Toyota Sequoia Transmission Problems
hi, I have a 2005 sequoia limited 4x4, on stop & go condition, everytime I release the brake, car jerks on first gear, especially when going down hill or with air conditioning on and driving with low gears are pretty rough. I took the car to the dealer with this problem and the dealer said everythings ok, but I believe it has some type of problem either on transmission, or brake or somewhere... so if anybody is experiencing the same problem, or if anyone has any idea what is the problem, please help.
Thank you for any help in advance.
«13
  • drfilldrfill Posts: 2,484
    I have recently purchased an '05 Totota Sequoia, and the first thing I noticed was the jerking you mentioned when the brakes are released after a rapid deceleration. I would like to know the answer also. Please let me know if you find anything out. I will do the same.
  • This is considered "normal" for this truck.
    Nothing unusual to mine and a lot of others based on what I heard!
  • yes, many Sequoia owners are experiencing this problem. Just go to Google and search on "Toyota Sequoia problems" and read all the postings. If Toyota knows what's causing the problem, they are not admitting to the fault. Most postings indicate the service department states no problem found... funny how this is being reported across the nation and everyone is having the same "no problem found" problem.
  • kimmi3kimmi3 Posts: 3
    I have an '04 Limited 2WD..first start is fine peppy -auto shifting, I park and go off again and it's like it starts off in a higher/lower gear...engine revs high and not so peppy at first & doesn't seem to shift right away.....takes a mile or so down road and seems to adjust back to normal. Is this normal? Does it have to do with Trac system? Or the iForce system?
  • lorihalllorihall Posts: 3
    I had an 05 Sequoia for almost 2 years. I had problem after problem. It seems once they tied to fix 1 thing they something else went. My problem started when I would stop. While stoped it would feel as if I was hit in the rear. Guess what, the dealer said this was normal. To make a long story short. I got Toyota Corp. involved due to all of my problems, my torque converter had been replaced, trans. was worse than when they started. drive shaft replaced, slip yoke, universals 3 times. You name it, it was replaced,
    When they took the car back 1year9 months later it still had problems with the trans it had rear bearings bad. The sequoia is a very nice ride, I loved the car but hated the problems. I now own a Nissan Armada. The only complaint I have is it rattles. Between the 2 suv the sequoia body int and ext are a much better design.
  • ripplefctripplefct Posts: 3
    I dont really think its a problem. More of a comfort thing. feels weird to have it do it. My Tacoma does the same thing. From what I can tell, its the tranmssion shifting back into 1st gear. It could also be the trans shifting its self out of over drive. I pushed the overdrive button to dissengauge it and the problem went away.
  • petro33petro33 Posts: 192
    The problem you described is a common one on the seq. Mine ('01 2wd) will do it some times, and yes, it does seem to catch you by suprise if you have not expierenced it before.
  • kkritchkkritch Posts: 1
    When attempting to shift the transmission into gear via the shift lever on the steering column we're having difficulty putting the vehicle into gear. In particular when attempting to return the lever into "Park". If the lever isn't "forced" into park prior to the car being shut off it will not start without repeated efforts of trying to move the shift lever, which is difficult to move since the steering column locks. If the car determins that the vehicle is not in the appropriate gear it will not turn over. We have to make sure to push the shifting lever all the way up and away from you to try and get it into park to see the "P" indicator light come on. At times, its not an easy task. We've had similar problems with other gears and the sensor reading which gear is engaged. When describing this issue to the dealer they say it just normal wear and tear and the only solution is to replace the entire steering column. Has anyone experienced similar symptoms and resolved this issue. Can the shift lever mechanism just need adjusting/tightening because it appears loose?
    I'd appreciate any info that can be shared.
    Th, KDK
  • jackpcjackpc Posts: 2
    Yeh...My 2001 Sequoia broken down in Manchester NH returning to NY. It turned out that the whole transmission was trashed. I had to wait in hotel for 4 days to get a new transmission from Toyota. The car only has 43,000 miles. The problem started about 1 1/2 years ago - it was difficult to shift gears and it had to be pressed. There were times when driving on highway the gear would not kick in to the next higher one although the car is automatic transmission.
    Anyhow, the Russell Auto in Manchester fixed my car and I got to tell you they are bunch wonderful people and very experience in transmission. The mechanic told me that it was a small piece of metal broke down inside the transmission and over the last year and half it messed up the transmission! The mechanic said the metal is inside the case and it's impossible to detect without taking out the entire transmission. I had the car checked before and no one was able to tell me the problem. In fact, we were driving it for over a year and half!
    I contacted TOYOTA and guess what they said to me...Sorry it's out of warranty! I am fuming. It cost me $3,600 and another $1,000 in hotel and rental car. I have 5 Toyota cars in the last 25 years and it really made me sick!
    Best luck on your car.
  • Last November the transmission in my 2002 Sequoia totally quit. I had been experiencing a kind of jerky thudding sound from time to time but never get the Toyota dealer to experience it himself. Well, they towed the Sequoia into the dealership and the next day I was told that they have some bad news and some good news.....
    Bad news was the transmission was shot but the good news was that Toyota was going to install a new transmission at no cost to me whatsoever. Pretty amazing given that the truck was out of warranty. Still with only 60K miles on it I'd expect a lot better life.
    Toyota must know more about these transmissions and their problems if they are willing to replace them, free!
    Otherwise, my truck has been fabulous for over 5 years.
    By the way, it's a TRD Sequoia, supercharged with all the TRD goodies.
    Hope that this may help others with sick transmissions.
    Jon Wilson
  • My is 2001 Sequoia. They told me the warranty is 5years or 50,000 miles. I had to pay out of my pocket!!! Is that the case? Thanks for info.
    Jack
  • seanicseanic Posts: 1
    The same thing happed to my 2001 4WD Sequoia. Info will be appreciated. Thanks
  • yevoyevo Posts: 1
    What you described in you e-mail is exactly what is happening to our Sequoia. Except, the hardware under the steering column cover actually broke. Did you ever find out if parts can be ordered to fix this or am I stuck having to have the whole column replaced.
    I appreciate your response!
  • We are on our second sequoia. both had the same problem. short story, it's your transmission.
    ours started with the lurch at stop lights etc. we also were told it was our air conditioner! the problem continued to get worse. it proceeded to a roaring when we were about 65mph, and the transmission started slipping then slamming into gear.
    we had to have to the transmission replaced in the first one. when the same problem started to happen on the second sequoia, we took it to freeman toyota in hurst, tx. the service manager knew exactly what it was. i cannot remember the part, but they replaced ours and we have been fine since.
    good luck!
  • atljamoatljamo Posts: 1
    we just bought our used Sequoia, great vehicale, roomy powerfull etc...
    driving down I75 pulling a yard trailer (low weight, just kids bikes) the tranny total died and rolled over to the shoulder on a very busy spring break vacation >>> of course it's raining like crazy so we waited outside for the wrecker to take us to toyota, nice poeple but hey for 3600 bucks they should be nice
    I am going with the toyota tranny as opposed to the AAmco one, my guess is that there is some value in them doing it going forward
    anyone have any thoughts??
  • gillyhbgillyhb Posts: 1
    This is normal for many SUVs and PICK UPs with two piece splined drive shafts verses the one piece splined to the transmission.
    When there is hard braking the front of the vehicle goes down and the rear goes up. This action stretches the drive line causes the rear shaft to slide out of the front shaft according to design. When the brake is released this causes the shafts to contract,sliding back into place. This sometimes causes it to go beyond the normal contact area upon the rust spot.
    To remedy that we would use emery cloth/sand paper to clean the area and apply some grease. So when I feel it when driving my 03 I just ignore it not a problem.
  • mtufenkmtufenk Posts: 14
    Thanks for the explanation. My 07 4x4 does the same thing. It seemed to get worse the further I got from the prior dealer service. Once I have it serviced, it goes away. It does sound like a lubrication issue.
  • elizablueelizablue Posts: 1
    I have just had the transmission on my 2002 Sequoia fail. I called the 800# for customer service only to be told to try to make a deal with the dealership as my car was out of warranty.
    I am very disappointed with the quality of Toyota. I have experienced two separate occasions where the coil packs had to be replaced. Now the transmission on a 2002. I am tired of hearing that this is not the norm for Toyota.
    Every forum I go on I find at least 8-10 owners with this same problem. So one has to wonder why Toyota has not had a recall. My dealer is telling me it's going to cost about $5k to replace.
    I just filed a complaint with the National Highway Traffic and Safety. I would suggest more of us do the same. Since Toyota is refusing to acknowledge they have a problem.
    Many people are citing that debris from other mechanical parts that have failed such as the a/c housings got into the transmission and caused it to fail.
    Recalls/Defects | National Highway Traffic Safety Administration(NHTSA) | U.S. Department of Transportation
  • joslyn7joslyn7 Posts: 2
    Hi I have a 2001 Sequoia please give me info on transmission I am having problems with overdrive please give me a contact # so I may be lucky like you and get a new one. Please help thanks.
    please find out the name of the part that was replaced. I think I have the same problem thanks.
  • slip ring, or slip yolk
  • freeman toyota in hurst texas
  • kattoy2003kattoy2003 Posts: 3
    My 2003 SR5 just started having the jumpy shifting. It waits a very long time before shifting, and then jumps to the next gear. I have 95,500 on it. It just started wtihin the last 4K miles or so.
    thoughts?
  • sequoia4sequoia4 Posts: 1
    Today while driving my Sequoia would be slow on accelerating from a stop. It was like it was "fighting" to get into gear. Slowly it would reach about 35 mph and then jerk into gear. Any ideas?
  • I have a 2004 Sequoia with 132k miles. Starts fine but won't shift into any gear; message on dashboard is "A/T P". Anyone seen this? Taking to dealer on Monday morning but just wondering if anyone has experienced same..
  • dxydxy Posts: 1
    I have a brand new 2010 sequoia limited less than 200 miles, I noticed something weird though not sure if they are problems.
    1. When I brake in low speed in parking lot, from time to time, I felt the car "jump" forward a little bit. It seems like I wrongfully step on the gas instead of the brake, of course, I am sure I stepped ed the brake. The problem, however, is not repeatable.
    2. If I push down the gas pedal very gentle, the transmission gear shifts, the rpm stays around 2000 and the speed goes up. If I push down the gas pedal in medium hard steadily, the gear shifts to the second or third, and will not shift to upper gears. What I see are: the rpm goes up higher and higher to 3500-4000 and the speed goes up to 50+ miles/hour. (I didn't try longer and/or harder.)
    However, if I release the gas pedal and push the gas pedal again, the gear shifts, and rpm goes down to 2000.
    Are these problems? Many thanks,
  • Did you find out what the problem was? My wife's 06 is doing the same thing? It only has 37,000 miles on it!
  • I have 2001 limited edition sequoia with 165,000 miles. In month of October, My car engine died at the intersection so I put car into Park gear and started right up but when shifted to any gear R,D,2,1 engine will die right away, I was stuck at the intersection. so called towing truck and hauled it to dealer in town that evening, next morning I went to dealer lot and started, tried gear, same will not move and engine will die. I had service department trouble shoot this issue, left car there for three days, then I got a call, they did not have any problems with this vehicle so I told them to keep it for few more days. I got the vehicle with out any bill, so that was good but my sequoia was not reliable vehicle for family trips anymore (what if)
    Now 11-20-09 My overdrive is used to eliminate noise from engine while on the road, it sounds like as if stick shift gear is in high gear at low speed. pushing od button kills the sound and run normal and it happens during 30~75 miles.
    Google search refers ths issue to Transmission problems. Feed Back Please!
  • luweegyluweegy Posts: 3
    My 2002 Sequoia shifter was getting sloppy and would only shift from park- neutral-drive.140k miles. Now it won't even come outa park. What parts do I need to fix this?
    Thanx.
  • janh1janh1 Posts: 1
    I also have a 2006 w/ 72k doing the same. Any luck with yours?
«13
Toyota Sequoia Transmission Problems — Car Forums at Edmunds.com
