Plymouth Grand Voyager
My transaxle ssems to have an issue. Perhaps someone can help. It will not go up hills or inclines nor will it it want to climb from a parked position on an incline. If it sit for a couple of hours its fine for a couple of tries then doesn't want to go up. It is fine on Flat surface roads/freeways and is fine in reverse on flat or inclined roadways. Fluid level is fine and clean. I had the system flushed in May, two bolts on the pan were recently loose, causing a leak and were re-tightend. Any ideas?
«13
  • i like the van alot :)
  • i found a 1998 Plymouth voyager for sale on ebay and it only had 29,128 miles on her and was only $7,000 so i might buy it as my next car. :shades:
  • What price and mileage would you want to look for?
  • abdul54abdul54 Posts: 1
    hi I have this problem if some can help me, thanks
    I am loosing the water from the bottle near radiator, I have changed the whole radiator,and its hoses as well even the radiator cap changed as well aand i did not found any change in the engine oil color, also the belt changed and I removed the thermostat from the engine but the problem still,
    any help please
  • sadamsrnsadamsrn Posts: 1
    Had similar problem with a 99 G.V. with the 3.3 engine. Turned out to be a connector to a line that went to the rear heat system. $150.00 for the part. Spent $500.00 for that and other work back in Feb. 2 weeks later, someone cuts in front of my wife and van is totaled. (sorry about, needed to vent!)
    Anyway, help this helps. Good luck!
  • reslingresling Posts: 2
    Looking for TSB 2304402-dated Oct 14th, 2002
    regarding a fix/kit for repair of strut tower metal to solve premature rusting problem found on 1996-2000 model year minivans.
    Has anyone else dealt with this problem?
    Also NHTSA issued a bulletin # 1000317 on this problem
  • 97xpresso97xpresso Posts: 249
    Edmunds frowns on recommending competing forums, but do an internet search (Allpar minivan) lots of info on strut tower rust there.
  • mmettsmmetts Posts: 1
    I have a 2000 grand voyager it seems lately that after awhile of driving and it is very warm out the van wouldn't start. My mechanic showed on how to start it under the hood by the relay switch I am wondering what could be wrong with it the mechanic told me it might be the ignition switch but it will be very expensive to fix. I don't want to fix it if that isn't the problem does anyone have any other ideas.
  • xrman55xrman55 Posts: 1
    I have a 95 Grand Voyager. Some time back, the finger grasp on the hood release broke. Since then, I've been using a channel lock to pull on the wire & trip the release. as you might suspect, the wire has become frayed & it has become almost impossible to open - not a good position to be in with a 12 y/o vehicle.
    Is this a difficult fix? Are the parts available? Does it need to go to a dealer? I know that would be expensive. Any help would be appreciated.
  • I have the same problem. I have navigated the web for a replacement part with no avail. I would go to a dealer and ask them to order one for me but I retired and brought the 93 GV to Panama and there are no agencies here. If you find a place that has the handle please let me know to order it. If a Chrysler dealer can get you one please get me their email so I can order one myself.
    Good luck!!
    Ed
  • rgb4rgb4 Posts: 5
    I have a 1992 plymouth grand voyager. Is there a relay or shut off for this vehicle? I'm not getting any fuel (tank is full)or do in-tank fuel pumps quit with out giving any kind of warning. Can a feul filter plug up w/out burning the pump up?
  • rgb4rgb4 Posts: 5
    If the Mechanic by-passed the relay to get it started, try replacing the relay. That happen to me but I had to replace the switch because it broke inside. But changing the switch didn't help. Still have same problem.
  • hmownerhmowner Posts: 23
    Any recommendation regarding when to replace the timing chain?
    I have a '99 Grand Voyager with 105K miles. So far, the engine is smooth, and I haven't heard any abnormal noise from the engine. A quote from a dealer to replace the timing chain, water pump, and other belts is around $1000. I don't want to spend extra $$ for this van as I only expect it to last 2 more years at best.
  • I just bought a 1998 plymouth voyager and the transmission doesn't shift properly.
    It shifts ok when taking off but once it goes through all the gears it will down shift and stay like that until I
    come to a stop and then it starts all over again.
    Sometimes it will shift normally while getting on the highway but then downshift and stay there
    but then nothing it's like it's in neutral what can this be???
  • My van is a 1998 Plymouth Grand Voyager with 118,000 miles. It has a 3.3L engine with an automatic 3 speed transmission. The problem does not create any strange smell or sound. I have a minor oil leak from the pan gasket - unrelated to current problem. The problem is as follows: in March of 2007 we had the transmission fluid changed (completely a maintenance item, no problem existed at the time). Two days later on a family trip while traveling on the highway we noticed the transmission goes into limp mode (staying in second gear). Along with this was the "service engine soon" light. Have had the car looked at and no obvious cause and it appears that there are no mechanical problems. Recently within the last two months, this limp mode seems to be occurring more and more often. The limp mode condition is reset when the ignition is turned off and the car is restarted. November 4th, had error codes read from computer and they are P0700 and P1776. I would like any suggestion on what could be causing the problem. I am considering 4 possibilities: 1. wrong transmission fluid (at service they put in dextron plus additive), 2. one or both of the speed sensors, 3. transmission control module, 4. solenoid assembly. I am open to any and all considerations, thank you.
  • I have a 1997 Plymouth grand Voyager with a 3.3 engine the problem I`m having is the lights on the wiper buttons the airconditioning button and the air recirc. buttons are flashing. I heard that there is a way to reset these so they wont flash anymore, any help would be appreciated.
  • sorry to bother you but i have some of the same problems. did you get a response on this and i could use some help for the past 3 years i have had problems and spent between 800 and 1500 each time and it is killing me. and it still is not fixed. i even changed the entire transmission. still have the service engine light coming on with transmission codes.
    thanks harris mueller
  • Hi i have a 99 voyager
    In the last 2 months when ever the weather got cold the transmission started to not work the it should when you put it in reverse and then go forward it just stalls you could be accelerating all you want and just sits there. So for now we reverse park onto the drive way so that we don't need to go backwards because it does go forwards at first but when you put it back to reverse and the engine is still cold it doesn't go forward until you put it in gear 1 or 2.
    Can someone please help me and tell me why this is happening?
  • I just bought a 1994 grand voyager. how can i tell what options came with this van when it was new. woild you believe it only has 55000 miles on it and it is in mint shape.
  • What ever option you see and use on the van is the options. Do you feel like your missing one? Go to a carfax...maybe it'll list it on there.
  • what I am primary looking for is rather or not it has a tow package. i see ne hitch. how-ever does that mean that the van does not come with a beefed up suspension and a tranny cooler.
  • ptsourisptsouris Posts: 4
    I have a 1993 GV. the transmission all the more often gets locked into 2nd or 3rd gear and in order to reset it I must restart. My mechanic has already changed the shift solenoid twice to no avail. It seems to me this is some sort of electronic part gone bad but how do you find it out of so many? Does anybody have any suggestions on this problem?
  • fordfan_17fordfan_17 Posts: 175
    1993 chrysler products are still OBD-1 what you are describing is called failsafe the A604 (41TE) transaxle has a high failure rate of input and output speed sensors and pigtails that plug into them what codes are being produced by the TCM? the transmission control module is separate from the pcm, the TCM connector is blue 6 pin connecter found under the dash to be able to help you, you will need to provide me the codes from the tcm .....
    Hey there, thank you for taking the time to post. I have brought the car to aamco now, so im hoping they can figure this out. When I did the key thing I got codes 12 and 21. The guy at aamco claims that the pcm will not talk to his diagnostic tools. I don't know if I mentioned this but the van besides going into limp, it also started running very rough as well. I don't know what will that turn out but I know I'm pretty scared because I have lost a car to electronic problems that nobody aould of figured out, and it did suck. Thank you again I'll keep you posted.
    aamco is our sister company normally if there is a no communication problem it will generally be a blown fuse not getting power somewhere needed.
    code 12 is Battery has been disconnected
    code 21 is overdrive hydraulic pressure switch circuit
    possible defective solenoid block
    Thanks again,
    The aamco guy gave up on it so I have it back. What's a solenoid block?(shift solenoid). I'm going to give the dealer a crack at it, see if he figures it out. If I have to I'll get organized and try to fix this myself. I'll keep you posted whatever happens.
    Paul
    this trans has an external solenoid block that controls all shifting aspects of this transmission if you open the hood and may have to remove air intake you can look right down and see a 8 wire pigtail plugs into it. removal of the input speed sensor will be necessary to get the middle bolt of the solenoid block out
  • I have a problem with the A/C. Sometimes I get cold air and other times I don't.
    Is there some kind on sensor that needs to be replaced? Any suggestions? It's getting hot in Texas . I'm on a fixed income and want to be able to talk to the mechanic intelligently. LOL
    I just picked up my minivan from the dealer. I drove it a good deal and it didn't go to limp mode. They probably fixed it. I won't know for sure until i drive it a couple of weeks. They rebuilt the transmission, changed the valve body and the torque converter. The job went for $2100. I'll keep you posted if this does not work either. If you don't hear from me , it's fixed. Thanks again for your input.
«13
Plymouth Grand Voyager - Car Forums at Edmunds.com
