Chevy Blazer GMC Jimmy Maintenance and Repair
Is anyone familiar with brand quality on after-market suspension parts? (ball joints, springs, etc.) Moog? McQuay Norris?
«134567119
  • 1995 Blazer. Started having a dead battery about 30 days ago. Put in new battery, same thing. If I do not drive it for about 3 days the battery is completley dead. I have checked all lights and doors are closed and Etc. What could be causing a battery drain?
    Wonpder@aol.com
  • Starting with the obvious... there's a short. However, finding it can be the old "needle in a haystack" exercise. You could have a shop look at it, but in my shoes I'd do that only as a last resort. They will rack up the hours ($$$$$) looking for it. I'd try finding it myself, first. Then, if that failed, I'd find someone who specifically deals in electronics. They'll find it way before an auto mechanic. I had a Honda that did this, but I never fixed it since the car rarely ever sat for three days.
    Has anything happened to the vehicle electrically? Is the radio stock? Does it have an alarm? Poke around with a flashlight. Sometimes the insulation on some wire or connection will erode causing enough of a short to keep a small amount of current flowing, but not enough to trip a fuse. Try starting at the battery and following the system through. Good luck. It's the things that go "snap" or "clunk" that are easy to fix. Annoying problems like this one can drive you nuts.
  • No, not a thing new. Could the wireing on the trailor hitch case a problem. I never use it , the wires just hang there. I will give it a try my self. Did you ever hear of a diode in the alternater going bad and causing a leak.
  • Yes, that happens, too. A short can develop that could draw the charge back into the alternator. If nothing else on the truck has changed and it just all of a sudden started draining, that could be a culprit. An auto parts store with a good modern tester might be able to confirm or eliminate that theory for you. Although, if it's still the original alternator, it's on borrowed time anyway.
  • We just bought our new baby, and hoping none of these problems happen with the new vehicle. We bought it so we can pull it behind our RV, so it will not get a LOT of mileage.
    Any comments on the 2001? We bought a LT 4WD.
  • Has anyone had this installed?
    Code#: ZM5
    Shield Package (4WD)
    Includes transfer case and front differential skid plates, fuel tank and steering linkage shields.
  • ryanbabryanbab Posts: 7,240
    Are you talking about a skid plate pkg? It sounds like. Its just a metal cover under the truck that is bolted on to prtect the things you have listed. Its very nice and if you hit anything you wont tear up your drivetrain.
    How much are they charging? If its under $100 go for it. I have a silverado with it and its nice worked already a truck blew a tire and i was on the receiving end of it. Checked when i got home at there was a rubber mark on them but thats all.
    The silverados skid plate pkg is like $85.
    Ryan
  • Yes, Ryan, that is what I was referring to. I requested it from the dealer, and they had it installed and didn't charge me.
    My question is, he thought it was only one plate they installed, but this refers to "plates."
    i have 2 on my truck
    1 for the trans and one for the front diff
    Ryan
  • You can confirm the ALT leakage by taking a current measurement with a multimeter. Set the meter on its lowest scale and connect the leads between the neg line and the neg post on the battery. You have to remove the neg lead on the battery terminal in order to perform this (current is measured by breaking a circuit). In short, the meter wires will be between the neg battery and the neg lug. Take your initial reading (say .035A). Then, disconnect your hot lead from the ALT and see if the reading significantly drops (say .005A). If it does, the ALT is caputz. It is possible for a leakage of .030A to drain the battery in a few days. If the reading doesn't drop, start pulling fuses to isolate the circuit (radio, etc)
    Once had a cavalier that kept killing batteries. Turned out to be the dang trunk light. Jerks who fixed my wifes car (after an accident) didn't set the liquid switch in the correct position. That one was a blast to figure out.
  • 60 days ago I had to drive 200 miles in 2nd gear
    since my transmission would only slip in high gear.
    The dealer sold me a new tranmission $2200.00.
    Last week , no high gear, the dealer claims the
    transmission clutch was burnt out. In both cases
    the SES light was intermittently on and off, not
    flashing. My air conditioner has failed recently
    also. The SES light has been giving me problems for
    the last 6 months, ever since the dealer updated
    the program to fix the ABS braking problem.
  • I have a 2000 blazer LS 4x4 2dr, and occasionally, the headlights flash off briefly while driving. dealer says they cant find a problem. knew they would say that. its a quick flashing, like a blink. just worried that some day they might flash off for good while im driving at night. would appreciate some input. Thanks
  • HEY PEOPLE, YA'LL HAVE GOT ME SCARED! MY WIFE AND I JUST TRADED IN A HONDA PASSPORT FOR A 2001 BLAZER. THE PASSPORT WAS DEFINATELY A PIECE OF CRAP. WE WANTED TO GET OUT OF IT DUE TO THE FACT THAT IT DOESN'T HAVE TETHER POINTS FOR BABY SEATS AND IT WAS HEADING DOWNHILL QUICKLY. TALK ABOUT SHODDY QUALITY. ANYWAY, WE WERE CONSIDERABLY UPSIDE DOWN BECAUSE OF THE HORRIFIC RESALE VALUE OF THE ISUZU/HONDA VEHICLE SO WE HAD FEW CHOICES. MY BROTHER-IN-LAW SELLS CHEVY'S AND WAS ABLE TO GET US INTO OUR BLAZER AT A REASONABLE PRICE. BUT NOW, I'M WONDERING IF WE DID THE RIGHT THING HERE. IN RETROSPECT, CAN YA'LL GIVE ANY ADVICE ON HOW TO AVOID THESE PROBLEMS (OTHER THAN NOT BUYING GM!) IT'S MY WIFE'S CAR AND SHE DOESN'T DRIVE A WHOLE BUNCH, BUT WE PLAN ON USING IT TO HAUL OUR POP-UP. GRANTED, THE BLAZER'S BRAND NEW, BUT IT JUST SEEMS SO MUCH MORE SOLID THAN THE PASSPORT, AND A HELL OF AN ENGINE! ALSO, HOW'S THE RESALE VALUE COMPARED TO OTHER SUV'S?
    THANKS
    First off relax. Not all blazers have problems some do but the majority do not. You hear alot of horror stories on here because people want them to be known. How often do you hear good things about for example a store? You usually only hear the bad things. So far my mom has had her 00 LT 4x4 for 15 months and has a little over 10K miles. She doesnt drive it much. Only problem so far is a front diff seal leak that was taken care of in no time. Hopefully your blazer will be great. Oh yea before her 2000 she had an 87 which was factory ordered and she sold it this past may. 13 years 130,000 some odd miles only problem was a hose recall (actually a hose broke and we broke down). I see the truck everyyday at school thing still is running and looks great
    Ryan
  • I seem to remember something in my manual that mentions that some vehicles lose their headlights for a moment when they are using their turn signals.
    Ask to see a manual for the 2001 and look it up.
  • 777, You have got to be kidding me. What manual where you reading?? The owners manual? I certainly hope not. Lights should not go out with the turn signals on..period. Not trying to be rude...
    Russ, I would suspect a bad ground or relay. Try "lightly" tapping your fuse box and light assy's.
  • mted23mted23 Posts: 16
    Most of the posts on this site are from people venting about their vehicles. I have a 99 Blazer LS with 37,000 miles on it in just under two years. The only problem was a squeeky door panel that was over tightened at the factory. The dealer fixed right away. By the way, we just had 12 inches of snow here in the Chicago area and the Blazer was excellent. I hope you have good luck with your Blazer.
  • No, I am not kidding. In the 2001 owner's manual, page 2-55, it says:
    "The DRL (Daytime Running Lamps) system on some vehicles may turn off temporarily while the turn signals are activated."
    I wouldn't fib, I might get coal in my stocking next week! LOL
    This is true of GM vehicles with the parking/turn signals as daytime running lights. Example: Camaro, Venture, Corvette, not the Blazer. These lights momentarily go out when the turn signal is cancelled and then comes back on constantly to be the DRL. For those who have asked: my 99 Blazer is excellent in the snow. I have OE Goodyear Wranglers and Auto-trac. Deep snow seems to be no problem when 4hi is engaged. This has been an unusually snowy December in the Chicago area and I am sure glad I have my Blazer.
    I hear ya about all this snow. I live in northwest indiana and we have been getting dumped on. How did your blazer come with goodyears? My moms came with crappy uniroyal. Hers is a 2000 LT with the premium ride? (best) suspension. Autotrac and 4 wheel high works great on her blazer and on my silverado.
    Ryan
  • boat10boat10 Posts: 59
    Anyone out there had problems with the oil cooler lines going to the radiator???? I had one to burst........WHAT A MESS!!!!!....... The general has ordered new parts. Mine is a 2000 4x4 LT and has 13000 miles on it. I live in Tennessee and would not be without my BLAZER..
    This is my 6th one..started buying in 1983 when they came out, renew every three years.absolutly love them, there are times the wife takes it away from me so she can do her hauling. Has anyone seen any specs on the new 2002.. many changes it looks like, new motor, new body style..
    Ryan,
    There is a small handful of Blazers that come standard with Goodyears. I bought mine from dealer stock in Frankfort IL. I choose my Blazer from several of the same equipped Blazers because of the Goodyears. Not only are they good in snow but they are decent in some light off road use and very good in the rain.
  • News from GM... extended warranty, although for only CA residents...
    http://forums.vmag.com/suvbrav0199/messages/143.html
  • Just got a 1999 Chewy Blazer AS 4D 4WD and I am trying to get used to it. First in 2WD I notice that it rolls back slightly when I'm on a hill and I take my foot off the breaks to give it gas. Is this slippage in the trans? Also, In 4WD I feel alot of resistance in my turns like when I'm pulling into my driveway. Is this normal?
  • I recently had oil cooler lines replaced on a 1999 Blazer LT due to minor oil leakage. The service tech informed that this is not too uncommon and he has seen this numerous times.
    I have found that the Auto Trac system is wonderful in the Minneapolis snow and slush. My only complaint regarding my Blazer is that as the cold temperatures descended on Minnesota; my gas mileage seemed to fall off from 17.5 highway to around 15 mpg.
    I am very pleased so far.
  • Hi,
    Well I dont have a blazer yet.. but January the 1st or so My Granfather is supose to take me to go get one.I already talked to the guy and its a 1996 2dr white abs 4.3 vortec. Wondering a few things How much Gas mileage will I be looking at and where can I find really neat accessories like extra things such as inside lights and stuff to really make it neat and different but not have to spend a fortune. Thanks for your time.
    Lonnie%0
  • Blazer is synonymous with trouble. My family has had
    two over the last five years. The worst vehicles we've ever
    owned. Like it or not, our new Four-Runner is hands down
    a better vehicle. About fifty times better. Unless you enjoy
    replacing two year old transmissions and having constant
    fluid leaks.
  • I have a 2000 Blazer and the 4wd electronic engagement is out for the second time in 4 months. It will go into 4low but not 4hi. First time, the dealer said it was the electronic module. This time they say it is an electronic motor control AND the module. BUT, there are no spare parts anywhere in the U.S. and they have no idea when parts will be available. They told me this is a common problem this time of year but normally affects '95 and '96 models and not as many newer ones. So, this means this has been going on for five years and GM has not done anything about it. And, it is apparently very common as the parts supply is already exhausted. Anyone else had this problem? Statistics say you are out there somewhere!
    The other problem I had was the back glass would not lock. It would latch but not lock. It took three trips to the dealer before they determined it was another electronic module in the driver's door that was bad. Then there was the fix for the 4wd last Aug. Now, it has been in once to find out there are no parts and will go again to finally (hopefully) get it fixed again. So, once I go one more time to get the 4wd fixed, it will make a total of six trips to the dealer for warranty service in one year.
    John near Indianapolis
    The 95 and 96 pushbutton 4x4 system is different than a 2000's 4x4 system. The 2000's system was released in 1999 its called autotrac. The pre 1999 version is instatrac. THe S-10's still use the old system but the blazers, tahoes, and silverados have switched over to auottrac. Its a great system the auto button is really good in rainy weather.
    Did they ever say anything about a solenoid? Ive heard of those going bad
    Ryan
  • opicdopicd Posts: 1
    I'll add my 2 cents here ... my 4wd hasn't been reliable for 2 years. Two transfer case repairs (one complete overhaul), two automatic trans rebuilds, numerous "minor" problems like wipers stop in downpour then go on when not turned on.
    Bought a new 97 blazer in 11/97 thought it was deal at $19k but have put $4k in repairs. Today the dealer said the fluid leak is caused by bad water pump and needs $600 in repairs.
    Anyone want to top this story?
    PS Chevy customer support said all this stuff happens all the time and ....don't expect any assistance from them.
«134567119
Chevy Blazer GMC Jimmy Maintenance and Repair — Car Forums at Edmunds.com
