Chevy Silverado and GMC Sierra Starting Problems
plusplus Posts: 1
edited June 2015 in Chevrolet
hello all,,
i have a Chevrolet 1500 Silvrado Z71 2003 with start problem, it will not crank at all,, battery good and took it to the dealer and started fin without any problems there, but some times it will not crank at all, but it will start if i keep try for 10 or more times!!!
i changed the key but still the same problem?!!
any help appreciated,,
See also: (Video, 2:11) Easy Ignition Fix GMC Sierra/Chevy Silverado
«13456718
  • byron14001byron14001 Posts: 1
    the problem is your starter, replace the starter, go to a mechanic place and ask them to replace your starter.
  • jmoran99jmoran99 Posts: 2
    Hi! My question is in reference to my 99 Chevy Silverado 1500. It cranks, but won't start. I checked the obvious (out of gas, etc.) and changed the fuel pump/filter. It still won't start. Cranks and will 1/2 catch for a second, but then nothing. Before I sink a boat load of money into this thing at the dealership, any idea? Your help is appreciated. Thanks!!
  • rusty25rusty25 Posts: 1
    I have a 2002 Silverado with 5.3L engine. Occasionally, when I turn it off, come back a few minutes later, it turns over but won't start. Leave it 15 mins and it starts. Recently wouldn't start at all, dealership put in fuel filter and fuel pump. Problem persists. Good fuel pressure (55psi). A second dealership has no idea of the cause; cjecked relay and its good. Message Center indicates low fuel when it's not starting (lots of fuel in it). Anybody have this problem, and know whats the cause?
  • hotel1hotel1 Posts: 50
    RUSTY..........No imm. start when hot ?
    Sounds like the FPR (fuel pressure reg.). Easy to check.
    Locate the fpr. Run engine then shut off. Pull off
    vaccuum line on side of FPR....WITH ENGINE OFF!!!!
    If wet with fuel.........Its bad !!!
    Many posts of no hot start and FPR failures on older GM
    v-8 trucks around the net.............
  • mshinemshine Posts: 2
    My truck wont start . When I turn the key it cranks for about 1/4 second then nothing .
    None of the gauges or power locks and windows work .
    The battery is fine .
    Last night while driving all the gauges quit working and the a/c compressor kicked off , but the truck still ran fine .
    Any help would be greatly appreciated .
    Start with the battery cables and connections........
    Problems with the battery bolts bottoming out in the
    terminals and not using/replacing the crush washers.
    BTW: Any mods or a killer stereo installed?
    I have a Western snow plow . I think there is a short or loose ground wire somewhere . I got the truck running , but every so often when I hit a bump , the gauges go dead . I will be checking all the conections tomorrow .
    Thanks ,
    Mike
  • chevy2007chevy2007 Posts: 2
    2007 BATTERY DIES JUMP START TAKE TO DEALER CAN FIND NOTHING WRONG ONLY 2200 MILES ON TRUCK.TRUCK IS A LTZ MODEL ALL POWER
  • diehard40diehard40 Posts: 5
    I've got a 1988 K1500 with the 350 FI. It won't start, turns over, but won't start sounds like fuel problem. Fuel pump has been changed, fuel filter, Fuel pump relay, Fuel pump fuse, ignition coil, all have been changed or checked.
    Any ideas.
    It is getting power, just seems to not be getting any fuel.
  • 0patience0patience Posts: 1,542
    The possibilities are endless.
    Start with basics.
    Compression. Spark. Fuel. Air in and out.
    Check the compression with a compression gauge.
    Use a spark checker to see if it has spark.
    Put a timing light on it and see what it shows.
    Use a fuel pressure gauge to see if it is getting fuel pressure.
    Is the air filter/tubing plugged? Is the catalytic converter plugged?
    When you crank it, does the engine itself seem to be puffing smoke (like out of the valve covers and oil fill) when you crank it over?
    What do you mean when you say it is getting power. Power to what?
    it is sparking,
    it shouldn't be the catalytic converter since it was pulled 10-12 years ago.
    no puffs of smoke around the valve covers.
    I probably just need to get a professional to come towe it in and look at it,
    just trying to be cheep and do it my self
    I just remembered something. :blush:
    Check the fuel injection and ignition fuses.
    They should be marked ECM-IGN and INJ A+B.
    I am betting one of them is blown.
    If it is blown, pull the air cleaner and see the pair of wires that goes to the injector. It is most likely worn thru the insulation and is shorting on the air cleaner.
    Let us know what you find.
    i have checked every fuse that i can find on the truck, but will look at them again.
    now the wires leading to the injectors may be a problem. I know that one is worn and gets a little loose at times.
  • Let the fuel pump prime before turning the engine over ... then turn over without hitting the gas. If it keeps flooding you may need to get the ignition retarded or have the engine tuned. Automatic choke issues may cause problems.
    It could be the fuel filter needs a change. Using an engine additive may cause problems too as it dissolves so much sediment in your tank that it clogs everything up.
    Starters are bullet proof on the Chevy but worth changing every 10 years as is the alternator.
  • I have read several posts similar to my problem and still have not seen much about it being fixed, so any help would be great.
    I have a 92 Silverado 4.3 V6, 5-spd manual trans. Truck will not always start when turning the key, Dash lights and radio fire up but engine does not fire. Most of the time I hear a click and sometimes there is not click at all. If I let the truck sit for 5-15 minutes and try again, it starts right up. I have had this problem off and on for more than a year and sure it must be a simple fix. I have changed fuel pump, filter, starter , plugs, battery, neutral safety switch, wires, plugs, cables, coil and still cannot find out what the deal is. It is as if there is a relay being tripped or a fuel pressure backup somewhere that needs to dissipate before the truck will start. If anyone has any ideas, I am certainly appreciative.
  • ubwareubware Posts: 2
    1995 3/4 ton truck with 454 was sputtering, changed fuel filter, ran little better. Next day it sputtered at stop light, limped home and next day started it and it died and will not start now. Checked fuses(OK), checked fuel filter(OK), no spark. Help!
    Charles
  • how about the fuel pump, however they often (or at least in my experience) don't give any warning prior to going out.
    For those that have replied to my 88 problem. I finally got it solved. After changing the fuel pump initially and not solving the problem, i thought it may just be a bad pump and was gonna change it again. that is when i noticed that somehow the ground wire was broken that goes to the fuel pump. repaired it and it fired right up. Often the little things that get overlooked or missed.
  • Hi My father in law has a LTZ crew cab 4x4 and has had the same problem. His battery is getting run down because the fuel pump runs and runs. It has been to the dealer 4 times and they are putting there heads in the sand. They have contacted a lawyer and may have to envoke lemon law. My inlaws hate the fact that they even have to talk with a lawyer but the spent 45k on this truck and he does not know if it will start or not. Next time you run around in it when you shut it off see of you can here pump running. It may be a short in the wiring harness. Yesterday we went down to a fishing hole on a bumpy road and it started doing it. He really wants to keep this truck but it has been a real heartbreak for him. If any one else has any ideas would be greatly apreciated. I am on here to check for them you can email me direct. doubledw@cox.net Thanks
  • Is this code indicate simply replacement of CMP? thanks for help
  • I have had this truck for three weeks. Yesterday I was at the beach fishing and on the way back it would not start. Initially it started, and withing 5 feet it bogged down and would not start after that. The battery is fine, the starter seems to be fine (it keeps cranking but the engine does not start). I got it towed to the dealer and will be finding out more soon. I hope this is not the beginning of a chronic problem. But in case it is, I was hoping you could give me some information on how to recover the cost / or how to approach using the lemon laws to get this thing replaced?
  • Hi,
    My brother bought a 2003 Silverado from an American insurance company. It has a couple of dents and scratches but we can fix that. Unfortunately the car arrived in Holland without a catalysator, so my brother bought one from a scrapjard. The only problem is this catalysator is for a 2003 v8, it fits perfectly. But the connectors from the lambda sensors are different. We managed to connect them, but the engine won't start. It turns over for around 3 seconds and then stops.
    My questions are:
    Is it possible to use a v8 catalysor on a v6?
    Do we have to change the 4 lambda sensors?
    Is there an other reason why the engine wont start?
    I would really appreciate it if someone could help us out!
  • sjors1sjors1 Posts: 2
    It revs!! Apparently recharching the battery was enough!
    Only problem now, it's stuck in 'P' and it wil only almost shift to reverse!
  • I have a 2003 Silverado, and in the last year and a half or so it has decided that it randomly won't start. When I turn the key all the lights and gauges, radio etc comes on, but the truck won't start. It does not make any clicking or anything, I have been to the mechanic more times than I care to think about and no one can figure out what is wrong. It happened today twice in less than one hour, and it has never done it more than once in a day, so I went to the mechanic, and of course it started. The starter has been checked, its fine, new battery, cables are tight, relays have been changed, and it keeps happening. I feel like I am loosing my mind over this, and since I never know when its going to happen, it worries me because it may be 5 minutes to an hour or more before it decides to start, and I dont need to be stranded for that long by myself.
    If anyone has any ideas, please let me know, because I can't just keep dropping it off with mechanics for days at a time and never finding anything out!!
    THANKS!!!
    ~*~ Sarah ~*~
  • mmoonmmoon Posts: 5
    Just died dead in street. Replaced fuel relay .. it was Ok .. replacd fuel filter It was bad.. Pump checks out fine and pressure of gas is to the box behind the carb? Disconnected the two lines (feed and return) from the fuel tank ..clear and under pressure ? If primed it runs quiet well, but I can't get fuel to the carb? Help
    Had an Ods Aler (GM product) same thin.. replaced the igniton and was told by the dealer if the key is a bit off . the car will think it is a theft and shuts down the fuel system? Never happened again after the relacement? good luck?
  • I have a 2000 silverado and it has a starting problem. It takes me about 3-4 times to start it. It turns over everytime, but wont start until the third or fourth time. It sounds normal when i try and start it, it just wont start. When it does start it takes a second for it to completely start up, like its struggling for fuel. Ive already replaced the battery and fuel filter. It seems like a fuel delivery problem to me, or maybe a sensor is going bad. I have no way to tell that because no check engine light has come on. Any ideas? Thanks
    Just had the dead in the street issue here . got it resolved... changed fuel flter/ still no result /then checked pump /had pressure..came to find out it takes a lot of pressure aout 50# to supply fuel to carb. changed the in-tank pump and screen ans it is now fine ......good luck
«13456718
Chevy Silverado and GMC Sierra Starting Problems - Car Forums at Edmunds.com
