Volkswagen GTI Real World MPG
petervm
Member Posts: 2
in Volkswagen
I have a 2007 Golf GTI that has done only only 5000 miles. I am averaging 13 MPG in the city!! And that is when I drive it carefully. The local dealer tells me that they cannot do anything if there are no warning lights on and basically does not believe me. Any ideas what may be wrong? Anyone else ever experienced this? I am lost as to what to do... Appreciate any advice..
In mixed city/highway driving I've gotten as low as 24 mpg in my 07 GTI. If you were really getting 13 mpg, you would smell lots of stinky fumes from the tailpipe if the fuel/air mixture were too high. Barring this, look for a mechanical problem like a leaky fuel line, which doesn't register on any warning lights.
petervm is your problem solved? if so, how and what was the problem?
Yesterday I decided to "stretch" the GTI's legs a little on the highway to see what the mileage would be at high mph. At between 85-110 mph (don't try this at home) for extended periods I was still able to get 27mpg! BTW, the car is rock solid at any speed, even more so than the '05 TL I had a while back. Smooth as silk, even @ 110 mph there was still plenty of tachometer to go. Awesome. :shades:
Once I had it redlined and the car topped out at exactly 133 mph, verified by the Garmin GPS. When I glanced at the current MPG readout I've seen 6.7 MPG. The car handles that speed really well, no drama to it. And I agree, don't try this at home. Mine is an 07 GTI with the DSG transmission.
Before modifications, I was seeing 21 mpg city and 31 mpg highway. After getting the APR engine remap and a Neuspeed cold air intake, my mileage has improved. Now I'm seeing about 22 - 23 mpg in the city (mix of normal driving, stop-and-go, and leadfoot) and 36 mpg highway. The highway figure surprised me quite a bit, but I drive reasonably on freeways (about 70 mph) and use the cruise control whenever possible. And yes, I came to that figure based on actual fuel consumed, rather than the computer readout.
The APR chip boosted torque by quite a bit (up to 303 lb-ft over the stock 207), which allows me to get up to speed using lower rpm's, which helps reduce gas consumption. Meanwhile the CAI helps with more efficient breathing and cooler air for the turbo (for greater combustion). The two mods together are a well-paired combination of technologies.
So, 260+ horsepower with a combined 28 mpg. Works for me :>)
maximum speed in not limited by engine RPM. It is generally limited by the final rear end ratio or by engine computer software.
I remember driving on a German autobahn in a Volvo with overdrive. As an experiment, we drove with and without overdrive. The maximum speed was the same, just lower RPMs with overdrive.
The interesting part is that when driving on secondary roads, which in Arizona are superbly maintained, at speeds between 45-60 miles, our computer usually displayed 32-36 mpg unless climbing steep hills. Most of the time we were at 4,000 feet or higher altitude, in the Sedona or Flagstaff area in high mountains.
The car never had a single problem in 2.5 years and it always starts the 1st time.
1) Winter blends of gasoline do not contain as much potential energy as do summer blends, and
2) when the OAT is below roughly 40°F, fuel does not atomize as well as it does above that point; the lower the efficiency of atomization, the lower the fuel economy.
Many of these do use some oil, but it shouldn't be THAT bad. Mine was doing it when I first got it, but after upgrading the PCV system and using Castrol Syntec on my last oil change, it hasn't lost any.
Much better than my 2007 Mazda speed 3 (21-23mpg)
Surprisingly, similar to my 2002 Honda civic SI 2.0 NA motor which had less power and torque and was lighter.
My 2011 GTI tends to get 21 mpg on average. I like to blame it on the LA traffic, but in reality it's probably because of launch control and the car's overall fun nature.
