Chevrolet Malibu Maxx Rattles, Bumps & Squeaks
fezazfezaz Posts: 3
edited March 2014 in Chevrolet
I have a 2007 Malibu Maxx SS that I recently bought with about 300 miles on it. It was in service 9 months ago but has been in various auctions. I'm very happy with it so far, but there is a problem. A serious rattle from the front dash/window at 40-80 mph. It comes and goes but it is quite noticible. Of course it is under warranty and I plan to take it in, but if you have particular suggestions or advice, that would be great. :mad: Thanks.
  • Check the brake pedal assembly for loose play/ ...David L
  • fezazfezaz Posts: 3
    Thanks. I'll do that --but how can the break assembly cause a rattle in the windshield when I'm not braking?
  • popadopolispopadopolis cnyPosts: 14
    In the past, several members complained of a noise (rattle) in the windsheild area. It was found to be the black plastic grill covering the the windsheild area fresh air intake. Some had found that it had warped in the passenger side corner and lifed up a bit, causing the wind at driving speeds to make it vibrate and hit the body in that area. Making a rattling or tapping noise. It was covered under warranty. Check to make sure yours is flat and not raised up at all. Hope this solves your problem, have a great day!
  • kurtamaxxxguykurtamaxxxguy Posts: 1,794
    yes, my black cowl was one of those - it was replaced under warranty.
    The Maxx does have a fair bit of rattling in the front end, however. It can also generate very loud momentary pops when the windshield pillars warm up or cool down.
  • I think the annoying fluttering rattle coming from the ventilation area of my Malibu Maxx is solved. I have two 2006 Malibu Maxxs, both had the rattle. Following Popodolis suggestion I checked under the hood and noted that just under the rubber molding that seals the windshield end of the hood there is a joint in the plastic enclosure for the air system. About two feet in from each fender the plastic showed an opening that was wider than the rest of the joint. For a temporary fix I just took a piece of 2" wide plastic tape that you seal boxes with and covered the joint opening at the point where it seemed to have opened up. Went for a test drive. Voila, no more rattle. When my temporary fix loosens up I'll probably just run a bead of silicone down the joint to seal it. Thanks Popodolis.
  • Sorry I mispelled your name popadopolis. My brain doesn't stay attached to my keyboard. But I still thank you.
    Not a problem rmill777. I know the brain/finger thing well. Tends to get worst with age!!! I'm just glad to help and also glad you solved your problem. Have a great day. :)
    I still have the rattle, I'll have to try that fix.
  • I thought I had cured my rattle on my two 2006 Maxxs but they came back but the tape I put on quieted them down considerably. I guess I'll have to get to the dealer for a cure.
  • I took my Malibu Maxx to the dealer to fix the annoying, vibrating rattle. He found Bulletin 07-08-111-001 which advised putting double sided tape on wiper cowl. He installed double sided tape and the rattle is gone.
  • Has anyone had a problem with leaks from the Maxx windshield or other windows? I am having a problem with my 2004 Maxx where there is a leak when it rains heavy. I have not found it when going through a car wash, but if there is a heavy rain, there is condensation inside the windows, especially the windshield. I have also had wet carpet around the rear left passenger carpet area. Has anyone experienced this problem?
Chevrolet Malibu Maxx Rattles, Bumps & Squeaks — Car Forums at Edmunds.com
