Nissan Altima Engine Rattle
j3flyerj3flyer Posts: 15
Took the 2007 Altima 2.5 in for service today with 1,500 miles. Engine has loud rattle when starting cold, and louder when shifting into drive or reverse as the idle kicks down a few hundred rpm. I sense that the engine oil has settled over a period of time not running. Further, I believe the internal engine parts do not get the oil lubercation until fully warmed up. Then the loud rattle goes away. More noticeable as we get into the cooler/colder Fall days.
Nissan dealer is calling the "hot line" to see what the problem and/or fix might be.
Has anyone experienced this loud rattling noise during engine warmup?
«134
  • I have the same problem.. .Dealer said it was nothing to worry about.. Thinking about calling corporate.
  • j3flyerj3flyer Posts: 15
    The loud noise is similar to a diesel engine on an 80s VW first warming up.
    If I am told this is normal, that will definitely not be acceptable.
    Hindsight, I would reconsider buying the 2.5. Otherwise it is a great car.
    I will post what comes back from the "hot line" call that the dealer makes. (..traveling rest of week, will reply on weekend. Tks.)
    Please let me know what your results are with Corporate. Likewise, if the local dealer does not resolve my problem, I will also elevate to Nissan Corporation.
  • i have exactly the same problem.. especially in the morning.. there is a weird "roaring" sound when start up. but during the day it's fine. Should i be concerned?
    i also have two other problems with new altima (bought it on 9/29) one is that I can hear the WIND NOISE when i speed up to 60 mph... which is quite annoying. Also sometimes when I release the gas paddle and step on the break....the car would "suddently drive foward like a downshifting mechanism". The last problem also happens in the morning, too, which is when I turn the steering wheel...i can hear a grinding noise near the fender....
    any thoughts?
  • gooddeal2gooddeal2 Posts: 748
    This is normal for most cars now. Actually, I prefer the way it behaves.
    Nissan's "Hot Line" and the local dealer have determined the problem to be the exhaust heat shields in the engine compartment. Something to do with factory installation of the bolts holding the shields. The service writer told me that this has become a common problem for the 2.5 Altima. The fix is to replace the heat shields which have been ordered. In the meantime, the shields have been removed from the car by the service department....
  • teianateiana Posts: 1
    I was relieved to find this thread, as I have been experiencing the same extremely loud noise. The dealer told me today the same thing regarding bolts and heat shields, but they're trying to use washers to tighten the bolts, rather than replace the shields. I asked if the rattling can cause deterioration over time, but they said no. Hmmm.
    And I also have that wind whistle through the driver side window. It is a bit annoying, but overall, I really love my new car.
    It has been two weeks since the heat shields were removed. That was definitely what created the noise. I am not certain when the new shields will come in. Nissan might be coming up with a solution. No problems without the heat shields that I know of so far.
    You might consider asking the dealer remove the shields until a permanent solution/fix can be made. Using washers to tighten the bolts doesn't sound like something that will be long lasting...
    Our 2.5 Altima is great, and the gas mileage is starting to improve with city driving. With 2k miles, getting 23 mpg city compared to EPA 26.
  • I dropped mine off at the dealer this morning for the engine rattle. The tech rep says,"what rattle?". I am sure glad to hear that there are others having the same issue. Did they make it stop rattling?
    We left the car at the dealer overnight so that the engine was cold when started by the tech. That is when the rattle occurred. I was willing to leave it because they did not hear it when I drove it in. As the engine warmed, the heat shields must expand and the noise goes away as everything tightens up.
    Presently there is no rattle on our car due to the heat shields being completely removed. Again, waiting for dealer to get in new heat shields and/or perform a fix.
    Concerning gas mileage; I asked the service department to scope the engine or put it on the computer. The service writer suggested that we get 2k to 3K for a good break in first. Time will tell as they say.....
  • Took my Altima in and the dealer replaced the heat shields, but the rattle still occurs. I am taking it into the dealer next week. I hope they fix it this time!
  • Ours is scheduled for replacement of the heat shields Wednesday 14th Nov. Hope I can report that all is well. The shields have been off the car for about a month now. No issues with them off. Stay tuned.
  • '07 2.5SL also has the annoying rattle when cold engine starts .....does go away after time ...judging from the many similiar accounts I would expect a TSB from Nissan to fix this issue. The dealer wanted me to leave the car overnite (inconvient)so their mech. could listen ...now that the word is out I hope they won't play dumb and will just correct the problem. Other than that we enjoy driving our vehicle.
  • Took my car in to the dealer and ths time they said it was a bolt with meshing on it that was causing the rattle. They replaced it, but, slso said that Nissan was working on a fix and that they would put my name on a list. If it's not resolved in a few months I am calling corporate for some sort of resolution. All of the hi tech gagdets on their cars and they cannot even fix this. I am frustrated.
  • Dealer's service department replaced heat shields with what factory sent. According to Nissan factory, this will take care of the noise from the heat shields vibrating on cold start-up. The noise didn't start the first time until about a month after the car was purchased. So I will give it some time before I am satisfied that the replaced shields is the cure. Stay tuned.
    Otherwise if the rattle returns I will pursue with Nissan the idea of removing the heat shields completely. We had gone without them three weeks while waiting on parts to arrive.
  • I hope that works for you. I had the heat shields replaced with a factory modified version and the rattle returned within 2 weeks. Nissan put my name on a list until they find a solution. I am giving them a few months and then calling their corporate office. I hope I don't have a lemon.
  • Well i have had the same problem since july with my 07 altima it has had 3 heat sheilds put on did not stop problem.. now they say it is v t c gear and they have no fix at this time for it. i have filed a complaint. dealer will not refund my money or give me another car or even put a new motor in.my car is still under warranty . if the do decide to give my money back they are going to deduct milage from price and give me price for what it is worth now.this is messed up i am very disappointed in nissan and my altima. hope everyone has better luck than me
  • "Engine has loud rattle when starting cold, and louder when shifting into drive or reverse as the idle kicks down a few hundred rpm. I sense that the engine oil has settled over a period of time not running. Further, I believe the internal engine parts do not get the oil lubercation until fully warmed up. Then the loud rattle goes away. More noticeable as we get into the cooler/colder Fall days."
    I've noticed this on my 3.5 SE--on cold start-up, the software rips the engine instantly up to just over 2,000 RPM, which is when I hear the noise. This is ridiculous to race a cold engine this fast. Here's what I do: I push the start button without my foot on the brake, then place the selector in "N". Then, with my left hand on the start button and right hand on the gear shift, I push the button and instantly put the gear shift into "D", which prevents the engine revving above just over 1,200 RPM. Then, after a couple of more second, I put it in "P" and the revs rise up to around 1,750, then settle back. I don't know how this could hurt the transmssion, but at least it keeps the cold engine from trying to destory itself.
  • I TALKED TO NISSAN TODAY THEY TELL ME IT WILL BE THIRTY DAYS OR MORE ON FILING THE LEMON LAW. THEY KEPT PUTTING HEAT SHEILDS ON MINE THE MORE YOU DRIVE IT THE LESS YOUR CAR IS WORTH.. I HAVE HAD THREE HEAT SHEILDS PUT ON. DID NOT FIX THE NOISE..... NOW THEY CALLED MAIN TECH. MAN IN HE SAYS IT IS VTC GEAR AND THEY HAVE NOT GOT A FIX AT THIS TIME AND FOR ME TO DRIVE IT UNTIL THEY FIND A FIX.. CAN YOU BELIEVE THAT. THE MORE I DRIVE IT GETS CLOSER TO WARRANTY RUNNIG OUT...GO FIGURE.ALSO WHEN YOU TAKE YOUR CAR IN BE SURE TO SAVE ALL RECORDS AND MAKE SURE THEY HAVE THE DATES RIGHT..THE LAST TIME I TOOK MINE IN THEY GAVE ME A RECIEPT FOR THE TIME BEFORE! NOW I HAVE TO GO BACK AND GET A COPY OF MY LAST VISIT. IF THEY ARE TELLING YOU ITS THE HEAT SHEILD MORE THAN ONE TIME YOU NEED TO CHECK TO SEE IF IT MIGHT BE THE VTC GEAR. DONT WAIT UNTIL IT TO LATE
  • Heat shields replaced two weeks ago on 14 Nov. At this time no problem with noise or rattle. Not sure if the new shields have been redesigned or made of different material. The noise on our 2.5 was definitely caused by the heat shields. Never did we detect a noise once the first set of heat shields were removed and went without for several weeks. So doubt that our issue is with the CVT gearing. I will post again in another two weeks with a report.
    Perhaps it would be useful if these Nissan service departments communicated with each other and try to solve the problem based on experiences. I am satisfied that our Nissan service department (Nissan of Omaha) is doing all it can. Hopefully our issue is squared away.
  • IT IS VTC GEAR
    Don't you mean CVT? If not, what is the VTC gear?
  • 1996-2007 NISSAN MODELS WITH ENGINES: VQ35, QR25, QG18, GA16, VQ40, VK56, MR18, MR20; DTC FOR VARIABLE VALVE TIMING CONTROL FUNCTION
    The MIL is on with any of the following DTCs stored:
    P0011, P0014, P0021, P0024, P1110, P1135,
    NOTE: The engine may also have Camshaft Sprocket rattle noise and/or other engine noise THIS IS A VTC GEAR
    NOTE: The engine may also have Camshaft Sprocket rattle noise and/or other engine noise I started with the heatsheid it has been replaced three times im not saying everyone has my problem. but after three heat sheilds this is what they say mine is..i have filed! they say they have no fix at this time now they want to give me what my car is worth now its not my fault they have a defect and cant fix it what if i said i didnt have my payment what would they dooooo. i bought my car in jackson tn.they do not want to work with you to settle the problem. and if they do i loose several thousand dollars.for something that is there fault not mine.
  • Well, it has been two weeks since the dealer replaced a wire meshed washer on the heat shields and so far there is no noise. I hope that this is the fix. I will check back in two weeks or sooner if the rattle comes back.
  • 2007 Altima 2.5 owners were sent a letter by Nissan North America this week. It discussed the "rattle noise around the exhaust manifold heat shield." Paraphrasing the letter; Nissan is investigating the reports and determining the cause as well as an effective remedy. Owners are to be contacted within the next 60 days with information concerning the final resolution of this problem.
    Questions or concerns are to be directed to a Nissan rep at 1.800.647.7261.
    With new heat shields installed on our 2.5 a few weeks ago, the rattle has not returned. Hopefully that was the solution.
  • It has been about 1 month and the rattle has not returned, so I hope the dealer has found a solution.
    It has been six weeks (14 Nov) since the dealership worked on the heat shields to eliminate the rattle problem. They used parts shipped in by Nissan. In the last week the rattle has returned. Despite the letter sent by Nissan to Altima 2.5 owners saying they were aware of the problem and working on a solution, I plan to call as far up the chain as I can to speak with someone about my dissatisfaction with Nissan's response to the problem.
    Sure the car will run with the noise, but who in their right mind would accept it? How is everyone else doing with their rattle and/or fix by their dealership?
  • Well it has been 6 weeks since they replaced the wire meshed washer and the rattle has still not returned. I hoping that they found a fix, but I think based on you are saying that the rattle will return soon. I too will call corporate if this happens.
  • I never received this letter and I have been having this problem and the dealership cannot fix it or do anything. I'm calling Nissan's number - thanks for the info. - I am so upset with the service and this car. I am at 36,000.
  • I have bought my Altima coupe 2.5s on 06/21/07 in Staten Island and I also had engine rattling problem and got it fixed. I have questions for you guys and I will really appreciate it if you guys can reply to my message. Does anyone feel vibrating when you are driving or car is stopped? My engine sound is not smooth rather it sounds like an old car(I really can't describe it) when car is cold and sometimes when car is warm. anyone sharing same problem? I am going back to dealer to fix my brakes again (squealing problem). I am sick of going back to nissan. My nissan dealer experience was terrible and car is terrible. I will never purchase or recommand nissan to anyone in my life.
«134
Nissan Altima Engine Rattle — Car Forums at Edmunds.com
