Honda Odyssey 2000 Rear temperature control
jbaum86jbaum86 Posts: 15
edited April 2014 in Honda
It seems the rear temperature control on the fron tdash has stopped working. The dial just spins on the both hot and cold side. If I get it just right, the AC goes on high. Otherwise it doesn't work at all.
How hard is it to replace myself?
  • kominskykominsky Posts: 850
    It's hard to tell from your description if it's the same or not, but we had a similar problem with my wife's Ody. The plastic cutout inside the knob cracked and it would typically just spin around without actually changing the setting. Popped the old knob off, stuck on a new one and the problem was gone. Took about 2 minutes. The knob cost ~$10 (I think) at the dealership.
  • sorry. I checked the knob is fine. I think it is the control unit, I'm just how hard it is to replace.
  • jbaum86jbaum86 Posts: 15
    Turned out it was the knob after all.
Honda Odyssey 2000 Rear temperature control - Car Forums at Edmunds.com
