Lexus ES Basic Maintenance Questions
Can anyone explain how to reset warning lights on the dashboard of the Lexus 350 ES once an oil change is completed, so that the message "required oil maintenance" is no longer displayed, and so that the exclamation point in a red triangle is no longer visible.
I was able to get a more complicated way of resetting the warning light for required oil maintenance from the dealer. If the method on page 287 doesn't work, contact me at assetcorp@yahoo.com Put warning light in the subject line.
Dan Harrison
The drive belt is slipping..??
Thanks for your comments.
Just that the belt is the most likely of MANY possibilities. Second would be the A/C compressor clutch itself.
Here's why: I have a 98 Toyota Camry, and Consumer Reports printed an article that described sludge buildup in Toyota engines, even with regular oil changes. So, after having the engine fully cleaned (which Toyota paid for, even at a non-dealer!) the technician recommended a switch to synthetic oil. I did this around 100,000 miles, and that car now has 140,000 and runs great. So, I'll apply that lesson to my other car, an ES 350.
Dan H
GHG
DH
The cylinder head covers on the ES350 serve two purposes: 1) The cover actually reduces certain engine vibrations from entering the cabin 2) cosmetically cleans up the engine bay
You may remove the cover and not experience an increase in cabin vibrations. All you have to do in order to remove the cover is to remove the one bolt that holds the cover onto the cylinder head (see ref #90480 in the engine cover diagram) and the cover should pop off.
Yes, those little clips that hold them in place are annoying--if you drop one, it's lost forever in the lower engine compartment. You can buy them at Lexus or Toyota dealers for about $1.25 each. One of these days I'm going to remove that lower engine compartment shield/panel just to see how much junk has accumulated there.
