Mazda CX-9 Problems
sbahrsbahr Posts: 2
I purchased the Mazda CX-9 in May 2007. Since purchasing the vehicle I have had to take the car into the dealership 8 times. It all stated with carpet/foam square missing from driver side. The carpet was ripped and a square piece of foam was missing. Thankfully, it was replaced. Although, the first time it was installed wrong. I had to take it back a few weeks later when the carpet started creeping out the sides. In addition, I have had the front door checkers recalled, my right passenger door lock was intermittent, check fuel light has come on, a tire rim was dis-colored and thankfully replaced. Currently, the car is at the dealership because a rock hit my AC condenser and my AC is no longer working. It's not a manufacturer problem, but could this be a design flaw? I do not recall a rock hitting my car to cause such damage. The dollar amount is approx $1100 to fix. At this point, I am frustrated that my "new" car has had so many issues. I love the car - it looks sharp, its has a lot of cool bells and whistles, and it drives like a dream. My kids love it, too. I would like to know if there are other frustrated CX-9 drivers out there? Any opinions? Should I upgrade to the 2008? Wait for 2009?
«13456719
  • cericceric Posts: 1,092
    I have '08 GT AWD.
    I think you should give it a chance. The AC was just bad luck. Recalls and poor workmanship can be explained by being the 1st year models. For that matter, my Prius had two recalls during its 1st year, and Prius is one of the most reliable on market today (check consumerReport).
    Anyway, good luck with your '07.
  • erik_herik_h Posts: 77
    Many of the cross overs have the issue with the AC. There are quite a few Lexus and Toyota owners which had a rock take out their AC. I think they are more prone to it due to the higher ground clearance and lack of skid plates. Its bad luck more than design, kind of like a rock taking out your headlight.
  • This is good to know. My Miata's AC was also exposed to potential rock damage so I installed an aftermarket grill. It's basically just some wire mesh. I may see about doing something like this on my CX-9...
  • Purchased my car in July 2007.
    Dec 2007 a grinding noise started under the hood.
    Dealer replaced front end differential - no change.
    Dealer said "had to blow out carbons from the engine" BS - no change.
    February 2008 replaced entire engine - 2 weeks later same noise reoccured.
    Any help?
  • c_rexc_rex Posts: 14
    Could it be the transmission?
  • k1200k1200 Posts: 40
    I purchased my CX 9 new last year... 2007
    All seemed ok but now .....
    When I turn it off, the interior fan comes on full blast and runs for up to 5 minutes... the dealer gave me a L O N G song and dance about how this is supposed to happen to equal the air temp... I told him to then please explain why is it when the engine is off and I turn on the parking lights the fan comes on, or when I push the key remote and the alarm chips 2 x as it supposed to do .... and the fan comes on 2 x also
    also....
    Why does the car creak like a old dump truck.... it sounds like a 40 ton truck with rusty leaf springs... to give you a better idea... those old yellow school buses at low speed on a bumpy road... everybody knows that sound...
    C'mon Mazda fix the issues
    At this rate I will NEVER by another one of these cars or recommend them !
  • maltbmaltb Posts: 3,572
    "...when I push the key remote and the alarm chips 2 x as it supposed to do..."
    Interesting feature. Is this the horn or the chirp of an aftermarket alarm? Based on the fan coming on, it sounds like some wires are crossed. If the dealer put in an aftermarket alarm system, they should be stepping up to fix it.
    It was installed after mkt by dlr, but this issue did not arise until fairly recently. I spoke with the dlr today and they said there is a "campaign" regarding this and they will correct it . I have an appt in a week, The svc mgr. said this is a known issue.I will keep you posted
  • i have CX-9 2008. at the very first day i had an issue, the car pulls left in highway.
    i find the ibformation about TSB in this forum and inform dealer, after that they able to fix it. the frustrating thing is they don't even know that there is a TSB about this and trying to explain customer somethign else. thanks edmunds forum.
    now i have new issue, i have 20000km on it and rear two tires loose all treads (external side loose more than internal side and rear left tire loose more than rear right tire).
    i go to dealer and they say tire wire is not under warrenty. but it is something wrong in the car that causing this issue on rear tires. but they trying to say it because of driving... or something else. they will give some discount on tire. they suggest me to buy two Pirelli (i think they get commission).
    do you have any idea what causing this issue and how to fix it, because changing tire is not the solution, need to fix the issue. and how to deal with dealer.
    i see lots of people write lots of good thing about this suv. i agree the handling, transmission and acceleration works good for me till now, but if you any other good suv you will find that these are common, not very special. i don't think it is a very reliable car, atleast lots of maintenance. if you compare it some other good suv like MDX, it is 8000 to 10000 doller cheaper, but the quality and reliability is much more less than MDX.
    i won't never buy it again.
  • jchappeljchappel Posts: 16
    Sorry to hear you are having problems. What brand of tire is on your vehicle? If their is a problem with the vehilce, it's a warranty item, and if that problem caused a premeture tire failure, I would demand a prorated discount on the new ones, not just a discount. If they fail to act, see if they have a Mazda representative you can talk to.
    As for the cause, do you have AWD?
    Another option for you would be to go to a specialty tire store (one that stocks your brand) and ask them why you are having the problems, and see what they tell you. If those results vary from your dealer's, take the report to them. If they fail to act I would be calling Mazda.
  • thanks for the information.
    my one is AWD. i went to another Mazda dealer, they say it is because of alignment. they say after the fix (for pulling left) i got a new alignment but my dealer didn't rotate the tire. so rear tires remain in the same position (angular or something) as before and that causes the damage, i don't know what is true or false.
    i need to know the real reason to fix it. and the dealers are just trying to avoid any issue. do you think wheel balancing can be a cause?
    Do you have cupping in the tread? That could indicate a balance problem. I would agree with the diagnosis that they gave you on the alignment. Now, what are they going to do about your tires since it was a vehicle problem that led to the tire failure? I know I'd be hitting them up for 2 new tires.
  • nxs138nxs138 Posts: 481
    I made a similar issue in my Audi, i.e. it pulled to one side. The dealer "fixed" the issue with an alignment that wasn't really an alignment--they basically overcompensated with one tire, if I recall, to make the car go straight. So that tire got used up much faster than the others. As it happens, the fix was to go to another dealer who had to do something with subframe alignment, but I don't know too many details. So it's entirely possible that your first dealer didn't follow the TSB procedures properly...
    For my Audi, which is AWD, I do have to rotate tires every 5000 miles, else I do see premature wear. Have you ever rotated your tires? Our CX-9 is too new to have a rotation yet, so I can't comment on tire wear quite yet
  • thanks all of you for all the information.
    but i needed to buy two tires $210, they put two new tires infornt and two tires from front to back.
    i don't know how long these two last, i remain scared... when i will see the next tire wire or another new problem... i don't want to waste more money on it... whats the point having a new car
    if i sell it how much i will loose?
    Started my CX9, put it in drive and now I hear click,click.click as I accelerate. As I drive it sounds like circuit breakers tripping same in reverse too. My neighbor is a mechanic and just listened to it and said "transmission" So back to the shop with it. And FYI this time I will take my digital camera and take pics of my vehicle before I leave it. The last time I wound up with a dent and a scratch that looks as if someone walked between my car and another with a tool belt on and scratched it .
    I will never by one of these again, I will go back to BMW for a X6
    I am really sick of this CX9 and all the B.S. that is associated with it.
    Let me know in which tire they find the rock.
  • I know this may sound really dumb but have your mazda dealer check the front windsheild cowl.
    Mine was making a horrible noise as well and it took them a new engine to figure it out.
    good luck!
    sure would have been nice if it were a rock...but it was not.
    after having my vehicle all day , they called me and said "we cant find anything" as I suspected, so I went back over to them and started it up put it in drive , moved forward and there it was "click,click,click"..... he said to me oh I heard that but that was more like (clunk, clunk ,clunk) Hmmmmm thats when I had an epiphany, they are not from this planet... So getting back to it, they took off one of the front wheels and entire housing for the brakes was literally being held together by one small screw. and that was what the noise was as it bounced around making contact with the rotor
    I was told never to say what next...
    Fix it trade it
  • We have a 2008 cx9 and twice now (my wife has told me) all the windows, including the sunroof, have openned up on their own. Tonight she thought I was playong a joke. No joke here. Is this a common problem?
    It seems to me some wirings in your CX9 have crossed. Did you have some accessories installed? Check the installation wiring. I have personally seen a Volve did something like that with my own eyes.
    I have not installed any other items to my vehicle, on occasion my drivers side window will open about 2 inches, when I hit the button to close it , it will close then immediately open all the way.... several times.... i sometimes have to pull over push the button and just about when i think its at the top i have to turn the vehicle off to stop it right there. When I restart it stays put and then I can use it as normal.
    And I mentioned somewhere in this forum that my drivers seat will inch up in small increments. And I would not have thought it was true until I left my video camera running inside the vehicle just to see what was going on.
    have that keyfob checked out, you know if you press and hold the unlock button for more than 3 seconds it will open the windows and sunroof also.... it could be sticking, hopefully thats all it is
    I wouldn't trust any aftermarket (and some factory) alarm systems. As vehicles get more and more complex, the electronics become more sensitive. You must be taking your car back to the same dealer that installed the system because any other dealer wouldn't touch it until the system was gone.
  • I tried holding down the button, however nothing happened. Called our dealership, they said they will fix problem. However, they will need to keep the car beyond a day. Bummer, but that's the way it goes, I guess.
    k1200,
    You know that some of the so called "factory accessories" were actually installed at the port by workers who might not have been properly trained. Maybe one of the installation went bad and messed up the electric system of the CX9. Do you have accessories that relates to electric system like auto-dimming mirror, Sirrus Radio, Remote Start, etc?
    If I were you, I would list all issues, and have them debug them all and have a loaner while they are doing that. If they cannot fix them all after three trips, you can cite Lemon Law on it and demand a new CX9 (or money back).
    Good Luck.
    I know what you mean , but I did not have anything like that installed, its just the basic touring package. So let me update you on what happened today.... went to pick up the vehicle... had the wife in tow as my witness , paid for everything, started it up pulled off and at 30 mph a very bad vibrating started as if the bearings were removed or as if the wheels lugs were not tight, when I made the u turn there was that clicking noise again. I drove it right back into their shop and demanded that they fix it or be prepared to replace it... this is B.S. and I know I dont have to put up with it. I said to the guy " c'mon you are a mechanic, fix it, if you cant just say you dont know how"
    I told the mgr. that once this car or (if) this car is up and running I will get rid of it.
    Oh I cant wait until they send me that "how did we do survey" I see some unemployed mechanics in the near future
    So here it is once again... the mysterious electrical issues. Vehicle runs fine, park it turn it off and the interior fan comes on full blast usually runs for about 2 minutes then shuts off(not normal) Two days ago it did not shut off and it ran until the battery flat lined on me. The dealer told me he had never heard of this when it happened the last 2 times "they could not replicate the issue" since it can happen intermittently. But this time I drove it straight to them and literally pulled the gut outside and told him "go ahead turn it off" Which he did followed by "oh my, I have seen this before" Now keep in mind he just said he never heard of such an issue and even went on to say I know what part you need and this and that .bla bla bla..
    My wife stood there with me and stared at him in disbelief and out of the blue just said to the guy "you're a dick". And what a coincidence I just got one of those JD Powell surveys about the car and the dealership. I will not hold back on what im going to say.. But I will say this.... I will never buy another Mazda ever, I will be looking at BMW, Infinity, Lexus. Not because I want an expensive car (i dont) but when I owned my BMW they fixed it right the first time , and always treated you like a human.
  • I have had the same thing happen to me.
    It is hard to know when it will happen but it does.
    I have not take it in yet but I will at the next check up date.
    Keep me posted
  • aviboy97aviboy97 Posts: 3,159
    I'm sorry to hear you have been having this issue. You should try servicing your car with another dealer. Remember, the way a dealer does business is not always a reflection on the auto manufacturer.
    Since you brought up being treated like a human being, your wife in no way treated the service guy like a human being. I hope they refuse to service you from now on.
    Of course I know that the service is not a reflection of manufacturer, and I do have another dealer that I use now.
    But as far as how the "guy was treated" give me a break, you needed to see the line of people and listen to the B.S. song and dance he gave to each customer. If you cannot handle the work load then they should get more staff, if they cannot fix an issue then BE HONEST and state it. Most people respect a person that will give them straight talk. Theres nothing like leaving your car with your trusted dealer on Friday , call the back on the following Thursday and you get "you know I been meaning to call you".Believe me the service guy got off lightly. Going by your resentful, over protective feelings ... are you a service rep. ?
«13456719
Mazda CX-9 Problems — Car Forums at Edmunds.com
