thanks for any tips.
bajaranger
Any help would be much appreciated. I've read some similar posts in here, but haven't seen many followups by folks stepping up to answer. Hope this time it's different. I'd love nothing more than to prove that this forum really works!!
Thanks much, in advance.
LP
Thanks again.
Good Luck
While I have operated this car for 66,000 miles, I have had my share of driveability problems that were experienced my many other owners, such as the surging and engine stalling at low speeds or at idle, but these problems were corrected by a local dealer after a few trips when they adjusted the computer.
My wife also used to complain about driving or riding in the car, since she used to say how "jerky" the car operated (which was never corrected by the dealer), but she now seems to love how it operates now after I had the trans fluid (and filter) replaced with a complete ATF Synthetic Fluid from AMSOIL. It seems that the shifts are much smoother now. I should also point out that that I had been using Mobil1 5 W 30 for most of the oil changes during the time it was a company car, but I saw a noticeable increase in performance from changing the oil last week to AMSOIL 5 W 30 (full synthetic) along with their full synthetic oil filter (this was done before the trans fluid change).
Anyone have same problem and maybe a solution?
I have a 1998 Dodge Stratus and last night as I was to take my leave from work, I go to get into my car and upon turning the key into the ignition, the engine didn't turn over. Now I've had this problem before where I would have to crank for a few moments before the car would start. However last night the engine didn't turn on -- I cranked one more time and the engine revved only to shut off just about 1 second later.
When the engine shut off, it took my cd player, the buttons for heat and a/c, turning signals, windshield wipers, and locks out with it... However my interior lights, my headlights, and my windows still work fine.
I consulted a garage, and they told me it's probably a faulty battery (but i would assume nothing electrical would work then..) but I've seen elsewhere it could be anything from an ignition switch, to the starter/cellenoid to the distributor. Anybody else have this exact problem?
Any advice is appreciated! It's cold and the walk to work sucks, and with snow in the forecast I would like my car back..
Gary
Car has only 22,000 miles on it. Original owner. Any ideas other than take to dealer and check codes?
After trying to boost the car and much searching I find the 20 amp ignition fuse blown in the engine fuse box.
A couple days later the same thing. Put 4 new fuses in an 4 times the fuse blows. I get the car towed to my mechanic
and he finds nothing wrong after 2 days of restarting the car over and over again. Not once did the fuse blow for him. A few days later the same thing the fuse blow so I install another fuse but the car wont start. I leave the
car along for the day the next morning it starts no problem.
Any help would be great. My patience are run very short.
I haven't had a problem yet and its been 2 months but will keep you posted if you want.
richard :mad:
I checked her oil and added 2 quarts. She could be losing oil somewhere because she just had it serviced a month ago. But I don't see any on the ground where she parks, so that is a question mark.
Anyway, I started her car and listened to it. It sounded like it might be idling a little rough, but not too bad. So I took it out for a short drive. I didn't notice the "tapping" but the check engine light was on. After I had driven at slow speed for a little while, I got it up to about 50. As I was coming back home after having gone about a half mile, the check engine light started blinking and continued to do so for the last quarter mile until I got home.
I know I need to get it to a mechanic to have it put on the diagnostic computer, but I'm not sure if I should drive it at all with the light blinking. That could be indicative of something pretty serious couldn't it?
any ideas
Write me back @johnpaul4223@hotmail.com. I have the whole printout if you want it. It cost me a little bit , but I'll be happy to share it. Later.
Identifix Reliability Ratings
Category: Comments: Rating:
Engine An occasional problem on this vehicle is the failure of the Timing Chain and Guides (2.7L engine only). Failure of the Timing Chain and Guides may prevent the vehicle from starting. The cost to repair the Timing Chain and Guides is estimated at $537.80 for parts and $292.50 for labor. All prices are estimates based on $65 per flat rate hour and do not include diagnostic time or any applicable sales tax.
Transmission & Driveline Occasional problems on this vehicle are failures of the Transmission Turbine Speed Sensor and the Output Shaft Speed Sensor. The cost to replace either of the Speed Sensors is estimated at $25.60 for parts and $32.50 for labor. All prices are estimates based on $65 per flat rate hour and do not include diagnostic time or any applicable sales tax.
Steering & Suspension Infrequent problems reported, all with low repair costs
Brakes Infrequent problems reported, all with low repair costs
Heating & Air Conditioning An occasional problem on this vehicle is the failure of the Blower Motor Resistor, 4 door sedan only. Failure of the Blower Motor Resistor may cause the fan to run only on high speed. The cost to repair the Blower Motor Resistor is estimated at $14.75 for parts and $32.50 for labor. All prices are estimates based on $65 per flat rate hour and do not include diagnostic time or any applicable sales tax.
Starting & Charging Infrequent problems reported, all with low repair costs
Accessories Infrequent problems reported, all with low repair costs
This 2001 DODGE STRATUS reliability information was provided by Identifix. Identifix is the nation's largest technical support service for the aftermarket auto repair industry. CARFAX does not review or correct the information provided by Identifix.
Back to top
Anyone has that strange case when a car has a mind of it's own or something like that?? :confuse:
however the previous owner of the car broke the driver's seat on the right side. When I go to sit in the vehicle I often lean slightly to the right, making a drive uncomfortable. I am looking to change this..
Should I go to a dealer and get stratus seat placed in, or should i consider aftermarket seats - if so, what are the best and best priced aftermarket seats available?
