Oldsmobile Silhouette
1373839404143»
  • I have my van for over 5 years, and was happy with, but about a month ago the car started stalling. the problem is intermitent, and some times I for several days without problems, then it starts again. lately the it is stalling more frequently. I have taken the car to the mechanic several times and they cannot diagnose the problem because the car does not stall while it is there, however as soon as I pick up the car and drive for about a mile os the car stalls again. I took the car to Chrisswell Chevrolet Dealer they could not find the problem either, but suggested that the problem might be the fuel pump, and as soon as I left the car lot and drove about a mile and half the car stalled again. I had it towed to the mechanic to replace the fuel pump. Cost me about $700 bucks, and did not solve the problem. anyone has any idea as to what might be the problem?
  • jmineerjmineer Posts: 3
    edited January 2011
    There is a great product that I can recommend to you. It is a scanner tool that you plug into the van and into a laptop. You can monitor, troubleshoot, and control many things about the van. It'll tell you what's wrong with it. I personally have it and it really works. You can do this from the driver's seat and even drive it while running the diagnostics.
    http://www.amazon.com/Crescent-OBD2-Multi-Protocol-Diagnostic-Scanner/dp/B001MT0- - XPK/ref=pd_sim_e_2
  • bob550kbob550k Posts: 148
    Our 99 has had a stalling problem a couple of times. Each time it was a bad idler pully or a tensioner pully. They get stiff and cause the car to stall at very low speed or idle. Super cheap to fix.
  • I had the some problem with a 2000. Mine was loose wiring at a junction under the sliding door on the drivers side. It was effecting the fuel pump.
  • car-part.com
    I FOUND THE 3RD ROW BENCH SEAT FROM THIS WEBSITE IT WILL TELL YOU ALL OF THE PLACES THAT HAVE IT NEAR YOU AND AWAY FROM YOU.
    I WAS LUCKY MY SEAT WAS 2 MILES AWAY AFTER 2 WEEKS OF NON STOP LOOKING . SOME ONE IN ANOTHER FORUM GAVE ME THIS SITE AND IT WAS MAGIC. AND BY THE WAY VENTURES,AND MONTANA'S ARE INTERCHANGEABLE WITH THE SILHOUETTE'S . GOOD LUCK
    edited April 2011
    We just let the 99 Silhouette Premiere go after nearly 10 years of ownership. This was a good car, it held up great, still looked and drove excellent (no fading, no dents, no rust, no tears, low cost for repairs, a little maintenance until 122,000 miles that's when the transmission gave it up, that cost plenty but after just normal repairs I just couldn't complain... Until about 500 miles later the head gaskets gave up at 122,800... Again, this car was cheap to run and so durable that I kept it for nearly 10 years, so doing some repairs at the end was fine in my book.
    When I first bought the car someone posted how I would get beaten down on resale because I should have bought an Odyssey. I would love to hear the final comparo from him. I paid $18,000 for the car (I never even put rear brake shoes on this thing), ran it from 22,000 miles to nearly 129,000 miles. Sold it to the first person that waived green at me for $2,800. I realize I could have gotten more, but I'm more than happy for that young family that got that immaculate, garage kept car so cheap.
    I really wonder how much better I would have done had I sprung the extra $8,000 - $10,000 for a similar used Ody after 10 years.... :)
  • Got my olds about 5 years ago. Check Engine problems off and on until about 3 years ago this past spring I had a new Jasper engine put in. A few months later I had the trans "rebuild" done which I'm still not sure they really did. Ran fine till last fall. Started the engine light then one merry day started to over heat. Well I stopped the car pulled over and had it moved. Dead engine. Not even that many miles on it. Found out it was still under Jaspers warranty and took it over Feb this year. After many long delays (one man shop blah blah excuse blah) I just got it back tonite. Started up great! Then... not 2 miles later the check engine light came on. Got gas in it (had a 3/4 tank but thats old gas from last fall now added startron too) but with all that on start up it makes a horrible noise. Engine runs smooth. We're thinking possibly the transmission now! Again! Well that fix is long out of warranty and the engine fix was covered by jasper or it would still be parked. Any thoughts? Suggestions? I'm thinking shed at this point? Lol Its the deluxe model leather/power/vhs player etc... THe engine alone is worth 2k I'd hate it kill another engine for the sake of saving the van but if its a simple fix.">link title
    It doesn't sound like an engine problem. Obviously the shop didn't find a problem with the engine. Like always, the problem comes back after your driving. If the Check Engine likght is coming on, then its obvious that a code is being sotred. Possibly a sensor or something is going bad and that can cause major trouble with this vehicle. I bought a cable box to hook up to the silhouette and the USB on my laptop. I can check codes with the van on or off. This is what you need to have hooked up while the van is running. I paid $50 for it on Amazon. Its a must have item for this lemon. Not a very good van at all. The transmissions is these things are junk.
  • 2001 oldsmobile silhoeete 3.4L engine.how can i rethread the spark plug w/o removing the head on the back side of engine.
  • Simple disconnect the front 2 stabilizer mounts, rock the vehicle when the engine is far enough from the fire wall ( have somebody in the vehicle so they can step on the E brake to stop the movement) and you will be able to access the rear a lot easier. Also remove alternator it will be easier in this position.
    Good luck
  • Is your engine light on if yes is it giving you any engine codes, also check your mass airflow sensor
  • jrdwyerjrdwyer Posts: 168
    Our temp. gauge recently went into the red zone when my wife was parked with our 2001 Olds Silhouette running at a convenience store during this hot summer weather. When she got the van safely home after letting it cool down, I ran it in idle and quickly realized that neither of the electric cooling fans were operating, even with the A/C on. Bad news.
    So I get out my Haynes manual and start troubleshooting. The wiring harnesses to the fans are fine. The 3 relays are all tested and are good. Fuses to the fans are good. I ran a grounded 12 volt from a trickle charger to the individual fans at the harness and they both turned on, so the fans themselves are good. I decided to take it to a trusted local auto A/C shop to see if it was related to the compressor.
    The A/C shop said all A/C components were good, but they could not fix it because it was beyond their scope of expertise and charged us $50 for the diagnostic time.
    Not having much electrical background, I then take the van to a certified independent mechanics shop (that I have used before) and have the auto electrical "expert" look at it. He comes back with an opinion that the fuse block is bad and it should be replaced with another one. He states that he can only get used ones for $200-$250 from salvage yards, so no guarantee with the part. His estimate to get another fuse block, replace ours, and maybe fix the problem is $500-$600. I pass and pay him $150 for the "extensive" diagnostic time they spent on our van.
    At this point I decide that I'm going to learn about electrical circuits and dive into the wiring diagrams in the Haynes manual and also do a thorough web search on this issue. I quickly come to a second wiring diagram for these fans that appears to be from either a GM service manual or another DIY source. Here is that diagram (thanks to the author for this effort):
    http://www.my-chevy-venture.com/engine-cooling-system.html
    I realize that I can take apart the fuse block. The bottom three modules are held to the top of the block with screws. I unscrew the module containing the grey and light blue fan electrical wires and I find both the female and male metal electrical connectors are black and the female ends are not likely to make good contact based on their slightly distorted shape . So I go to a local salvage yard/pull-apart and find a similar van and then cut out two good female electrical clips with 5"-6" of wire attached. The trick to getting these connectors out is to remove the secondary light blue slide-in plastic clip first and then use a very small (eyeglass repair) flat screwdriver to push the primary spring down that holds the female connectors in the plastic bay.
    I get home and remove/cut out the two bad female connectors from the module, clean the male contacts, insert the two new female connectors into the module, and butt splice the new connectors to the corresponding wires coming from the fans. Then I screw the module back into the fuse block, start the van, and the fans are RUNNING AGAIN with the A/C turned on. Hooray!
    I'm not sure why there was a short/poor connection to cause this problem. Maybe one or two bad connectors from the factory? Maybe too much amperage on this type of connector/bad design? Maybe something internal in the fuse block? It did take 11 years for the connection to finally fail. From an internet search, there seems to be a fair number or people who cannot solve this problem and have to hard wire the fans directly from the battery to get them to run. I was also prepared to fix it in that manner.
    So after the initial run around with mechanics who were not close to being experts, we spent a total of $3 for two used wiring connectors, some new butt splice connectors, and some electrical tape to fix our van. Most importantly, I learned quite a bit about vehicle electrical diagnosis and repair. Hope this info helps someone out there.
  • shopdog97shopdog97 Posts: 160
    I did this on my friend's '99 to get more access to the O2 sensor about 2 years ago. Just another FYI.
    My friend has a '99 Silhouette Premier with the self-leveling rear shocks that are just about shot. They are leaking and they are not going to last long. The van has over 206K on it and has had both the engine and transmission replaced over the years and last year the head gaskets were replaced too, so while it runs very well now, it hasn't been without its issues. My question is this: My friend is not going to spend nearly $500 dollars to replace the self leveling shocks when they finally go altogether. Can we go to an auto parts store and purchase normal shocks for this make and model with the hope that they'll act like regular shocks and won't cause a significant handling issue? In other words, will REGULAR replacement shocks work with this van? My local Auto Zone store told me that while he has these shocks in stock for a NON self leveling model, he told me to check with our local GM dealer to be sure. A Chevy dealer will do because this van is the same as the Venture and Pontiac Montana.
    Also, the temp gauge is not working the way it should and neither is the fuel gauge. My friend claims that there is a problem with the instrument cluster on that side(right side). Now the tach and speedometer and other things are fine, and I'm wondering if the fuel sending unit in the gas tank may be at fault. The temp gauge goes down to 0 when the van is shut off and when you start it, it seems to come up to temp normally, but then creeps up to just below the red marks, but this causes no problems and the cooling fans seem to work normally. My friend says he was told he'd need to replace the instrument cluster at a fairly good price to solve these problems and he's not going to do this, so he'll have to live with it. The gas gauge is what really bugs me. It just seems to go all over the place, one time it might be right at the full mark, and then it's at half or below. He's got a wacky formula that he uses so that he or his wife don't run out of gas. They multiply the number of gallons they buy by 18 and reset the trip meter and when they get near what they call the "magic" number, they get more gas(LOL)
    Sorry to be so long winded, but if any of you have any suggestions especially whether we can replace those auto shocks with regular ones, please let me know and thanks very much.
    I guess I'm answering my own post here, but today at a local NAPA auto parts store I stopped into for a different issue told me that they have a replacement OEM self leveling shock set for about $100 bucks. The guy couldn't say whether I could replace them with regular shocks, but I'm going to inform this van's owner about this and see where he wants to go with it.
  • I am having the same problem with my 2001 Olds Silhouette. Just like yours, relays, fuses and fans all work. The junction fuse block seems to me what I should look at. Thanks for all the info.
    Greg
    Glad I could help. Post back with your results when fixed.
    One thing that I didn't mention is the bottom of the fuse block should have a black plastic cover/splash guard that snaps into place. Ours was missing and I'm not sure when it was removed or if it was ever on the van from the dealer, where we bought it new. I got another one at the junk yard.
    Our van had over $4K in dealer performed GM warranty repairs in the first 5 years (extended warranty came with all new Olds vehicles in mid to late '01). We will run this van for another 10 years, assuming that the head gasket and tranny don't fail. I might even tackle the head gasket myself.
    We do like the van for its size, interior space, and ride, but it's very high maintenance! So much potential existed for improving upon this great basic design (large inside-small footprint outside- lighter than competitors- fuel efficient), but alas, GM just gave up and moved on to SUVs.
  • bonebrakebonebrake Posts: 1
    edited November 2012
    My CC was working friday, now monday it doesn't. I noticed all the posts about the brake light issue so I ran out and bought brake lights. Put them in and they still don't work and neither does the CC. Any Ideas? (mechanically challenged)
    2003 olds silhouette
  • i have a 2000 oldsmoblie silhouette and i have a wobble at low speeds and also a roaring noise coming from the front end. i replaced the cv joint on the right side last night and thought that was the problem becuase the cv joint was throwing grease but the same thing is going on this morning. can some one help?
  • I have an Oldsmobile Silhouette '03. Been doing assorted jobs (previous owner busted out the rear window with a hammer, busted the taillight out with the hammer, used a corrosive chemical on the headlight causing a small hole, replaced the radiator and cooling system since they used the wrong anti-freeze, and so on) to bring it back to being a decent, legal vehicle, but...
    A couple of months ago, I suddenly lost the 5th fan setting on the A/C dual climate control. When it's on 0, it runs as if it's on 1. I've replaced the climate control (not exactly cheap), but it didn't resolve the issue. Both climate controls were checked and are working properly, so I'm a little lost. Not particularly my strong point.
    Any idea what it could be? What's the next step?
    I'd appreciate any input anyone could offer. Thanks in advance!
  • I have a 2002 olds silhouette . I am trying to find the heating module for the front seats .
  • mikejayemikejaye Posts: 1
    The driver's power seat on my 2003 Silhouette Premiere has quit working. Fuses are both good. What is my next step?
  • daveeedaveee Posts: 1
    rawah said:
    Folks,
    Does anyone have the specs for the OLDS Silhouette (1998) premium sound? OLDS dealer does not have access, Olds customer service is of no help - refered me to Delco. Delco will not provide to a retail customer.
    Any ideas? Cheers
    you can find some specs on the computer. Can you be more specific as to what kind of specs? tune up? liquids and fluids, Features? Rebuild specs ---- What?
Oldsmobile Silhouette - Page 43 — Car Forums at Edmunds.com
