Pontiac Bonneville
Yeah, that might be an explanation
Speaking of metric/imperial speed, I love using that E/M converter button to mess with my friends when they're with me. Usually the scenario is me driving through a notorious speed trap at about 45mph (limit is 55), tapping the button, yelling "check this out!", and flooring it for a few seconds.
Man, you would not believe their faces the first time I did it! Now its getting passe. I need to either think of a new gag or get some new friends.
If anyone is interested, check out the following link:
http://www.aeswave.com/otc/index.htm
Mike
Maybe someone will come out with a cable and software for a PC that doesn't require the hand-held tool. That would be cool.
I read about OBD-III in the July 2001 issue of GM High Tech Performance magazine. The government and manufacturers are tossing around the idea of broadcasting a diagnostic signal from the PCM to the feds as an alternative to emissions inspections. That leads to some scary privacy issues, but in the interim some inspection stations are starting to use a scan tool to download vehicle performance data instead of hooking up the tailpipe sniffer. The current OBD-II systems have this capability, so it is going to be more difficult to change the PCM settings without getting caught (although things like the DIC greeting or steering effort obviously don't count).
With only 6k miles on it, I don't want to replace two tires, so I'm looking for one. I get my dealer working for me and he tells me that the local goodyear rep initially couldn't even find this tire on his price sheets because it's OEM. Eventually found - price? $425 Cdn (=$275 US) incl. taxes. I'm getting it at cost (or about $180 US). And - it's going to take a good couple of days to get the tire I'm looking for up here.
The good news? The dealer's put me up in a 2001 Regal GS until my tire comes in. Now that car goes like stink!
I hit a rock in the road the first week I had my car; took the tire right off the rim. Had to get the tire and wheel replaced. Good thing for me was the tire size -- Eagle LS 225/60-16. My dealer had no trouble finding that size.
I've always thought 235/55-17 was an odd tire size. Not many tires available in that size. Reminds me of my 84 Trans Am -- 215/65-15. I think Eagle GTs were the only tire available in that size. It would make more sense to my anyway for OEMs to use more conventional tire sizes.
That Regal does scoot, doesn't it. Almost wish I had bought one. LeSabre has more room and the bucket seats are better. Too bad LeSabre doesn't have the L67.
Mike
They claim that you won't need to dry your car at all after using this stuff. I was a little skeptical about that, but let me tell you, there was hardly any water left on my car after I was done. It only took a few minutes with a terry cloth towel to get the rest of the water up.
Wash a section at a time and then rinse off with a stream of water (don't use any spray attachment). Once you have washed the whole car, rinse it all again with a stream of water. Wait a few minutes and most of the water is gone.
I've used a dozen different car washes before, including the stream of water trick to minimize beading water on the car. Nothing I have used works as well as Blue Corral. It also helps if your car has a good coat of carnuba on it.
Check it out. Should be available at most auto stores.
Mike
Ken
A friend of mine, who is a lot older than me, if that's possible, came by last night in the middle of his second childhood or at least adolescence. He was driving a 1968 Olds Cutlass that was a real sleeper with a factory 350-375hp 4-speed that he had just bought from the Volo Museum here in Illinois. He wanted to know if I wanted to drive it and of course, I said I most certainly would. We took it out in the country and I hammered it through the gears to the point where he was looking a little pale. While it was fun to drive a car like that, the comparison between it and the SSEi was pretty amazing to me. It probably was a bit quicker on acceleration due to the gearing but it felt like a lot of show for the amount of go. Also, at 70mph, it started to feel pretty light in the front end over the less than interstate quality roads. He said of all the people that he had let drive the car, I was the only one who had put it through its paces, including him. I offered to let him drive my car on the same road for him to get a feel for the difference that 32 years had made but I think he was still a little wobbly after watching his life flash in front of him.
Normally, when I drive to Maine, I stay on the U.S. side simply because it is more direct. Customarily, we take all of life's necessities including an ample supply of Gordon's Gin and Johnny Walker Scotch. So for this trip, I did as I always do and loaded enough for our "needs" and what we need to entertain when we are there. After everything was loaded, it dawned on me that this time, I had decided to stop in Toronto to visit with the people at the Toronto distillery who I had worked with the last several years. Nothing wrong with that except that with the huge differential in taxes on liquor between the two countries and the resultant tremendous problem of smuggling, I realized I had loaded far more than you are allowed across the border. So back out came most everything I had packed so I could get to the booze box. Hopefully, I guessed correctly about how much you can legally take into Canada since I have no desire to be the poster boy of the Customs people in the war on smuggling. Dan, I'll be crossing back into the U.S. at Thousand Islands which isn't too far from you. It would have been fun to see your car and meet you but aside from having to get to Maine to get building permits, I also didn't think you would have been similarly eager to see a 1988 Caravan loaded to the gills.
The Bonneville is resting snugly under my Camaro's car cover since neither is going anywhere fow a couple of months. I'll miss it but that should just make me appreciate it more when we get back to Illinois.
http://www.theregister.co.uk/content/archive/15393.html
Ken
On my way home from PA yesterday I became the Spruce Green filling in a Maple Red SE sandwich! Must have looked like a Pontiac Christmas Tree! I had these new Bonnevilles as travelling companions through northern Connecticut into Mass. A black prior generation SSE joined in the convoy for a while. It's funny - seems like last month I picked up 2 other new SE models in basically the same stretch.
Bonneville hunting has become one of my favorite drive time passtimes.
I wonder how many Mark will see on the way here from Chicago.
Ken
Stephen
http://www.treadepot.com
I have never used them (just used google.com to find them). But they list the tire for $125 US.
Cuzin Brucey
Check out the link:
http://www.clubgp.com/forum/topic.asp?TOPIC_ID=6358277&FORUM_ID=19&CAT_ID=1
I never did try these folks out yet. I've been too bogged down with heavy duty engine mods. I would say that somewhere around mid-summer I will rethink my position on not being able to go faster than 126 mph...
Scott
BTW, the RSA 235/55/17 actually lists for $357 Cdn. (about $230 US) in Goodyear catalogues up here but local Goodyear dealer explains that this is out of date and $370 is more like it. I am suspecting that, given that this is not a commonly stocked tire, that local supplies will not be abundant - nor will discounts.
I have bookmarked the tirerack and tiredepot sites because this experience has started me thinking about tire replacement. My mechanic informs me that 235/55/17 will NOT be an easy size to replace and that the RSA is a damned fine tire - particularly as an all-season high performance tire that works well in snow. Unless I want to get a 2nd set of Hakkepelitas for the winter (yuck!), I might not have much choice on the matter. However, he did say that he could probably put Michelin Pilots on for close to the same price.
According to my mechanic, other than the above 2, the only other tires available in 235/55/17: Bridgestone Turanza Z RevoMichelin Energy MXV4 PlusGoodyear Eagle LS.
I can say that I love the RSA's - very sticky and the built-up sidewalls let you throw the Bonnie into tight corners with confidence, zero squeal and no added roll (that's probably the 55 profile). I cannot compare ride comfort with another tire because the RSA's are all that I've had on this car.
Any recommendations or comments?
A couple of options. A 255/50-17 tire is about the same circumference as a 235/55-17. Seems like there is a bigger selection in that size. I'm not sure if a 255-series tire will fit on your rims or not. I think the Bonnie has 17x7.5 wheels. Another option is to move up to 18x8 wheels. Expensive, but then you could use 255/45-18 tires. I think intense01 has that setup.
Mike
Did you happen to be driving north on I-95 in the Georgetown to Newbury Mass area on Sunday afternoon somewhere around 3 p.m.? If not, I saw your car's twin as I headed south to PA. I remember thinking it was the first SSEi or SLE I had seen in that color - very nice by the way.
I'd love to see a Bonneville meet in our area too - maybe a Sunday afternoon sometime in late June? I'll help but can't do it all. How wide shall we open the invitation? Based on participation in NJ, I think it would be good to get a buy in from a few other car types to make it the most fun. I'd like to see Grand Prix, Impala, Regal, Aurora and Intrigue, and Cadillac join us - what are your thoughts?
Ken
Nice touch - my boss commented on it today.
Has anybody else done this - and lived to tell the tale?
BTW, spoke with my dealer today & thanked them for all their help with the tire. As we got talking, something didn't sound right to him and it turns out that I may have been over-charged by about $50 Cdn. (about $32-35 US) so I'll be getting a refund.
Surgenor Pontiac Buick GMC - best dealership in the Ottawa area (IMHO).
This was an unscheduled visit to the dealer but it was at the 6000 mile mark, so I had them change the oil (58% life left according to the DIC oil life monitor). Unfortunately, because it was unscheduled, I didn't bring any synthetic with me - we'll have to wait until the next one.
We're heading into our first warm-weather holiday weekend this weekend (Queen Victoria Day - rather quaint, 'tisn't it?) so I hope to make some headway on that "honey do" list.
Have a good one yourselves! Dan
Don't worry, I'll keep the car in second gear.
2.169 9.218 @ 76.94 14.242 @ 97.45
2.197 9.202 @ 77.82 14.230 @ 98.48
2.255 9.188 @ 78.26 14.163 @ 98.50
Scott
2000 SSEi
Stock: 15.800 @ 89.60
4/14/01: 14.555 @ 94.75 mph
5/19/01: 14.163 @ 98.50 mph
Ken
You are a true pioneer.
Keep up the good work, you are paving the way for the rest of us. As soon as my warranty is up I will be trying to keep up with you.
While SE owners are, on average, somewhat less generous in their scores than owners of SLE's and SSEi's, the gap between their appraisals and the others is less than 3%.
These numbers fare well against those of the '00 Toyota Avalon (8.8), BMW 3 series (8.6), BMW 5 series (8.8) and Acura TL (9.0). Where the Bonnie falls short of these others? The interior. We give ours an 8.4 whereas the others attract 9.2, 9.0, 8.9, and 8.6. Does this give you any ideas about where Pontiac should focus future improvements?
Although the sample size is small (116 cars for the Bonneville) and unscientific, it's probably every bit as good as what Consumer Reports uses.
Does everyone follow the suggested schedule for rotating tires?
By the way, I forgot to mention how fun it was to run 14.16 while at least three newer Mustangs (two slightly modified GTs and one stock Cobra) were all running 14.30 to 14.70...
My everyday tire/wheel combination is 18 x 8 Konig Villains with P255/45ZR18 tires. For the track, I put some 17 x 8 Konig Villains with P275/40R17 Nitto Drag Radials on the front. They don't make much difference right now because I don't have much of a traction issue off the line (yet).
Scott
Mr. LeSabre
KZM
I'm fascinated by the fact that Scott can achieve those times with front wheel drive and without any form of positraction. How do the pocket rocket/rice burners do it since when I've seen them on television, they are spinning both tires up front? Scott, what are your shift points set at?
Ken, how can I contact you about delivering the stabilizer bar?
Mark
The Stage II and RAT AFPR should NOT set any codes whatsoever.
You'll want to get an Autotap or Tech II and see what code(s) you're setting as soon as possible. This way you can determine how bad the situation is, and also formulate an action plan to rectify the situation.
As far as fuel pressure goes, I don't really know what mine is set to, because I haven't yet verified the accuracy of the Casper's gauge. It showed 46 psi static stock, even though my manual said the stock setting should be 52 psi. Regardless, I have it set to 58 psi for maximum performance, which is 12 pounds over my stock setting, and may actually be as high as 64 psi.
Let me know what code(s) you have, and we'll figure out how to proceed. By the way, you may want to reset your PCM if you haven't already...
Mark:
My shift points are still stock, as I still have the stock PCM. I get the best performance by leaving the shifter in '3', and letting it shift when it feels like it - usually 5,600 to 5,800 RPM.
Scott
Ken
If you turn on the headlight switch for parking lights, the DRL remain on (apparantly this defeats DRL in some cars - not mine). When the auto headlight sensor thinks it's dark enough, the regular lights come on - so again you have headlights on, though not DRL.
Anytime the car is in gear it appears that either DRL or headlights will be on.
I don't have a need to defeat them - just wondering.
Any comments?
Ken
ALL opinions are welcome.
Henri
You piqued my curiosity. I think DRL is a great idea, but I have never liked the fact that it is fully automatic. As the pilot I think I should have ultimate control over such things as lighting (at least I have the ability to defeat the automatic door locks!). Anyway, I went digging through the service manual and learned the following:
The DRL will operate when the ignition switch is in the ON position, the gear selector lever is out of the PARK position and the ambient light sensor indicates daytime conditions. I haven't checked, but I think on my car turning the headlamp switch to the PARK position will turn the DRL off as it does the headlamps at night. Of course, the parking lights will now be on.
The only way I can see to disable DRL is to pull the FOG/DRL fuse (located in the underhood fuse block), which will still allow the high beam headlamps and flash-to-pass to operate, but will unfortunately also disable the front fog lamps (the Aurora is the only one with rear fog lamps). You can't pull the DRL relay because it is part of the high beam headlamp circuit, and it might also cause a DTC.
The rest of this post is probably Too Much Information, but maybe someone will be interested. In DRL mode, the left and right high beam headlamps are placed in series. Remembering your elementary circuit theory, assuming the resistance of each lamp is the same the voltage will be split evenly between the two lamps, causing them to burn at half intensity. In high beam or flash-to-pass mode, the lamps are placed in parallel, allowing the full battery voltage to cross both lamps. The circuit switching is done by the Dash Integration Module (DIM), which is one the many microprocessors aboard the new Bonnevilles. Chances are the logic is in software. That opens up the possibility that the DRL feature is "user" configurable. The service manual describes reprogramming the DIM, which is done after it is replaced. This is the same procedure the dealer uses to change the Magna Steer setting and the DIC greeting. The manual describes the various menus the Tech 2 scan tool will display during this process, including two called "Miscellaneous Options #1" and "#2". Unfortunately, it does not describe the options other than to say "follow...the on screen instructions." Without a scan tool or more detailed documentation, I can only speculate that there may be an option to enable or disable the DRL. If I were designing this, I would put that option in. On the other hand, since GM considers DRL to be a safety feature, they may not have the provision to disable the DRL. Perhaps someone with access to a scan tool can enlighten us?
You've got to be right - no way to defeat it short of pulling the fuse. I don't have any need for that and enjoy having the driving lights on when the car is in gear - but I agree it is better to have the ultimate authority over the vehicle.
Ken
