I am on the mpg avg and I do reset it after every refill of gas. I always fill to full and ride it down to almost empty and calculate the mpg. I get +33mpg consistently, but the computer states 36 mpg. The computer must be calculating wrong. I thought there might be a way to fix this, but it really is no big deal.
I agree, the Solara is a great highway cruising car. I imagine that in the city, it wouldn't do so well.
Joe Cali
www.nextgen-usa.com
Your thoughts,
Meegwell
Was it difficult to install and how much did you pay. I have the coupe I am sure it will make it a real road car. The coupe is very solid, like a rock. I just like less lean.
I keep looking at the "puney" gear shift knob and would like to find a bigger one. Anyone know of a website that carries them? Thanks, Charlie
PS. Has anyone talked to a dealer about the MPG problem?
I bought a 2001 Toyota Camry Solara with 95.000 Miles in it.
The car have a vibration over 60 mph, i can feel it through the entire body and also in the steering wheel, and it comes from the front of the car. No change when decreasing / increasing the speed (only if it goes below 60 then the vibration goes away) , and also braking do nothing with it, the vibration not getting stronger/weaker, and the car is going perfectly straight at braking. The car have a brand new set of tires, all wheel balanced (twice) , and alignment is done by a Toyota recommended Garage.
Any idea would be greatly appreciated.
PS: I still have the car with ~13,000 miles on it - it has never seen rain or snow.
Any ideas or experience?
Traction control will not help you much in snow with stock all season tires, however, there are better all season upgrades available that will give the car more bite in the snow.
p.s. just joined as a new member, I am amazed at the knowledge and experience you all have.. your help is appreciated , holding off buying at this time.
Be sure to let us know what you get and how good the deal is. Best of luck!
I have been very happy with the quality and price of the paint work that MAACO has done; but $300 to paint a slightly scratched bumper sounds like a lot to me. If you prefer to have it professionally done, that might be the best option. However, there is now an aerosol paint made by Krylon, which is called "Fusion For Plastic." It is designed to bond directly to most plastics with no sanding, no priming, and no fuss. It comes in a spray can with a special "EZ Touch Fan" nozzle, which makes application neat and easy. And this paint dries in 15 minutes or less. It is sold by Summit Racing in 12oz spray cans for $4.95 each. One of the available colors is Gloss White (Summit item #SHW-2320). It shouldn't be difficult to fasten newspaper to the surrounding areas with masking tape; to prevent any overspray from going where it is not intended. And in case you end up unhappy with the job; you'll only be out a few bucks; and can still take the car to MAACO.
www.summitracing.com
My wife and I just got a 2005 Solara convertible, we traded in a 2000 Miata because we were finding it hard to fall in then climb out (we're approaching retirement age). We like the car and hope we got a good one. After reading several pages here I get the feeling that most people are happy with theirs. I have a couple question though.
In the manual they mention something about energy conserving oil, I was wanting to use synthetic...is there a problem with that?
Does anyone know if the Nav unit from a 2008 would go in a 2005
Thank You
I found this out when I had to replace my 2000 Solara's engine.
One thing to remember with the Solara's is that oil. The engine loves to sludge the engine. Since I bought mine, the oil has been changed every 4000 miles and never has gone past 4200 miles before the change. And it still sludged. The first time Toyota had to pay to have the engine torn down and cleaned. The last time, the engine dropped the number 1 piston in the oil pan on my way home from work.
My tech always uses one of those fiber inspection gizmos to look down in the engine to let me know if it's starting again. Unfortunately, he can only see the top side of the engine, not the area around the crank.
I would trust the owner's manual when it comes to when to change. I had mine done at Toyota and the cost was just about what you'd pay anywhere. So that throws out that rumor that the dealer charges more.
To do the job "right", you would also want them to replace all of your belts, the water pump, and perhaps the tensioner. You should also make sure that they're not going to reuse the coolant. If they want to charge you extra for new coolant, then I wouldn't argue and just have it done. The price of the Toyota proprietary coolant has gone up quite a bit over the years, so you can expect to pay from $20-$28 a gallon for it.
Just my opinion
http://www.gates.com/brochure.cfm?brochure=2256&location_id=3487
It's the Gates site - timing belts for the '05 Solara 3.3 6 should be replaced every 90,000 - good news is that this is a non-interference engine so a timing belt failure will not cause major damage. It's all explained on that site.
No, it's probably a combination of other factors: Summer vacations, the economy, people are busy working of looking for work, not to mention all the stories about the Solara being discontinued.
We're still around.
Happy 4th of July!!!
Meegwell
The first time my rear alignment was out (toe in) it chewed my Bridgestone serenity's with only 30,000k down to slick. After realignment at 6000 kms it's happening again with mainly highway driving. The outside tread is wearing faster.
Any ideas what's causing the alignment to go out? Dealership has inspected the rear suspension and sees no indicators.
They are brighter, but they also create more heat causing the plastic headlight lenses to discolor fast.
If your car is still under the warranty; the dealer should fix this for free. If it is just beyond warranty; because it is highly unusual to encounter brake fluid leakage at such a low mileage, it may be worthwhile for you to contact the regional Toyota customer service office and ask if they will cover this problem.
