Lexus ES 300/ES 330
Fill the tank up.....all the way up, really "top it off". Set the trip odo to "0". Next drive and use up some of that gas, it doesn't matter how much you use up just drive! When you next stop for gas fill it up again ALL THE WAY up, just like you did before. Now divide the miles driven by the amount of gallons you just topped off your tank with. Thats it!....Now was that so difficult!
here in Houston 97 ES are initially priced in the low 20's. That means you can go down closer to 20 and sometimes slightly below 20, depending on factors like color, mileage, and condition. Of course, certified ES cost a lot more. Anyway, come down to Houston to shop for cars!
NOw i see why you're getting such low numbers. You can't use the 18 gallon capacity of the tank. At the point where the light comes on you still have about 2 1/2 gallons in the tank.
What you want to do is when you fill up use the gallon figure on the gas pump. That tells you exactly how much gallons of gas went into your tank. I am guessing when the light comes on and you fill up, you are actually only putting in about 15 gallons of gas vs. the 18 gallons you use to calculate mileage.
I'm not saying you literally have to wait exactly to the 1/4 or 1/2 tank mark. Just use any measure. reset the odometer if you want next time you fill up and then drive 200 miles if you want or 150. then fill your tank up again as I said in my last post, and then use the amounts of miles you drove and the amount of gallons that went into your tank based on what the gas pump reading says. I'm sure after you do this, your MPG numbers will be more towards what you expected.
Was talking to my mechanic about the above posts concerning the mpg. He says that one shouldn't drive until the warning light comes on. He says that one shouldn't go under 1/4th of the tank because there's a fuel pump in the tank that is cooled by the fuel. It would overheat if the level goes too low. On the other side, he says to fuel the tank up until the auto cut off is reached. Overfilling would cause problems since the tank cap is not vented like in the old cars. On hot days, the gas will expand and go up the fuel lines and cause problems with the systems.
Any comments?
Tim
Personally, since ES uses the same engine and tranny as a V6 Camry (and even the Sienna and Avalon), you don't need the extra warranty.
Thanks for your patience on the subject. You're the foremost authority in the Town Hall.
And whoever else wants to know about certified PO vs. just plain used Lexus'.
The biggest advantage to the CPO Lexus is the warranty. Which means you get the 6/100K warranty, $0 deductible, and the backing of all 180+ Lexus dealers in the US.
Otherwise, a regular used Lexus can be just as good and you can save a few grand buying one privately. The 120+ point check is not really all that rigorous. Believe me, most of the 120 points are ridiculous like checking fluids, wiper blades, tire wear, brake wear, etc. etc. etc.
Some checks are good like having all service records for the car, no major accidents, etc. But you can have these things confirmed on a used car that you buy from someone's driveway also. Most Lexus owners should have the book stamped and should be wise enough to keep service records. And cars that have been in major accidents are easy to spot.
Personally, if you find a good used Lexus for a few grand less, take it and save the money. But I can't say the person who does buy the CPO Lexus is foolish also since that also has its advantages.
rolloman,
Make sure you let us know on your gas mileage figures.
Anyways, is 32,200 a good price for a 2001 ES300? Any one has any opinion?
PS: a 2001 in Iowa is going for about $500 off list. What a jab!!!!
The lexus symbol on the back of the trunk just above the license plate on my 1998 ES300 was pried off (pretty neatly) while the car was in a parking garage.
I assume the local Lexus dealer is the best way to replace it?
My real question is: does this happen very often? Is there a way to prevent/discourage it? I try to be careful where I park but didn't anticipate this problem.
Zymol seems to be far more expensive than Zaino.Is it worth (for that money) using Zymol?.
BTW, my local Lexus dealer recommands Zymol. Any input/suggestions from auto gurus?.
Follow the directions and your car will have a showroom wet-like finish with little effort. I highly recommend it. Go to: www.zainobros.com and check it out for yourself.
Best wishes
I am looking at a 2001 with VP, heated seats, HID, Trunk mats , wheel locks, wood steering wheel, 16in tires. Sticker price is about 35,400. From what i can tell, dealer invoice with dest. charge is 30,755.
I know it is hard to tell but what approx should i pay. I am thinking that around 32,000 seems fair. I would like to buy within 1 month but am not opposed to waiting for a while.
I have read most of the past posts. Seems as though 31,500 to 32,000 is the price for the ES. Any help would be much appreciated
As far as Camry roots. Well, last year they didn't mention it now for 2001 all of a sudden the ES300 isn't very luxurious and looks like a Camry? Whatever, I say.
Don't know for sure if the 2001 ES300s have the Nak available as an optional sound system, or the Mark Levinson, or just the Pioneer.
You can get the Nakamichi Package with the regular ES300 but as your salesperson told you, it will be harder. Lexus simply doesn't produce many Nakamichi equipped ES300s because the demand isn't there.
If you're not a sound buff you probably won't notice the sound quality difference. The Nakamichi is better than the base stereo, but only sligthly and the difference is very hard to notice, unless as I said before, you are a sound buff. Personally the regular Pioneer stereo is very good and the Nakamichi is unnecessary.
What I heard from Toyota salesmen cliffy1 is that the 2002 Camry will be quite different (as much difference as the 1999 vs 2000 Toyota Avalon). His supervisor saw the prototype Camry at Las Vegas toyota meeting.
If the 2000 Avalon and 2001 Lexus LS430 is any indication, you can expect the 2002 ES300's price to remain largely unchanged, however, there will be more features and luxury for your money.
I'll let you know what the numbers look like.
The 2 year "free" service/maintenance plan (which obviously isn't free) sound like a plan unique to your dealership...I don't believe "free" oil changes or services are normally included in the standard Lexus warranty. I believe the current standard warranty includes the first 2 services (1K and 5K) at no charge...which amounts to one oil change. So, if indeed your dealer is going to give you all the rec 5k services at no-charge...the extra difference you are talking about sounds reasonable. My dealer however does offer "free" car washes whenever desired...which is not very often, now that I discovered "swirl marks" in my paint...I wash/wax the car myself now.
I think enigmaone will probably be able to provide the real story...
I purchased my car in July 2000, right after my promotion...had to find a place for that extra $$$ right?
Hope this helps...
Vern
