Seriously, have I felt the wind? Yes. Has it been a problem? No.
I have also driven my Echo at around 100mph and felt very safe. It was very surefooted. Please note that I know that while I felt safe, going 100mph would have made for one spectacular crash if anything had gone wrong.
I do stand by the fact that while I have felt my car moving around, I did not find it disturbing or dangerous.
Now, if someone is used to driving a much, much larger car, they may not feel the same.
The hold up is that you have to have a helmet. I am writing them back to see if I can rent one.
They have also said that if a car is faster than 11.99 in the quarter, your car must have a roll cage. I don't think I need to worry about the roll cage. ; )
I think the difference between what Rippspeed did in the quarter and what the mags say is the method of starting. Do the mags use a light tree? Did this guy?
If I do go to the track, I will post my times here.
Your suggestions appreciated.
I just got back from a vacation to Hilton Head from northern VA. Averaged 42 mpg on my 4-door automatic, with average speeds of 70+ on the interstate, AC blasting the whole time. I love this car!
You can call me whatever you want. Just don't call me late for dinner.
The air conditioning is definitely not as cold as air conditioning with Freon.
This may just be me, but one or two minutes after I start driving and have turned on the air conditioning, I am comfortable.
If a person is concerned with the heat, a black car is probably not the way to go.
My 2001 ECHO is ten months old and had 6000 miles on it. Ive changed the oil three times in that time period. (I do mostly short distance driving) Still loving this car!
About the only time you really need to consider putting in more pressure is if you are hauling a much-higher-than-ordinary load, which is usually an issue for pickup trucks, vans and SUVs, but not the ECHO.
In a low-speed off-roading situation, you may want to underinflate by several psi or so to maximize the area of the tire contact patch, and thus, traction. Once again, this is usually not an issue in the ECHO.
Just get 32 psi in there and don't worry about it.
The motivation behind my question was a desire to attain the highest fuel mileage possible along with a vague knowledge of the fact that tire pressure plays a huge role in fuel economy. On my recent trip I got some very good mileage, and it came as I started the trip by filling the tires up to 41psi (cold) all around. The handling seemed slightly improved as well, though that might be psychological. I just wondered if I was doing anything dangerous or counter-productive by putting that much air in there.
I've been using NuFinish for 10 years now and have never been disappointed!
The psi of your tires is nothing to fool around with. Definately inflate them to the value shown in the owners manual or decal on the car. I suspect all this flap about the tires on the Ford Explorer is due at least in part to people not running the correct pressure in their tires. (pressure gets too low and tire heats up, causing dammage to the tire which eventually throws its tread) Dont think this problem is only the exclusive property of the Explorer! Tires have been throwing their treads for years and in all probability the cause is owner neglect of the tire pressures. (and company failure to come up with a way to ensure proper psi) On my motorcycle I check the pressure EACH TIME I ride it because if the psi gets low in ONE tire (maybe by picking up a nail) it drastically effects the way the bike steers...youlll have an accident for sure if that psi gets low and you dont realize it. The same thing on a lesser scale can also affect your car (even the ECHO). You pick up a nail in one tire, the pressure drops and you car doesnt handle the same. In bad weather or trying to avoid an accident this could cause you to lose control.
Historically (and I know this is bad), I've not paid much attention to the tire pressure in the various cars I've owned over the years. My interest has been triggered by ownership of a car like the ECHO, however, since fuel economy is one of the main reasons I bought it. I just found it strange that the difference between the manual and what was marked on the tire was so great (32psi vs. 44psi). Also, the way the manual was worded didn't leave me much faith that much attention was paid to the various brands and types of tires with which the ECHO might come equipped. It just read like a lot of boilerplate, to me.
Last week, on my trip to Hilton Head, when I had 41psi all around, the handling seemed to be better and the ride didn't seem harsh to me at all. The mileage was terrific considering the speeds (near 80 mph on RT 95, consistently) and the fact that the AC was on the whole way. I visually inspected the tires when I got home and nothing seemed amiss (no cuts or bulges, etc.)so I wondered if I could safely keep them inflated to those pressures with no ill effects.
Average mileage so far is 43.47 (automatic, 40% city, 60% highway).
For those really interested in pressure accuracy, check out this short Town Hall discussion on Tire Gauges.
http://www.meguiars.com/CarRx.cfm
In addition, I also use Meguiar's Gold Class clear coat liquid car wax and Meguiar's trim Detailer for black plastic and rubber trim...they both work great. I've also used NuFinish on my other Toyota's with great success. I like both products.
Anyone have any tips for getting the blue paint off, but leaving the finish of my car intact?
My previous car was white and somebody left a good bit of their bumper on mine. I was able to remove it all by slathering the polish on the mark and rubbing very hard.
Rubbing compound would work too I suppose...
But if it happens again, I will know another way of dealing with it.
The Toyota reccomended number is a compromise for the ride handling and economy. If you are not worried about the ride, or don't notice the difference then 41 is fine. Tires actually run cooler at higher pressures, and are less likely to burst not more likely. This is because there is less flex/friction in the tire which is what heats it up.
41 psi will also handle better especially with a high profile tire. The higher pressure keeps the tire from rolling over onto its edge as you go around corners - so it acts more like a low profile tire. Try this - drop the pressure down to about 20 and go around a corner the tires will squeel like mad, raise it back up and they will be fine.
Yes the tire may wear slightly more in the center, but will probably last just as long, or longer because a cooler running tire (see above) does not wear as fast.
The downsides include slightly harsher ride, and more sensitivity to poor balancing. If a tire is not balanced very well you may feel a vibration in the wheel that would be dulled by lower pressure in the tires.
I just want to clarify that the 44psi listed is in fact COLD tire pressure and the tires are DESIGNED to heat up from that point. It takes a heck of a lot more than 44psi to blowout a tire.
Like 80psi at 120mph, or a nail, or a police "stop strip"......
Anyone considering an Echo needs to test one first before taking the biased views of sources like Edmunds.
And by the way; because of the lack of low-end torque, the Echo is not the easiest in the stoplight grand prix. The sweet spot comes after 3rd gear above 40mph...this bugger really cooks then!
Now, kaz6, while you dwelt upon what you perceived as Edmunds "slam" on the ECHO's highway handling, I noticed comments like "the Echo will probably last forever," "through a crowded city, the Echo is ideal," and "clear winner of the subcompact class." Now, maybe if Toyota would just consider increasing its bribes, maybe Edmunds will do better about ignoring anything negative it turns up in the future.
"Even if you option this car with everything, you'll be rolling down your own windows and manually adjusting your own mirrors."
The ECHO comes with "remote" mirror adjusters. They are indeed manually operated but do not require the driver to roll down his window. A little less sarcasm, Edmunds punkin'heads, and a little more research and we'll all be doing fine...
I take the most exception to their complaint about highway driving in high winds. I do not feel that I am in danger whenever I do that.
The Echo is not perfect but seems to garner undue criticism for things that are fairly common for the class.
As you said though, I'll focus on the positive! Translation:I don't read Edmund's reviews anymore!
I have written a letter to the editor pointing out the error in Ms. Riches' article.
FWIW, the notes at the bottom indicate that the Mirage coupe is going bye bye after the 2001 model year, but Motor Trend reports that the coupe will continue into the 2002 model year as a 2002. Given that Edmunds has a shorter lead time, I have asked them for a clarification.
You know it is funny, but if Edmunds (and its editors) are so concerned about the safety of small cars, you would think they would include a warning about becoming spam in every small car review.
If you click on the "compare with other vehicles" when looking at the Echo's information, you get a table with information for the Daewoo Lanos, the Hyundai Accent, and the Kia Rio. If you check out their reviews, only the Hyundai Accent has any warning about the "dangers" of small cars and it is no where near as severe as what was printed in the Echo review.
Edmunds claims to be unbiased. Sounds like they are biased against the Echo.
