Alternatively, you can have the car serviced and inspected every 15K miles or so, and the mechanic will catch it if the chain is beginning to wear out and need replacement.
I can walk you through checking the valves no problem.
To check the valves you need to remove the black plastic valve cover (four 10mm acorn nuts), the spark plugs, (so you can turn the engine over easily), and the metal valve cover itself. Ive never removed mine myself so I cant tell you whats involved right now, but it should be easy. The main thing to think about is putting it back on so it doesnt leak afterwards. I would suggest delaying putting back the black plastic one for a week or so (engine wil run fine without it) to make it easy to ensure there are no oil leaks.
Once the valve cover is off, youll see the cams. There are 16 valves to check. Youll need a feeler gauge to check the clearances, about $5 at pep Boys or a similiar store. I dont know what the actual clearances are without looking at the book. Ill get to that another time. There are two rows of valves. The intake valves are the ones nearest the FRONT of the engine. The exhaust valves are the ones nearest the REAR of the engine. To check the clearance, you will rotate the engine so the cam of that valve is pointing UP (or nearly so it doesnt have to be PERFECTLY up) You can do this by putting a wrench or socket on the nut in the center of the alternator pulley. Or just pull on the belt like I do. The spark plugs must be OUT to do this. You will check each valve and write the result on a piece of paper. I like to make 16 circles in two parallel rows of eight (just like the valves are laid out on the engine) and write each valve in the corresponding circle. Ill get more specific how to do this another time.
Right now you need to know why you are doing all this. You are looking for a tight clearance on an exhaust valve. It almost doesnt matter what the intake valve clearances are. (as long as theyre not zero or really out of wack which is RARE) The exhaust valve clearances can be too loose (even out of spec loose) but there CANNOT be too little clearance. The result of that is eventually a burned valve. This is what you are looking for a tight exhaust valve.
Now a word about checking valve clearances. It is unusual to find valves clearances out of spec. They are probably fine. But if you DO find one really wrong, dont freak out. Thats what the check is for. You can have the dealer adjust it and all will be well. The WORST thing is NOT checking the clearances and having a tight exhuast vlave go undetected. That would mean an expensive valve job at some point.
Thats enough for now. Ill check what the values are for the exhaust and intake valves tonite in the service manual.
To get the metal valve cover off there are 9 bolts and 2 nuts. Probably 10mm. The sparkplug connectors need to be removed from the plugs as well.
The clearance for the exhaust valves is .010 - .014 inches. The clearances for the intakes is .006 - .010 inches.
Have you ever used a feeler gauge?
The 16 valves are in two parallel rows of eight. They run fron left to right across the sideways mounted engine. The front row of eight are the intakes valves. The rear row of eight are the exhaust valves. We're looking at the exhaust valves first.
Get out the .010 inch feeler gauge blade. Now look at the cam which is above each valve. They are in pairs. Each pair of cams operates a pair of valves. To check the valves, the cams must point upwards. Doesnt have to be perfectly straight up. Turn the engine clockwise until the first valves you want to check has their cams pointing up. Slide the 010 blade under the cam between the bottom of the cam and the cam follower. Check all of the exhaust valves in the same way. Check off each valve as you do it on a piece of paper. I sometimes mark the valve with a black magic marker.
Did the 010 blade fit under all the cams? Good you're ready for the next step. If you couldnt get the 010 under even ONE of the cams STOP RIGHT THERE. The car has to go to Toyota for an adjustment. Its that simple.
If the 010 went under all of the cams, get out the 014. Its marked right on the blade. Try the 014 under all the exhaust valves. It either should not go at all, or br fairly tight. Put it this way, the 015 should NOT go in. If this is the result you get, youre finished with the exhaust valves. If however, if the 014 fit in any one of the valves, try successively thicker blade until you find one that wont go. Then try the next smaller. It should go in. Play around with the various blades until you find the clearance for the valve. Write the value you get down on a piece of paper. When all the exhaust valves are checked, your ready for the intakes.
When you are finished with the 006, get out the 010. Try this under all the intake valves. This blade should either NOT go under the cam, or be very tight if it does. If it goes under the cam, try the next thicker blade until you find the one that WONT go. Try the next smaller blade. It should go. The value you are looking for is the blade that WILL fit under the cam, but the next thicker one WONT. Play around with the blades until you have a value for each valve. Write down the values for each valve thats out of spec so you can identify each one.
If on the other hand you find an exhaust valve(s) the 010 didnt fit under. An adjustment is required.
What happens if you found a valve just a little out of spec? Even a somewhat tight INTAKE valve is probably OK. If its 002 or less out of adjustment Id leave it alone. Thats 010-014 for exhaust valves and 006-010 for intakes. Its better the valve be LOOSE than TIGHT. But a little tight wont hurt intakes. A tight exhuast valve needs attention.
Its possible you found a valve with ZERO clearance. None of the feeler gauges, even the .001, would fit under it. Well this one needs to be adjusted even if its an intake but theres more. Youve found a significant wear in the cylinder head. As the valve wear and sink deeper into the heads, the clearance gets LESS. Valves with ZERO clearance are trouble. You probably want to do a compression check on that cylinder when the valve is adjusted. It might be time far a valve job.
Niels
I wonder if the new Yaris will eventually turn cheap as the years go on also, or if they have improved upon that...? Nevertheless, I will be moving on to a different vehicle soon.
Also, for those in winter climates, this car was awful to drive in snow, keep a shovel with you at all times.
Some things to be happy about:
1) Outstanding ergonometric design. Small on the outside BIG on the inside. Easier to get into and out of then my wifes 05 Camry.
2) Great storage pockets through the dash and doors of the car.
3) One of the most reliable cars made
4) Easily the most cost effective fuel efficient vehicle made. Youll pay $10000 more for a Prius which will save you $2000 in fuel over the life of the vehicle (compared to an ECHO). Im driving mine over 110 miles a week for $7.50 in gas. Thats @$3 a gallon. Wait till it hits $4 a gallon.
Heres an idea for some therapy. I saw a Kia Rio as old as my ECHO the other day. Not a pretty sight!
I agree 100% about the ECHO being poor in snow. Easily the WORST car I have ever owned in that respect. However I noticed in the Tire Rack Survery that the Potenza 92 tires that came standard on my ECHO are the WORST on the chart for performance in snow. I bought a set of four Kumho PowerStar 758s (for $29 a tire) which score very high on the chart. Im hoping thaey will remedy the problem.
However, I have been pleasantly surprised in mine, which is a year older and almost certainly has more miles (coming up on 75K any day now), and certaily has none of those problems.
I also notice that reba purchased his/her car used as I did, which of course leads to that eternal question when not buying new: how did the first owner treat my car? Some of reba's complaints could be the result of hard use when new (loose windows, squeaky noisy back end). Cheaper cars are always more susceptible to give trouble later on when they get poorer care and/or harder use while young.
reba05 - It does not matter what car you buy in the future. You will always have something to complain about the car if you abuse it by driving hard and not upkeeping the maintenance. Even a car with built-in reliability requires proper maintenance. Toyota cars are no exceptions. I would not buy a used Toyota car because its owner(s) tends to skip maintenance and runs it to the ground.
But I do feel its a pretty cheaply made car and wish I would have paid more attention to that when I purchased it.
It was kinda cute to see them all gathered together there! I wondered whether their owners parked next to mine on purpose or if it was just the best parking spot available when they arrived. Now that I own one of these cars, I am noticing that they are everywhere around here. Knowing the sales figures as I do, they must have sold most of the Echos on the coasts, for there to be so many of them in the San Francisco area.
I was on the freeway next to one yesterday, driven by the oldest woman I have ever seen driving a car. Well, she saw my car and turned and gave me a broad wink! Most Echo drivers I see seem pretty happy with their cars. They say the gas prices are about to spike up again for a while - can't beat the Echo's gas frugality in these times of high prices. :-)
Its pretty rare I even see an ECHO on the road let alone two at the same time! Im old enough to recall VW Beetle owners waving enthusiastically to each other and did it a lot myself. I can only recall one return wave from another ECHO owner however.
Yes the cheese is about to get binding with the gas situation. Why manufacturers were allowed to sell six and eight cylinder cars given our dependence on foreign oil is hard to understand. This "let the market decide" approach might end up burning a lot of people and our economy to boot.
So I have a fellow Echo owner living right next to me! Not only that, but his/hers is a really good-looking dark green - I wish that was the color of mine. Mine is silver of course, which it seems about 80% of them were, with the other 19% being white and 1% the very rare red. They should have made more of the green - it is a really good color on this car.
In the meantime, I would love to see either of those blues you mentioned, as even with all the Echos I see regularly around here, none have ever been blue. I don't particularly like Toyota's seafoam blue (presuming it is approximately the same color as the one of the same name on the Prius), but I bet this car would look gorgeous in a dark blue.
I am waffling on the next purchase, what with interest rates going up and all. I may just end up keeping this Echo longer than the couple of years I originally intended. Seven months in, I still miss having a tach, so my next car will not be a Yaris, as the tach is still absent in the liftback. If I go with a Fit, that is spending more money than I already spent on this car, so I might just take out a much smaller loan to mod this car some - the 14" rims have to go once these tires are used up, to be replaced by 15" alloys and slightly wider tires, and I would like to find a rear sway bar and perhaps lower it a little and change out the shocks as well.
This car has the awesome advantage of the lowest curb weight of any passenger car on the roads today, which makes it peppy and agile. But the suspension is a TOTAL letdown, unnecessarily I feel. For a few hundred bucks of cost, Toyota could have given this model a proper economy-car suspension like the Corolla's, so it didn't just keel over in any hard turn. At first I thought that the body roll matched the chassis response to turns, but it doesn't AT ALL. The tires never lose traction even in very spirited driving, and the steering follows the driver's commands quickly and accurately, but if you want to drive it fast and fun, you have to settle for gradually becoming sea-sick. :-(
Anyway, for now I am putting off these decisions until it needs tires, which is probably two years out. Maybe by then new car fever will have overwhelmed me! If not, I will look into some of these upgrades.
PS Just got Sirius satellite radio as a gift, so cruising around in the Echo has become even more fun! :-)
I myself have succumbed to the "New" car bug however. Having had to sell my mc I went out and bought a 1999 Miata today for $7500. 28k miles, female owner, pretty much new condition. There a lot of deep scratches on the bumper and some on the rear deck and the top has a tear in it but over all pretty nice.
I want a bit more of a balance between sport and comfort, so I am willing to give up a little comfort to achieve it.
When I think about getting one that mounts on the A-pillar, I get all hung up on how it might look silly - sort of like I was trying to be "Fast and Furious" in an Echo! :-/
Which is strictly a personal hang-up, BTW, in case yours is mounted there.
I also don't want anything in the car that is going to squeak against other plastic surfaces, or rattle. I just hate that. Which leaves me in a pickle as far as getting an aftermarket tach.
I kinda wish it was possible to install the whole IP from the xA - it would be $$ I am sure, but I bet it would fit right in. And I like the look, and hey! The xA has a tach! Alternatively, it would be cool if it were possible to retrofit the IP from the '03+ Echo, which had a tach also.
I installed 4 gauges on the A pillar by myself: oil temp, oil pressure, coolant temp, and transmission temp. There is nothing silly about mounting gauges on A pillar. I prefer functionality over prettiness. The blue light goes off at 140F. Radiator fan kicks in at 212F. If your radiator fan does not kick in at 212F, your cooling system needs to be checked. Oil temp stays at 181F, and transmission temp at 140F during crusing on a 76F day. It takes about 15 minutes of driving for oil temp to register at 140, and about 30 minutes for transmission temp at 120F on a 76F day. Short trips are definitely not good for the engine since the oil is not even heated up enough to burn off excessive fuel in the oil. Excessive fuel in the old during start up dilutes the oil and increases engine wear.
Whats an A Post anyway?
Also, I'm taking a trip south to San Francisco, and I'm hoping to get better gas mileage then I did last time. When I drove to sacramento I only got 33 MPG at 80 mph with the ac on, which I was a little disapointed with. I'm going to try to keep it around 75 this time get a little better gas mileage. Two things:
1) What PSI do you suggest I inflate my tires to?
2) Any advice for driving in SF with a 5-speed?
I keep my ties at 32 psi which is what the manual says.
kneisl1: the A pillar is the plastic divider between your driver's side window and the front windshield. Lots of folks mount gauge packs there, as scjfan has. I like the idea of having oil pressure and temp gauges as well as volts - I wouldn't mind getting a 3-pack of those and mounting it below the bottom of the center stack, removing the ashtray I don't use anyway.
As for a tach, I was considering scj's words this morning as I came in to work. Behind the steering wheel probably would be a good spot to put it - I was kinda checking it out to see how it would mount. I dunno. Call me crazy, but I may just ask the dealer how much it would cost to retrofit the stock unit from the '03 in there, and I might even do it if it's not outrageously expensive - I prefer the stock look inside the car, you know?
Im right about the fuel. Assuming of course Fi is working right. You WOULD get increased carbon buildup, assuming a cold start. Once the engine is warm idleing wont hurt anything from a fuel contamination standpoint.
The automatic transmission will be greatly benefitted with warm ATF in the winter. I was incorrect in my earlier post abbout the ATF temp. It actually takes 30 minutes of driving on a 76F day for the ATF to reach 100F instead of 120F. I measure the ATF temp after ATF exiting the OEM cooler built inside the radiator. Since I installed the temp gauge this spring, I do not know how high the ATF temp could reach in winter. But, when I touched the canister of my ATF bypass filter several times after 35-mile drive to work in winter, it felt warm and never hot. I think the OEM ATF cooler is working too well.
I replace the toilet paper (TP) of my oil bypass filter every 3k miles, and notice the used TP is dirtier (blacker in color) in winter than in summer. For those using dino oil I would recommend changing oil every 3k miles in winter to reduce water/carbon buildup in the oil and engine.
To further reduce carbon buildup I would recommend putting a 12 oz of Techron in the fuel tank every 3k miles, and then changing the oil. For those who are more adventurous try a 32 oz bottle of MMO in the gas tank once a year followed by an oil change.
Gee if Scjfan is right about cold weather affecting automatic transmissions then people who drive n places like South Dakota must have drastically reduced transmission life.
After that there are some mechanical possibilities. Are your sparkplugs and air filter in good shape? Are you looking after your tire pressure? You havnt installed wider/larger tires and rims have you? Do you have a seized brake drum/caliper? Have you done a compression test/leakdown teat on the engine to determine its state of health? Are you using gas from cheapo gas stations? How is your wheel alignment?
Im thinking of more.
Id be willing to bet you can train your ECHO to get better mileage. I thought of this because I just bought a Mazada Miata. I was suprised how much difference in performance there is between the ECHO and the Miata, and the engines are only like 25 hp apart. And the ECHO has VTT which the Mazda doesnt. I think the "i" part of the VTTi might be the reason.
I really, really don't want to become a widower if she gets in an accident with a Navigator.
So we've been looking for an Echo with ABS and side air-bags.
Supposedly these were available options, but we have yet to find one.
Do they really exist in the U.S., or this just a tailpipe dream?
But lots of Scion xAs have side airbags, and all of them have ABS. They have been around a couple of years now, and have the same powertrain and approximately the same price (when new) as the Echo. They also look similar to the Echo from the front, and are decently cute in ther own right. Perhaps you could look for one of those?
I wonder how long a time frame we're talking about for the "learning" of the engine. I always assumed that if it did any learning, it was just adjusting based on a very short term basis, such as being in the city vs the highway.
I don't think I'm getting too much rolling resistance. I can put in the clutch in and roll extremely well - with the MPH not decreasing much at all.
I can get about 38MPG driving to school and back at ~40-50MPH with a few stops, (11 miles each way) it's just the freeway that really kills me. Do you know if outside temperature has an effect on gas mileage besides air-conditioner usage. It sounds like you're all in cooler climates than I am.
Thx
