Mercedes-Benz E-Class Sedans
14950525455218
  • rokinkeadrokinkead Posts: 18
    I picked up my '01 E320 from service today. I got hit with the fuel guage problem. They changed the fuel sending unit. The service advisor said it has been happening alot in the southeast lately, due to changes in gasoline additives. It is damaging the units. Even 4 year old cars are ailing with the problem (he says). He also called the techs in the shop to ask if they needed to change my instrument cluster. They said no because the cluster only needs to be changed with the fuel sending unit for '00 models. I found that interesting. Can anyone confirm the claim that a fuel additive is damaging fuel sending units?
    They also changed a steering angle sensor to get rid of a very embarrassing and annoying beep and flashing "visit workshop" for the ESP/ABS/BAS. I will watch this to see if it has indeed been fixed
  • kenyeekenyee Posts: 738
    rokinhead:
    Do you know the build date of your E?
    The ML had this problem for the longest time, but they hardened the sender in roughly Feb, 2000. I haven't heard of it being a problem since...
  • wnielwniel Posts: 97
    I had the fuel sending unit replaced in my 2000 E430 4-5 months ago and it has worked fine until just the last two tankfuls. I was talking to the service manager at my dealership to day and he said that they have made some addidional repairs to the unit in the last few months which apparently has fixed the problem. I will be taking the car in shortly to have it fixed again.
    yupyupyup:
    No, I didn't have any squeeks or rattles after replacing the instrument cluster. Not sure with the additional work they will be doing will require the replacement of the cluster. I hope not. There was no evidence that I could see that would tell that the cluster had been replaced.
    Wally
  • park city. The MB people told me the new E model for 2002 due during Sept 2001. Don't believe any real design/body changes for this model. Model year 2003 due at MB dealer during fall of 2002. Lot of changes for this model year including design and equipment changes. Hope this helps.
  • mbpincmbpinc Posts: 3
    After three months of research, including reading most of these posts (thanks for the help), I've finally arranged for a car from Three Point Motors in Victoria, BC. I leave from Atlanta for Victoria this Monday. The 1999 E-320 AWD wagon has just 330 miles on the odometer. This wagon has a build date of 12/98, but an in-service date of 10/00 (thus, 3 1/2 years remain on the warranty). I had reservations about a Mercedes that had sat for so long. But I've already ordered a MY2003 E-430, and I'm not sure how long I'll keep any wagon I buy now, with new models coming out in 2004. It was the 1999 (mostly new), for $40K, plus shipping, or a new MY2001 AWD wagon for $53K. If the 1999 wagon checks out, and I end up keeping it, I'm unable to get the Mercedes Extended Warranty; instead, the Globe 3yr/100,000mile warranty has been offered. Anyone have anything good or bad to say about Globe? And what, if anything, do I request that the dealer do, to be sure the car is in good shape - for me, or for the next owner?
  • fshxprtfshxprt Posts: 8
    Anyone have any experience with the Colgan Bra for the E320? I drive freeways often and want to do as much as possible to lessen paint nicks from road stones, etc.
  • cmayercmayer Posts: 38
    ... is my loaner as my '98 E300 tells me it needs brake pads. (Actually, it warns me of brake lining wear.)
    Haven't driven it yet but I'm looking forward to it. Had a C Kompresser loaner last year with the newer shifter - that was fun.
    I expect I'll have it for the weekend - I'll post my impressions next week - but I probably should take it out for a spin at lunch time, just in case.
  • Hi all,
    I haven't been posting lately but have been reading all your comments.
    I have received an invitation from Mercedes to attend a driving event of all new cars including AMG models and the new C Coupe. If interested call your dealer for an invitation.
    The event is gonna be held in Hollywood Park over the weekend of May 11th till May 13th, 2001. Or you could check it out at mbpowertrip.com
    I am looking forward to go on the AMG "hot laps" and enjoy this sales-free atmosphere.
    I hope to see some of you there.
    Cheers
    Johnny
  • dman12dman12 Posts: 9
    Hi Walt.
    I was looking at the same Yoko dbs you put on your car, and they get pretty high praise on tirerack.com. I'm in the market for tires on my E430 and was looking on that site at the same tires (same size as yours, btw). How long have you had them and how are they wearing? It sounds like you're pretty happy with them.
    I also saw some Bridgestone Potenza RE730s and wanted to know if you know anything about them. They seem to be similarly rated in terms of customer satisfaction.
    I still have the OE Goodyears and with 21,000 miles on them, I need to make a decision. I live in Houston, so weather isn't an issue.
    Thanks for any help.
    Dennis
  • waltowalto Posts: 34
    I've had the 17" db's on the car for only 700 or so miles, so I can't comment on the wear. The wear rating is 320 (or 340?), so I'd expect them to be pretty good on this score.
    My impression of these tires get better and better. The ride has actually improved with mileage, so I find higher pressures comfortable. I am still running them at 34 all around. The handling is neutral (little understeer), and the highway stability is just fine. The twitchy, overly-sensitive, wandering quality that I experienced with the original tires is simply gone. The car is rock steady at any speed and steering effort finally seems appropriate.
    Generally, higher pressure at the rear gives better high-speed stability and maximum load carrying ability. The lower pressures at the front also improve ride quality, because passengers are more sensitive to harshness at the the front. So the 32/36 pressure recommendation makes sense. This arrangement, however, will produce less precise steering response and handling (more understeer) and make the car feel "sloppier." For feel, I like equal pressures all around. The ESP will deal very well with any oversteer that might develop from this arrangement.
    Although the db's are Z-rated, they are not all-out performance tires like the Yoko AVS-I or Sport or Michelin Sport. The db's don't have that level of cornering adhesion. But they have enough adhesion to scare me, and that's my limit anyway.
    I don't have any experience with Bridgestones, although I have heard good things about their high-line tires.
  • hlsjrhlsjr Posts: 4
    I too have had the fuel sending unit on my 01' 320 replaced, and was rold that gasoline additives are responsible for the problem. I was also told by the mercedes mechanic to expect this to occur again,or until Mercedes improves the ability of the units to resist the deterioration caused by the additives. By the way, I only use Sunoco 93 octane in the car.
  • mcintexmcintex Posts: 2
    I just bought my first MB...a '97 E420 with 35k..what a wonderful car to drive and look at. But where do I get started? I don't want to let it go to pot. I am looking at Zaino for wax, but it wasn't arrived yet.
    First question.. used up all of my washer fluid on my first long trip. (It was great though.) The owner's manual recommends a specific fluid combination. Do I really need to take it into the dealer for wiper fluid?
    Also, although it is still under factory warranty ail 8/01, I want to start maintaining this myself. Is there a good place (on the web) that is a good resource for in-between major maintenance work?
    Thanks for the assistance. P.. I am seriously thinking about upgrading the brand new 16" tires/wheels to 17". The car is too sensitive to my liking and I think that will help.
    When the service advisor said there is an additive problem, I asked him if the new unit is different or will they keep replacing them. He stumbled and "kind of said" MB has a fix that is permanent. I am inclined to think there is no permanent fix available as yet.
    Maybe they should have used the same system found in other cars that have the same features.
    I am beginning to question the belief that I will be able to keep this car long term. If basic changes in fuel treatment do this in 4 months, imagine what might happen over a 10 years.
  • kcsuprattkcsupratt Posts: 23
    I just washed my E430 Sport car today and I noticed on the Molding where it reads Sport i have some dirt or something that seeped into the molding. Is there anyway to get this out ? Also, where can i get mud guards for my car ? I think if i had the mud guards in i wouldn't have gotten the new car blemished.
  • jean7of9jean7of9 Posts: 192
    Mud Guards can be installed by your dealer. To avoid piercing the body, MB designed them with brackets which can break easy when the rubber hits a solid obstacle. You should be careful when backing into side walks or snow banks, you may leave them behind. If you lose one you will have to buy a "pair"for replacement. Good luck.
    Jean
  • mbdrivermbdriver Posts: 426
    Jean is correct. My dealer installed mud guards on my '00 E320 about 6 or 8 months ago. They're the black molded type that fit perfectly and blend in nicely, similar to those found on the Honda, Toyota and other Japanese cars. The rocker panels on my MB are clean and free of road tar, grime, etc. Well worth the money!
    Do you know how much they are and how much do they charge to have them installed ?
    Has anyone else have problems with stains on their molding of the Sports package ?
    Thank you all !!!
    Kenny
  • recyclrrecyclr Posts: 1
    Can anyone give me an idea where I can get a single headlight ring for the parking lights[small light] for a 2000 e430
  • bdwrightbdwright Posts: 4
    Hello all,
    I will be doing my first(of many) Zaino's in the next few days, when my shipment arrives.
    Just a couple of newbie questions, that I didn't find answers to on previous posts.
    Has anyone used the clay bar on thier wheels('97 E420)? Then do you Z1 and Z2 your wheels? Does it help keep brake dust at bay, etc?
    Secondly, since it is my first go at this, can I use the Z1 and Z2 on the black plastic door handles without that white haze that you see on some wax jobs?
    Additionally, I just purchased this car, any tips on cleaning the interior dash, wood etc? I will be buying some Lexol to clean and condition the leather.
    Thanks a million.
    Brian
    The auto, with only 1200 miles and a still new smell, was my weekend loaner while my '98 E300 was serviced. Several physical changes in 3 model years - different wheels and ground effects, newer shape and lights on the side mirrors, longer and lower third brake light, telephone antenna...the change to the hood slope wasn't something I noticed either driving or looking at the car. I never had the two models side by side.
    Interior includes all those radio and emergency telephone things - too many buttons, but the wheel mounted ones are convenient - don't you get a cassette player any more?, nice contrast piping on the leather (mine are vinyl) seats and headrests, Mercedes Benz and stainless on the front door sills, newer shifter shape and funtionality, and the changed displays. The digits are larger (nice for us bifocal aged owners) with more functions - I assume you can adjust the contrast but I didn't fuss with it. Since tele-aid isn't active on this loaner, I got an annoying "1 malfunction" displayed every time I shut off the car. Even the key fob has a changed shape with the panic button relocated. Both the key fob and the steering wheel have silver silver stars, mine are just embossed onto the black and oyster plastic.
    The desert silver and java wouldn't be my choice, but I'm sure others really like that combination. I liked the single push for roof opening; must be German safety that requires holding the switch for closure. I played with shifting a little bit, but I doubt that I'd do that much once the automatic were adjusted to my driving patterns.
    Performance was similar to the turbodiesel, but the handling differs due to my 17" wheel upgrade. Very nice car and fun to drive, but I'm glad to have my own auto back. Sure beats a Honda loaner for the weekend.
    The Delaware dealer took care of getting my PA state safety inspection at their associated agency. The service adviser called and offered to perform my next service 2800 miles early, but since that's three months away and I'll be paying top dollar for synthetic oil as well as any other regular maintenance items when that happens, I demurred. I'd also like to wait to see how the a/c and engine cooling functions are performing as we move into that time of year. Speaking of cooling, I noticed that the temp guage would settle near 10 o'clock on the '01. I'm used to seeing it at about 8:30.
    I'm still convinced that the E Class is the perfect sedan, even though I chuckle every time that robotic hand holds my coffee. You folks have good taste!
  • You can use the clay on your wheels. After claying, wash with Z7, then Z1, Z2, and finally Z6. Brake dust will still accumulate, but will come off very easily. You can Z1 and Z2 your door handles too.
    Just finished my second coat of Z2 after beginning the process with Dawn and clay. If there was a newspaper on the ceiling of my garage, I could read it in the reflection on the hood!
    Bill
  • 2ndmb2ndmb Posts: 72
    Hey Guys, Z2 works great on the wheels, as someone already stated, you will still get brake dust but it will come off easier. Keep adding more coats of Zaino, the paint will get deeper and deeper. My Brilliant Silver E320 looks awesome now. To those that haven't taken the plunge, go for the Zaino, you won't be disappointed.For more tips go to http://www.zainobros.com
    My dealer charged me around $200 for a complete set of four installed mud guards. I think I was taken -- they're listed as an MB accessory for a bit more than $80.00 on www.mbusa.com (build your own E-Class). Since they just clip on, they should be easy to install yourself.
    Regarding Zaino on wheels, I recently upgraded to 17" 5-spoke MB Style E wheels on my '00 E-320. Before they were mounted on the car, I did the Dawn wash, Z-1, Z-2 routine and added two additional coats of Z-2. Since the new wheels were put on the car, I've washed them twice and each time added another coat of Z-2. What a difference! The brake dust doesn't seem to adhere as much, and it's really easy to wash off. Perhaps the reduced accumulation of brake dust on the new wheels is a difference in aerodynamics.
  • drew_drew_ Posts: 3,382
    Just a reminder that the MB chat is on tonight (6-7pm Pacific/9-10 pm Eastern). Hope to see you there!
    http://www.edmunds.com/chat/mercedeschat.html
    Drew
    Vans, SUVs, and Aftermarket and Accessories message boards
  • dl7265dl7265 Posts: 1,381
    well dealer got in a 1999 300 TD finally, it was Silver/Grey starmark and 32k miles. My 1st drive of the turbo model , I noticed u can slightly hear the diesel at startup but after that the 244lb torque really kicks in , pretty impressive,nice ride and good colors . It was priced at 42,900, they offered it at 40k even , and gave me a decent trade offer, I passed for now :(, a few more miles than i would want on a 2 year old car and the steering wheel was very badley worn down .It might be hard to locate another especially with that color combo, most seems to be Black or White, but i will still scour the private market, , ,thanks again for your assistance.
    regards,DL
  • spfoteyspfotey Posts: 131
    Has anyone heard when MB is updating the e320?? i originally heard this fall but haven't heard anything for a while??....
    thx
  • macbestmacbest Posts: 55
    The new model will come out in the fall of 2002 as a 2003 model. It should be released in Germany later this year; it is a total redo. A number of previous posts talk about what has changed.
    Given that it will be so new, and the potential problems that come with a new release, the current make, a classic, is and will continue to be a good buy. I'm seeing a major glut on the market as the German connection could not turn off the production of E classes in as timely a fashion as they did with US cars. Prices of invoice at Phx dealers, and hundreds over invoice for California bay area dealers is common, although, still requires a "well I will have to talk to my manager" routines. I'm zeroing in on an E430 with these caveats and will wait until the new E has some of the bugs out.
    DL - I guess there will be some coming off three and four year leases for a while. Other than people who must replace their auto every x years, or, perhaps, the new quintuplets make an E too small, I can't imagine why anybody would want to give one up. I know I'd be really POed if mine were stolen or clobbered in a crash. Good luck with your search.
  • bargamonbargamon Posts: 302
    With the pending new model release in a year, does it take away from the present model??
    many have written they will wait. What is the cost and is it worth it? Food for thought.
    My 01 e430 after 5000 miles has really jumped in gas milage. now at 20mpg. Should be interesting when air conditioning season comes. Only problems is incosistant gas gauge.
Mercedes-Benz E-Class Sedans - Page 52 — Car Forums at Edmunds.com
