I doubt if this is true, though I never sat or rode in a Sentra :-) To me, the best seats are in the 3rd gen Max, 5th and 6th gens are tied as second, and 4th gen is the least comfortable, though not really uncomfortable. I am 5'8" and find all gens roomy, both front and back.
My biggest complaint about the 4th and 5th gens is the rear axle suspension, which makes the car hop over bumps, such as highway expansion joints and parking lot speed bumps. The 6th gen uses independent rear suspension, but from what I heard in this forum, the revised suspension still needs plenty improvement.
My biggest compliment about the Max is its reliability (I own 3rd, 4th and 5th gens). If you keep up with routine maintenance, repair bills should be nominal (other than expected wear and tear). The 6th gen appears to have initial quality problems, since they are now made in the U.S., but hopefully they can be remedied in the near future.
My 02 Maxima doesn't have lit controls on the steering wheel. It took me about 2 weeks to learn the buttons. That's it.
There are 6 buttons. Two of them are small and in the center of the group, one changes the mode of the stereo, one cycles the trip computer. Then there are two big buttons to change tracks/presets and two smaller ones to adjust volume.
They are all easy to find by feel. If you need to take your eyes off the road to adjust the stereo, then you should not be adjusting the stereo while driving.
'17 Chevy Volt Premiere
Then go to another dealer that knows what it is doing.
Before removing spark plugs, recommend blasting spark plug holes with compressed air to remove dirt and sand to prevent them from falling into the cylinders (assuming engine is cold when you do this). When installing new plugs, always screw them in by hand by turning the extension with your fingers. Only when you are sure the plugs are threaded correctly, use a ratchet to tighten them. Make sure you use recommended torque because overtightening can damage the aluminum threads in the cylinder head. You can also use small amount of antiseize paste on the plug threads.
I recommend using the OEM plugs. They are pricey from Nissan dealers. The best price I found was from www.sparkplugs.com.
When removing the rear cylinder head coils, you will need to remove several brackets to access some coils. Make sure you do not drop any fasteners, which will be then hard to retrieve. Also, be carefull disconnecting the coil electrical connectors so you do not break them.
You absolutely MUST use Hess 93 octane and Mobil 1 5W30 or your engine will seize up and explode.
There! I said it. Now go out and enjoy your car and quit sweating the small crap!
At 60K miles I would recomment the following for your car:
engine coolant replacement
replace engine drive belts
four wheel alignment
replace brake fluid
change air and fuel filters
I would skip the 45 K service and do the above at 60K (with the exception of the air filer replacement, which needs to be done as required). Just my $0.02 worth.
I personally have had good luck with salvage yards. I was able to get a correct color center console in great shape for my 83 Mercedes 300 SD for $ 75. This console retails for over $ 700 from Mercedes dealers. I also got a full size spare with aluminum wheel in like new condition for $ 15. The rim alone retails for $ 450.
Try silverstarrecycling.com.
tires basically are shot
tires are the more important part of your car..get new ones and your handling in snow will get better... having traction control helps too..
