Has anyone heard differently or actually know what is in the GM bottle?
This vehicle is great except for the ride. It is by far, the poorest riding vehicle that I have ever owned. Every little bump or imperfection in the road is transmitted throughout the car.
I am not sure if the Gran touring suspension is at fault or if the Good Year tires are causing the problem. The tires are still like new. Maybe someone can suggest a fix.
Ron
If you have any other questions let me know and I will try to do better at getting back to you.
How its done:
Parts:
2 bottles of GM supercharger oil, GM p/n: 12345982
Tools:
Turkey baster
Short hose- needs to fit over end of turkey baster, and in s/c plug, about
6" long.
3/16 Allen wrench or hex bit
NOTE: Make sure that the engine is cool before proceeding.
1-Remove the S/C oil inspection plug. It is a black plug in the front of the
S/C 'snout' with a hex head.
2-Insert tube attached to turkey baster in hole, suck the oil out. It will
take a couple of times to remove all the oil, use a light to check. Dispose
of oil with your old motor oil.
3- Add S/C oil, fill to the bottom of the threads on the hole for the
inspection plug. It will take all of 1 bottle and most of the 2nd. Do not
over fill.
4- Reinstall inspection plug.
5- Check S/C oil level after driving for a day, add only if it's not to
bottom of the threads on level ground. Check S/C oil level at every engine
oil change.
body cars. I go back on Saturday, and I will ask them to look at my whole front end. My car as 73700 miles on it. The struts are original and so are the brake rotors. Any comment would be welcomed.
We may never know what the OEM fill is?
Did you do the turkey baster method?
Called my dealer and so far no response...
Fortunately the only thing "hurt' was the hoop!
10K or earlier, they shouldn't wear out, should they?
I have traded two Buicks (LeSabre and Century) with 135K and didn't even notice a looseness, let alone have to change tie rod ball joints because of looseness at 30K intervals with tires. Is it possible the store has found a profit center item that customers can be sold that they don't need?
Are there any mechanics with an answer to this?
What are the basic differences between the Century and the Regal(beside the engine)?
When I purchased the '98 the Century had bench seats and the shift on the steering column. I think the newer models have bucket seats.
Would appreciate all your suggestions.
They aren't cheap. Maybe the dealer is scamming my extended warranty company. They just replaced one a year ago.
Black '99 GS
140,000 miles
Oil change every 5K
Tires rotated and balance checked every 5K
Tranny fluid change every 50K
SC oil checked and added every 30K
Air filter changed every 15K
Cabin fitler changed every 30K
Front pads/rotors turned 50K and 100K
Rear pads 100k
Both serpentine belts replaced 100K
OEM Goodyear LS tires replaced at 50K
with Bridgestone RE730, on second set now
great tires for wet or dry roads
no snow here in Louisiana, thank goodness
A/C control panel faded out after warranty expired
bought new unit from gmpartsdirect.com for $230
replaced myself
The only other problem I've had from this car is the BCM unit, which I have no idea what it does other than the fact that the back-up lights dont' work when it goes bad. I've had this module replaced three times and now it's gone out again.
Those two things aside... I love this car!!
and the service manager inplies that that has allowed the lockup slip control valve to start acting like it's gummed up. It's been acting up since about 75K.
I'd recommend changes at 36 or 24K.
You folks have any advise? Thanks
My mileage dropped 2/3 mpg when I switched to the Bridgestone RE730s, but that was expected with a high performance tire my highway mileage during trips runs between 28-32 mpg at 70-80 mph... most of driving is combined city'highway as my daily drive to work is 20 miles of open highway @ 65 mph that mileage usually runs 22-23 mpg... there are some days when the adolescent in me comes out and really have to get down on the S/C... mileage then goes down to 17-18 mpg.
I didn't mention this before, since about 75K miles I have added a can of RESTORE each oil change (5K miles).
Preston
(current owner of a 95 bonneville SSEi)
The Series II engine may have a reliable track record, but I've become disappointed with the electronics complimenting this engine. With 4 months/6,000 miles left on the warranty, I'm seriously considering either getting an extended waranty or selling the car. The above mentioned repairs, if not under warranty, would have been $1,000+ out of my pocket (including diagnostic visits).
If there is a positive out of all this inconvenience, at GM's expense I've been able to 'test drive" three vehicles during these past couple weeks (GMC Envoy, Acura MDX and an Infiniti G35). I'd need a three sided coin to decide which I liked best (the Envoy was a pleasant surprise of luxury and performance).
Do all four tires match?
Anything appear worn?
- Power window switches
- Arm rests
- Floor mats
Service records available?
With the 6 digit odometer the "rollover" concern is no longer valid. But, this seems very low - I'd take a long, hard look at the car.
I've got a '95 Custom 3.8 w/140,000 miles that runs just great, btw.
Let us know how everything turns out.
Paul
Already the oil pan gasket changed due to a leak,
outside thermometer pickup changed, 2 mirrors repainted black due to factory never painting,
I rate this car JUNK--- it is surburban driving and rides like a Ford Bronco
I have a 2002 Buick Regal GS with about 17,000 miles. there is a squeak (kind of a chirping sound) coming from what I *think* is the suspension. Happens every time I go over a bump (large or small). Frequency increases when I have (say) a passenger riding in the back. Anyone else experience this?
I thought much the same about the Regal GS, which is why I bought it. However you do need to question the reliability. Without my ext. warranty I would be about $3000 out of pocket so far. (Dealership repairs)I'm at 65,000 on a 1998??? Thats about $1000 for every 10K over my factory warranty. My wife hasn't done any better with her 97 GMC Safari. I wouldn't own any GM vehicle without an extended warranty. The Envoy caught my eye... but knowing our current situation, I'm backing away slowly. By the way I got a Pontiac Grand Am for my free dealer test drive. Wife got a Yukon Denali with DVD ? go figure... better have her relationship with the service tech checked out : )
Next day I start the car and guess what? So...took the car back to the dealer and he replaced the ABS module. It's now a few days later and all is well.
Have the dealer replace the ABS module. From what I was told, the ABS module works alongside the traction control and air bag electronics and is most prone to becoming defective. If the dealer disagrees, then tell him you want the AIR BAG module replaced. If the dealer gives you any problems, call 800-4-A-Buick and ask for the name and number of the Buick territory manager for your area. Give him/her a call with the issue at hand - you're guaranteed to get some quick results.
I change oil every 3-4000 miles and rotate the tires every other oil change. It is on it's third set of front brakes, the back haven't been touched and have 50% wear. I am still on the second set of tires. They are Michilen X-Ones.
Obviously, I am a road warrior. They car still gets what I consider good mileage. I have busted 30mpg on trips and still do.
GM is trying to terminate the 3800 but is having a tough time doing it. Last time I checked, it will be in production through 2008. The 04 Impala and Monte Carlo get the SC 3800. It appears that the new V-6 might be the new 3600 they will be putting in the Rondevous next year. It gets 240-250hp without an SC.
