-mike
David
Paisan...me too, I hope this will resolve my recent issues. I am glad it finally died in front of my house, and not somewhere on the road. Thanks.
Let's say you pour in 5 quarts during an oil & filter change. You finish up, start the engine and let it run for a few seconds, and shut it off. How soon will the oil actually travel to its normal resting place anyway? My impression was that the dipstick may not show Full right after a change - i.e., you need to run the engine for several minutes and let the oil settle or whatever.
-mike
5 minutes will be more than adequate to allow everything to settle down.
I am interested on the upgrade. My '99 Passport is pinging all the time unless I use techron (every 3k miles) or use special grade fuel. That's enough for me. Unfortunately, my warranty already ran out. What is done in the upgrade? How much will I have to spend? Thank you very much in adbvance.
Mark
Pinging can also be brought on by dirty injectors. The techron may be cleaning them up to a state where the pinging goes away for a while but they soon get deposits building up again. It may be worth checking whether they need an "off car" cleaning.
It's good practice to run an injector treatment through every 5000kms (or 3000 miles) to keep the injectors clean anyway.
Your manual says 5 quarts?
-mike
The dealer charged me $88 for the part and $184 for labor $*!(*!_@#
Thanks for all the input
FWIW my symptoms were different than yours, it would take a long crank to start, then run fine. Your symptoms still definitely remind me of the IM gasket problem, which I have had twice.
Granted nothing could possibly be wrong with adding the right amount of oil back and 5 qts is the right amount. However, the problems come into play when you get sidetracked or confused. For example, did you really add 5 qts or did you miss one? Was that a big 5qt jug or the standard 1-gallon size? Did you put in only 4qts because that is what the OTHER family car takes? etc. Thus, the purpose of checking when you are done is simply a fail safe move.
As to when to check, I have noted that it can take over 30 minutes to get the last 1/2pt or so of oil to drain from a warm 3.5l engine. Thus, you can get slightly low dipstick readings on even a warm engine as all the oil has yet to make it to the pan.
However, I would gladly pay to have my car fixed than hear...we couldn't find anything.
BUT even if you were, the Powertrain Warranty is 5 years/60K miles. It specifically lists "Fuel Pump" and "Gasoline Fuel Injection Equipment". IMO the fuel pressure regulator is an integral part of the fuel delivery system, and therefore an integral part of the powertrain, and also could be construed to be part of the "Gasoline Fuel Injection Equipment", and therefore should be included in the Powertrain warranty.
I mean, if it's not part of the powertrain, what is it part of?
Suspension? No. (actually, most suspension parts are covered under the Powertrain Warranty)
Electrical? No.
Accessories? No.
Body? No.
Climate control? No.
Tires/belts/hoses? No.
Interior? No.
Everything that's left is the "powertrain", including the fuel pressure regulator.
Oh well, I'll get off my soapbox now.
But to you point, the regulator IS part of the fuel delivery system.
Thanks guys
Oh, well, that's life.
I'm no engineer, but it sure seems like a "FUEL pressure regulator" would be considered part of the FUEL system.
How much were you charged for this repair?
Don't really have too many choices, around here (Mineapolis metro area), there are only 2 dealers left.
They may have issues getting warrany repairs paid for by Isuzu? Maybe that is why they didn't go the extra mile? They identified the problem and fixed it quickly, there is something to be said for that.
Everyone else might want to pull out their warranty manual and read it before you too are in for a nasty, non-covered repair.
I have also had some front wheel vibration at 55 MPH for a while, which I attribute to my new tires. However I jacked up the truck today just to look around noticed the front driver's side wheel has some movement when I put pressure top/bottom? Not much, probably less than a mm, but still movement that could vibrate at speed? Maybe when they replace the steering column they took the wheel and other assembly off and didn't put it back right?
Nothing too bad, but since I have a 3 ton Jack, I have to get out and use it once and a while.
I think it is pretty weasely to stick stuff like that under the emissions warranty.
I wonder how you guys with the 2000s and later are covered for stuff like that?
What have others paid for this service?
On my way home from work and to the dealer afterwards, the transmission just crapped out? It wouldn't engage gears properly, and while shifting and/or @2500 RPMs it started to make that tape winding noise. At one stop light there was a low rumble and vibration, it was as if the transmission was slipping or a clutch (I don't know if a clutch engages with the brake?) wasn't engaging properly with the brake depressed?
I was driving with TOD activated the last few days and power drive on. Afterwork I turned both off because it stopped raining and gusting...power drive just because people were talking about it on the forum recently. The only thing I think might be that the electronics failed and the TOD and power drive didn't properly disengage?
At least it happened on the way to the dealer. I just hope it doesn't disappear after is sits overnight.
A DTC was caught and analysed by the dealer. Something to do with a range finder. There has not been a repeat and has been fine ever since.
-mike
I am hoping 1. That they can find something wrong (nothing worse than getting it back with "nothing found" on the repair slip) and 2. that it is something simple, like a fuse or short or something.
I have a bad catalytic converter? It is under warranty, but going to take a week to come in, so another trip out to the dealer in the next few weeks. Maybe that was causing the stalling here and there? That also may be the tape winding noise I just started hearing?
No answer on the transmission yet.
As to doing the front wheel bearing grease, many people DIY. However, it is a more involved procedure. For example, you have to pull the front rotor to get at the inner bearing, properly reset the bearing preload, get the hub nut off, etc. While not rocket science or real complex, it is way more complicated than fluid changes.
The catalytic converter is going to have to be done next week. Supposedly they will have to remove at least 1 if not 2 frame rails to replace it?
-mike
I am not sure about the thermostat and the warranty (I will have to check, but it does seem like a wear item), it was $137 to replace. They did it because I reported running hot this summer...the service manager wanted to be safe...since it is such a pain to get back and forth to this place, I agreed. The other option is to wait for it to overheat again and then deal with it. If it overheats again, I will try to get something off the repair cost since this one wouldn't have been necessary.
They also had to balance my tires, which is the 2nd time I have paid out of pocket at a different shop since the initial install. So for the $80 over the initial tire price, I could have bought a set of michelins which may be manufactured better and then offset the repeated balancing cost. My front end vibration is gone, which could have been the balance or the bearings? Either way I am glad it is fixed.
Total cost $590 OTD - $180 for above work, so I guess the 30K service was $410 OTD.
Travis
