jbuchanan
Lately, my car will not start and the check engine light comes on. The first time I took it to the mechanic, he plugs the computer in and it tells him to replace the crank shaft sensor. I take it home, drive it for a few more days and the same things happen. The car won’t start, the check engine light comes on. When I try to start it, no sound, nothing happens. I do this same routine for a few more times and eventually, it will start. So I take it back to the mechanic and he struggles with it and says that he needs to replace the ignition starter. So he did. I take it home, drive it for a few days and same thing happens. On the 3rd day or so, I drive it for over 20 miles, park it for an hour, come back and try to start it and it won’t for the first few tries. Eventually, it starts, but now when I press on the gas until it passes 2rpm, I release the gas, the car dies. I do this a few more times and it doesn’t improve. I let the car sit for 15+minutes, try starting it again and it does. Now the check engine light is on. The mechanic plugs in the computer, runs the diagnostic test, nothing comes up and when he unplugs the computer, the check engine light goes off. The mechanic sends the car home with me and says he can’t figure it out.
Have you heard of this happening before and what was the problem?
Please help, Fawn.
does anyone know for a fact if this would damage the engine? tia.
i'm under the impression, however, that higher octane gas give you more acceleration, not better fuel economy.
I was wondering about the use of regular vs. plus vs. premium gas. I am driving what turned out to be a real gas hog, a 2004 325 xi wagon (between 13-15 with the air-conditioning). It has the sports package. Was so worried about the gas pricing spikes, I dropped it off two days ago with the dealer to have it checked out. It has about 20,000 miles.
Among the problems I reported were: poor radio reception (both AM & FM stations), an occasional sticky handbrake light after putting the car in gear, some squeaking noise when I first turn the car on, sometimes, a back door that couldn't be opened for a couple of hours?, spongy steering, and the gas mileage.
Told me that nothing showed up on the computer, pumped up the tire pressure to 36 (front), 38 rear, the end.
Asked what to do about the bad gas mileage. Told the following: change the tire pressure, bad gas mileage with awd is normal, do a trial keeping records of either regular gas for a week, or plus, and see what happens. If you switch back and forth, you won't be able to tell the difference. He did say that with lesser premium fuels, the gas mileage would get worse....
I went to look at a Honda Accord Hybrid today, thinking about a trade-in. A friend said, I'd end up losing more money, and the money keeping the car, could be used to spend on gas. Then, there's a lack of maintenance plan on almost every other car than BMW.
Maybe, I could sneak in a secret chip to improve gas mileage without voiding the warranty?????
The "torque" is in the higher ranges, while there isn't too much of a rev in the lower registers, like city driving......
Thanks for your thoughts.....
Cargal (lost and found)
I hope for the best for the Southern survivors......
:mad: :confuse: :confuse: :sick:
Mr radio also is terrible and I am still telling BMW that the performance is unacceptable. My other car (a '04 Acura TL has a superb radio and cost me much less. I won't let the tell me (as they have) that it is performing to specification.
jbuchanan
jbuchanan
Isn't an alarm included????? (And do you think I can get an answer from my dealer??)
I did check battery and charging systems and it seem to fine. I also tried put the car in neutral gear and tried but didn't work. I think it the best bet would be starter motor or possbily solenoid. I am going to take my car to local shop this week and I have some quick questions.
Is there any way that I can start my car just to take the car to the shop? Or I have to call a towing car?
One other thing is: while trying neutral geat safety switch, I stepped on the brakes and it bulit up brake pressure so I can't seem to change the transmission to neutral. Can I release the brake pressure manually?
Thanks for the help.
Do you (does anyone) know the proper name/model for the integrated BMW alarm (tilt detector, motion detector, etc.)?
I have an annoying whistle/whine that happens at around 2,500 rpm when the accelerator is depressed (not when coasting). Seems to come from engine or front of the car. Get the mechanic shrug when I ask them to fix it. Not tied to speed, but rpm of engine and accelerator.
Anyone else have this....? It sounds like a wet finger rimming a wine glass.
Best Regards,
Shipo
If not make sure the starter wires are tight and belive it or not twist the battery cables,sometimes a little corrosion will build up between the battery post and the terminal.
jbuchanan
I own BMW 98 328i. I had a problem with my (inside) temperature controller of my car which they replaced for about $450. Now the temperature controller is bad again and the display of temperature is not working too. My dealer says this is another $450 expense but to me it looks like the same thing has gone bad, shouldn't it be under some waranty? Is it possible by any chance I can go some non bmw dealer place to fix this problemf or less? Thanks.
My check coolant light came on and the coolant was low so I put some in. A week later it came on again and before I could get to the next exit it was over heated and the hose from the radiator blew off. I took it to a local bmw mechanic and they were very nice and seemed really competent. They replaced the thermastat and the radiator and of course the hose. I picked the car up and it was fun for the 45 min drive home. I parked, went to do some errors later and the dang light is on again. 1/2 the reserve tank is full and it seems to be running in the middle of the temp. The heater does not seem to be working either. No leaks under the car at any time.
Could they have forgotten to reset the computer?
Could it be the sensor?
jbuchanan
jbuchanan
I hate to put this beautiful car in the hands of an unknown who might not do a really good job. please help
Notes:
- I've not exceed 65 mph (I put the limit reminder on to keep me honest)
- I've not accelerated beyond more than 3500 rpm
I am babying the car since it's new (break-in period, etc.). This mileage seems much lower than I should expect. Your experience?
1) Your engine isn't broken in yet. I've always found that the mileage on my cars gradually improved for at least the first 10,000 miles.
2) I'm thinking that you are driving too slow. My former 328i and 530i both got their best mileage well north of 70 mph.
Best Regards,
Shipo
