OW
Mine: 1995 318ti Club Sport; 2020 C43; 2021 Sahara 4xe 1996 Speed Triple Challenge Cup Replica Wife's: 2015 X1 xDrive28i Son's: 2009 328i; 2018 330i xDrive
I appreciate the advice. I am leaning toward getting a used engine with 80-100K miles on it - I've looked on sites such as car-part.com and prices range from $350 -$1000. I figure another $1000-$1500 in labor. Do you think I should stick with a 4 cyl engine vs 6 cyl? I am thinking the 4 cyl will be more cost effective and would theoretically have less issues since that is what is in the car to begin with. I have found a guy that works on various makes - not specifically BMWs - that is interested in performing the work on the side- my usual shop seemed to be extremely expensive. Any concerns there, or is the job easy for someone familar with that kind of work regardless of make? Thanks.
IDOC
A 4 cylinder swap will obviously be an easier procedure. If you are happy with the performance I'd stick with it.
The guy you found might do excellent work -who knows?- but it has been my experience that you are almost always better off using a tech who knows BMWs. The swap procedure is pretty straightforward, but think about it: Will that guy have the proper torque specs? Or even care? Does he know how to bleed the M42/M44 cooling system? Does he know that he MUST use BMW coolant? Will he bother to get the proper copper nuts to use on the exhaust system? You know what they say about a jack of all trades...
If it was Chevy-Ford-Pontiac, I'd say sure.
The job isn't all that difficult. Here's the step by step procedure for an E36 3 Series- the procedure for your 323i will be about the same.
Are the Bentley BMW maintenance manuals that are often suggested on these boards anywhere near as good as this?
Mr. Shiftright is correct, the Bentley manuals don't have as many illustrations, but I still consider them to be the best collection of reference material short of an official BMW CD.
Are those reasonably good? At what price?
I really enjoy doing what I can to my car, but I do need shop manuals to help me determine what's do-able, given the current state of affairs. Then, if I think I can do something, it's nice if the manual is complete & correct. Doesn't always happen.
The BMW Service CD is known as the TIS. It contains service procedures, torque specs, TSBs, etc. The problem is, BMW went online a few years ago so all the information on the newer cars are accessed through www.bmwtechinfo.com, which is a subscription service. The TIS CDs for the older cars run @$150. More info can be found here.
The online thing might not be all bad, at $30 per day, assuming it's possible to print off the relevant bits from the PDF file(s). One can print a lot of stuff in 24 hours.
I agree. I haven't had to use it yet as my wife's X3 hasn't needed anything other than scheduled maintenance. Often if you cultivate a relationship -and spend some money- at your dealer's service and/or parts department they will run off something you need.
Immediately before the warranty expired, I got the dealer to replace both control arms and just had the power steering pump replaced by BMW NA for free even though we were 10mos out of warranty and at 42K miles. You know what they say about honey and flies - it worked!!!
Anyway, I was going to replace the brake pads but anything else. I seem to recall something semi-major going out around 60K miles usually on these e46s but can't remember. I've got some time on my hands right now so no better time that the present.
And can you recommend any brake pads that will yield less brake dust than the OEM pads. Don't need performance as this is the wife's car and most likely baby-mobile for the first 6mos
Thanks as always
After 60K I'd keep an eye on the water pump, but it will begin to leak rather than suffer a catastrophic failure.
What you want are Axxis Deluxe Advanced pads; $88 for all four wheels from Zeckhausen Racing. Little if any dust and OEM levels of braking performance on the street.
Any thoughts on what to do?
I'm planning to drop it off at my mechanic later this week, but would like to suggest what he should look for (besides leaks, which he hasn't found in the past)-- PCV valve? oil separator?
Other than this, the car is great but I don't want to be adding a quart every month.
I change the oil (BMW 5W-30) every 7.5K miles... should I use Mobil1 0W-30 and/or increase the oil change frequency to 5K miles?
For about the last week or so, everytime I start driving my car after it's been sitting awhile, I hear a grinding noise (definitely not the ABS self-test) when applying the brakes. If I drive only a couple of miles and stop, there is a distinctive burning-brakes smell as well. However, as I continue to drive, the sound goes away and the smell also goes away, so I'm assuming things cool down with further use.
Yesterday I took my son to a friends house about 3 miles from home. The grinding was present and when we got there the smell was bad. At the risk of great pain, I walked around the car and touched all 4 rotors.. they were warm at best. I've done the same thing with a previous car and I knew when I came across a rotor with a frozen caliper because I was on the ground screaming and crying seconds after contact...
Would a bad wheel-bearing exhibit these symptoms? Any thoughts on the emergency drums doing this (I almost never use the emergency brake and it hasn't been on in weeks)? Any other thoughts?
My next step is to start pulling wheels/rotors to look for something. Unfortunately, I probably won't have time to do that until the weekend.
EDIT: The car is a 2001 330Ci w/133K miles
In my case, I've had two BMWs, and both of them managed to wear at least one set of pads at an odd angle, an angle that was able to allow the backing plate to start grinding on the rotor while at the same time holding the sensor far enough away from said rotor to prevent any contact and subsequent light. My guess is that you have a pad that has worn funny and is only partially contacting the rotor. Sounds like it's time for new brakes. ;-)
Best Regards,
Shipo
I just replaced the pads and rotors in August... being an average mechanic at best, I guess we can't eliminate user error as a source of the problem. Everything
has been fine up until now, though. I guess I'll know for sure on Saturday when I start pulling things apart.
Thanks!!
Best Regards,
Shipo
Visiting Host
Thanks again for your input!!
BTW, if I chucked a pad, I'll have to hold you responsible. I got those PBR/Axxis Metal Master pads you're always talking about.
I checked under the hood this morning, and everything is clean and the dipstick is reading "full".
I'll drop it off tomorrow and ask them to do a leakdown test (and pray that it's nothing serious).... just to be clear-- the leakdown test is to check and see if oil is leaking into the cylinders? If it is, how bad could the problem be (ie, is it fixable at a reasonable cost or am I looking at a very expensive situation)?
My rule of thumb is that if you carefully monitor oil consumption over the course of a few months and it comes out to 1,500 miles or more per quart, then forget about it, it's just normal wear and tear. A little oil burning is okay. But if it starts to drop regularly, from 1500 to 1250 to 1000, then you have to jump on it and figure out what's wrong.
Maybe this was just confusion on reading the stick? Happens to all of us.
i guess that's good news, but the only thing the mechanic could figure is maybe it's due to colder weather.
anyhow, we are going to try a thicker oil (Mobil 1 0-40) and keep monitoring it.
OW
i'll switch to the heavier oil and then if it's still an issue, go look for a second opinion.
I don't think that the switch to 0W-40 will make a bit of difference. There are only so many places the oil can go, and the mechanic has failed to find the culprit. His suggestion that 0W-40 is the answer tells me he doesn't have a shred of a clue.
This is what is lacking, nearly always, when I want my vehicle fixed. I can f*** (let's say foul) it up myself for free. If I pay the man, I expect him (or her) to know more than I do & to fix the thing more quickly. For this, I pay them.
Well. . .
I have any number of things that aren't right on my daily driver (and in my house) that I'd dearly love to let a competent (that's C O M P E T E N T) technician deal with. My car is rare (that's in, they discontinued it), so not many technicians will have ever seen one before. My bad. I won't do it again.
The fact remains that a competent mechanic is worth his/her weight in gold. A $793 repair diagnosed (yeah, right) by the Nissan dealership becomes an $87 fix at the (trusted) shop.
Works for me. If I end up with a BMW, it won't be before I determine which independent shops nearby are deemed worthy. Since BMW has been around awhile, such databases actually exist.
YMMV.
for better or worse, I did a lot of searching on other forums and only found the following possible culprits for excessive oil consumption: valve cover gasket, valve seals, and oil separator.
I also found that some people (with higher mileage cars) have switched to this heavier oil and it has slowed the consumption.
So, based on this and the suggestion for the leak-down test, I asked my mechanic to do this test and check all of these things as well as anything else he could think of.
When he came back with nothing, I asked him to go with the heavier oil. I figure at the least, it may work (it may not... but, you know what they say about what you read on the internet!).
I'll keep you informed. (for the record, I'm at 85,020 miles and dipstick is reading at the full mark).
This cranky (no pun intended) oil separator is a known BMW issue.
IDOC
My biggest problem which has yet to be solved by BMW is my clutch. Everytime I release the clutch, it makes a squeaking noise. If I have the radio off or low, this sound drives me nuts. I have come to realize that this noise is the pedal not the clutch itself.
Another interesting problem arose a few days ago. After I washed my car: everytime I released my clutch my air conditioner would turn on from its off mode.
Has this or anything similar happen to anyone else?
LIST OF OTHER ISSUES:
- Sunroof Colapsed, was not able to close, looked sunken in for days.
- Passenger seat, had 3 huge bumps on the bottom part of seat. Very unattractive
- Random display of messages on the cars on-board computer display.
I think it is a function of the emissions system; my wife's 2004 X3 2.5 does the same thing.
Have any of you experienced this particular failure?
br
ManualGuy
I'm leasing mine and it goes back at the end of the summer. It will fortunately never be out of warranty during my time with it.
I have never owned or leased a BMW before this one. I am quite surprised by the emotions that this car evokes in me. So I would expect irrational thinking on my part as far as this car is concerned and I keep this well past the warranty period.
Didn't realize it.. but, that is the first trip to the dealer since the 15K oil service.. Just over one year...
Did you ruin your car by putting regular anti-freeze in there? No, that would be unlikely, especially if it has only been in there for a short period of time. That said, you would be best off if you had the cooling system flushed and the proper coolant re-added to your car.
FWIW, if you are on a budget, you can also use the Zerex G-05 HOAT coolant (I've found it to be available at most NAPA stores). http://www.valvoline.com/zerex/pdf/Zerex_CoolantChart.pdf?coaid=1B5D1AEA1AFC
Best Regards,
Shipo
The car is a '02 325ixT with 45,000 miles
TIA
While I am not technically oriented, being a member of CCA for many years and reading Mike Miller's column does me good, and of course I also benefit from reading many postings here by those very knowledgeable people.
OW
If he replaces one.. then, you'll go back for the other one... If he quotes you a price for both of them, you might find another place to get it done cheaper..
Either way, I agree... wait for the other one..
I was having front struts done once... The left and right were two different struts.. They sent two left struts, and the repair shop put the left one on, and told me they'd call when they got the proper right hand strut.. Every strut that the distributor shipped was the wrong one.. It turned out they only had left struts.. I never did get a matching strut... :surprise:
