Low aspect ratio tires are fairly susceptible to impact damage - pot holes, curbs, etc. What happens next is that the air gets let out and the tire runs some distance without air pressure to hold it up, rapidly destroying the tire in the process. Ultimately you wind up with 2 sidewalls and a tread.
It's also possible that a simple puncture could do the same thing.
When you get the tire replaced, have them look at it to confirm.
Hope this helps.
By all means, show it to the BMW dealer. However, be aware that many vehicle dealers are not tire experts (many tire dealers aren't experts either!) Hopefully, he will have enough experience to know what he is looking at or at least know enough to admit he doesn't know enough.
You might also take the tire to another shop and get a second opinion.
Hope this helps.
It's much less noisy at low speeds--almost imperceptible. But at 80+ it's very apparent. The only good thing is that it seems to take higher and higher speeds for it to come back--today I was at 85 and couldn't hear it as much. The key seems to be sustained high speed (I could only briefly maintain 85 today due to traffic). Anyway, is this normal? Is the transmission breaking in?
For example.. a typically equipped 2003 325i that stickers for $34,895 has an invoice price of $32,025 minus the $2000 incentive, results in dealer cost of $30,025.. So, you should be shooting for about $500 over that, or around $4500 under sticker, depending on how well optioned the car is.. If it stickers for less than that, figure a little less off sticker.
regards,
kyfdx
There is large black plastic cowling that fits beneath the engine. I banged it up on some speed breakers and it started dragging on the pavement. I simply reached under the car and pulled it out. (It now sits in my garage.)
Does this cowling really do anything in normal driving? I imagine that it helps to keep ice, snow, and salt away from the engine in cold climates, but I live in Georgia and don't even take the car out in cold weather.
Do I need to replace it?
ksso
I still want to know if anyone else's car has the high pitch whine mine does while the car is at idle or low rpm? I can hear my car "whistling" from inside my house while it warms up outside, it's that loud and annoying!!! The dealer says the high pitch is normal because of the all wheel drive, my audi a4 advant does not make that noise! Please someone else tell me they have this noise.
FWIW, the noise does not sound normal, however, I haven't owned a 325xi, just a 328i and a 530i. To help your dealer, I might also suggest that you try to isolate the sound.
Is it coming from the front (engine and accessories) or the rear (electric fuel pump) of the car?
Is it coming from the transmission (do you have a manual or an automatic)?
Is the sound louder above or below the car?
Is the sound louder of the hood is opened?
Is it coming from the actual engine?
Is it coming from the accessory area (ie. power steering pump, A/C compressor...)?
Good Luck.
Best Regards,
Shipo
Since BMW tends to retain good resale value, you may want to trade it in while it is still "young".
Best Regards,
Shipo
Did you purchase your BMW at Park Ave? If you don't mind me asking!
thx,
Richard
I then took the car to a BMW dealership thinking that local garages might not be able to find out the cause of the problem. The dealership kept my car for more than two days. They also suspected the idle valve because the computer was logging that as the problem unit. When I told them that it already has a new valve, they pulled out one from a 'good' car, put that on my car and tested. Still the same problem.
They checked loads of other things that can go wrong. Finally said it looks like the control unit is faulty. Will need replacing and is coded for the VIN, so has to come from BMW directly. Will cost me GBP600. Now that is a lot of money. Anyway, I took the car from them 'coz they said if I disconnect the wire from the Idle Valve, it runs fine. So I did. But then later on, I reconnected the wire on it. And the car has been running fine after that... for about 100 miles.
Then the problem happened again - Just once. Hasn't happened since, I've driven about 20 miles after that. (I drive short distances to work).
I am very confused. Don't even know if the dealership is right in saying that the control unit is faulty, 'coz it runs fine most of the time. But obviously there's a problem. It's specially risky driving in slow traffic when suddenly there's more gas burning and the car jumps ahead. Thinking of contacting BMW directly now. Has anyone had similar problem before and what fix was made? Any help would be greatly appreciated.
http://bmwwhistle.tripod.com/index.htm
It's a tripod account, so sometimes it runs over it's limit, but it restores within the hour. We would appreciate anyone's help on this situation!!!! Ahhhhhh!
2) It sounds like one of the devices driven by the belt (A/C compressor, hydraulic pump, radiator fan, one of the three idler/tension wheels or the alternator*)
3) Your service adviser is deaf
* Alternator!?! I just checked my 530i and found that it had a belt driven alternator! What’s so strange about that? Well, I thought I read back in 1998 that BMW had combined the starter and the alternator into a single unit and mounted it near the flywheel. So, why does my 530i have a belt driven alternator? I cannot remember if my 1999 328i had one or not. Could one of you kind souls check your E46 3-Series and see if you have one as well.
Best Regards,
Shipo
P.S.
After thinking about it for a moment, it occurs to me that both the alternator and the hydraulic pump are on the left side of the engine where it seemed your noise was concentrated. I would suspect either of those two first.
