I am guessing that the problem is that something has become loose. Once things heat up and expand a bit the problem goes away. Anyone else have similar problems or advice.
I checked the transmission fluid when I got to work, it had air bubbles in it. Is this normal? Has anyone else experienced this kind of behavior? If so what was the fix? TIA
Joe
I suspect something is not quite right with the fuel injection system or the car computer. It may be running too lean because some sensor is feeding wrong information into it. Then the only way to get more power is to give it more gas, which will kill your gas mileage. I had this problem years ago with a VW car - it was never fixed. Do you need to push hard on the accelerator to make the car accelerate normally?
Seems to me that for some reason the fuel/air ratio is off in your car. This can greatly affect fuel consumption - usually negatively. There is a number of sensors on the car that can be feeding wrong info into the computer: throttle position sensor, airflow sensor, temperature sensor, altitude pressure sensor, etc. If one of the sensors is feeding the wrong signal voltage to the computer, but within their normal performance range, the engine light may not come on. Also, performance of the EGR circuit may be affected if the temperature sensor indicates that the engine is cold when in fact it is warmed up.
Joe
You may want to visit the following website: www.pureoil.com. Click on "Where to Buy" and you get a list of stores that carry Purolator oil filters.
Joe
I have always used Nissan oil filters in my 98 Maxima SE and never had any problems or lifter noise on startup. I live in Florida, so I do not have experience with really cold starts.
I use the cheaper version of the Purolator oil filter in my 95 SE V6 Nissan pickup and have no problems.
What oil do you use in your car? I use 10W30 Castrol GTX.
Bill
What gives is that the OEM Nissan oil filter is junk when it come to stopping cold start clatter (or in your case cold and warm). I claim that the Purolator PureOne Oil Filter with its silicone anti-drainback valve prevents this. I'm still trying myself to locate one. p100 in message #1457 claims to have found it on-line at Discount Auto Parts but when I went there, no luck. See my next message to him.
Joe
I went to Discount Auto Parts on-line and all I was able to come up with for my 2003 SE was Nippon, Bosch, Denso, and Advantex oil filters. Please paste the URL for the exact page at Discount Auto Parts that shows the Purolator PureOne filters that you found. I even used the search feature for 'Purolator' and came up nothing. Are we talking about the same Web Site? Again, please send URL for exact page. I'M GOING TO FIND THAT FILTER OR I"M IN THE TWILIGHT ZONE!!
Joe
Or else you can just wait and see if the SES light disappears. There is no sense in disconnecting the battery - if the problem is not repeated for a few days the light will go off by itself. I think you should try to get the code ASAP precisely because it may go off and you won't know what the problem was.
Just came back from Autozone. Got the code pulled for free. It's Oxygen sensor Bank 1 Sensor 2. Says "slow response" and also "bad voltage". Autozone tried to pull up the part number and they don't have it, says dealer never released it. Also said it's easy to put in. How much did it cost for you to get a new one put in at the dealer? Guy at Autozone said it's really easy, he showed me the part from another car and it goes in just like a spark plug with a wire connecting to it. Only difficult part is raising the car to get in behind the engine because this senser is between the cat converter and engine. I'm calling the dealer next to get price on new sensor. Will update post just to fyi people in case same happens to them.
I didn't have to pay for my repair - it was done under warranty. It took very little time to install - so I assume it is an easy job.
A word of caution - ask the dealer how much the whole thing will cost, and if at all practical (inexpensive) do it there. Some Y2K cars (Federal emission) have 3 sensors, the California emission cars have 4. Then they switched to 4 for all cars in 2001. On top of that each sensor has a different part number. So to play it safe - let the dealer install the correct part.
Also - I just had a look as the Service Bulletin - after replacing the sensor they need to reprogram the ECM to prevent this from happening again. Definitely worth going to the dealer. Also, if you print the SB (available at maxima.org) you may get this done for free as it is a known problem with the rear O2 sensor.
According to one site I found the PL14610 is available at PepBoys.
i had noise coming from the front end and the hood seemed to flutter. I brought it to O'BRIAN NISSAN in hawthorne NJ, they did a great job. the guy behind the desk grabbed a bunch of tools and went out and fixed it on the spot. This is what customer service is all about, a job well done.
the sales department, that's a different story, just terrible.
Pep Boys On-line does not sell the PureOne, P/N PL14610. You have to get it from one of their stores and there aren't any near me. In message #1457 you said you saw it at Discount Auto Parts On-line. Can't you just copy/paste the URL for the exact page, in a follow-on message? Thanks.
Joe
Anyone ?
Sorry, I misunderstood your post #1457. Thanks for taking the time to check out the PL14610 filter at your Discount Auto Parts stores. Can you imagine the frustration of you finding it in two of your stores and I can't find it anywhere locally or on the World Wide Web! I even have Discount Auto Parts stores all around me and none of them have it yet. How can they have it in Florida and not here. That makes no sense to me. Anyway, I think they will eventually get it. I'll just have to wait. Thanks again for your replies.
Joe
Initially I wanted the K&N air filter, so that I can reuse the air filter later. But on reading the forums at maxima.org & the instructions on how to re-oil it, it become apparent to me that I am likely to screw up my MAF sensor after that. And I have to go to dealer for repairs.
And no increase in performance & abt 6 times more expensive than Nissan OEM air filter, possibly waste time at dealer, what gives ?!
What is the point of having it then ? so that I can get more trouble with my car/engine ?
His the the solution to all.
1. After they tell you they cannot find it, and have checked the tires and wheels numerous times, do the following.
2. Document your visits. Then take the FRONTS rotors off, and have a certified mechanic, NOT THE DEALER, put it on a lathe, and test for runout, not just on a micrometer. You will most likely find that after the tires and wheels, it its a crapy, OEM, front brake rotors that is either out of round, or whose runout is terrible. Replace them with a quality rotors (NOT OEM) such as a powerslot rotor. You will notice IMMEDIATE IMPROVEMENTS.
Hope this helps.
One reason why rotors get distorted is improper tightening of lug nuts. You have to torque them to specified torque, not have some kid at some tire store use an impact wrench and tighten one lugnut to 200 ft-fbs and the other four to 65. I do not allow anybody to tighten my lugnuts with an impact wrench. I ask for the lugnuts to be handtightened and torqued to proper spec.
Incompetent wheel balancing and shoddy tire quality are the biggest problems causing vibration and shimmy. When was the last time you saw somebody balance your tires to 0.1 oz (approx 3 gram) accuracy? And when was the last time you had them mount the wheel on their balancer using a flange adaptor instead of a centering cone? Flange adaptors made by Haweka Co. are used by professionals to properly center the wheel by its lug holes on the balancer. Professionals also claim that 0.1 oz accuracy is required for proper wheel balance. Yet almost all commercial balancers are set to 0.25 oz found-off mode (or 5 gram for metric weights) because standard wheel weights come in .25 oz or 5 gram increments. Nobody bothers to clip weights for better accuracy anymore. Given these choices, you are still better off with 5 gram roundoff vs 7 gram (0.25 oz). Remember that only metric wieghts come in 5 gram increments.
I have wheels on my vehicles balanced wrong so many times that I am positively disgusted. I finally found a few places that can do it fairly well and none are tire store chains.
