If I push the button to get air on the face, all I get is air to the windshield and feet; ...and the same for the rest of the buttons...
Thank you for any tips!
I start the car and the light is off. The alternator is producing 14 VDC. With air, radio, headlights on-car idling- the voltage reads 12.9 vdc.
The only time the car has had this problem is first start of the day. Any suggestions would be appreciated!
Had no problems until I brought car in for detailing and some paint work, they unhooked the battery during the work.
It would be very nice to get a separate forum started on OBD2 issues. All specific error code questions could go in there.
Scanning through the posts in this forum, I see that the ignition coils are a big repeat item. Hasn't happened to my car yet, but it makes me nervous...
What I haven't seen is anyone's assessment of what fails in the coils. Is it the insulation or does the part fail electrically? My point, as always, is - can they be repaired without replacing?
Would appreciate some discussion on this.
Since I have a 95 SE, it would seem that I don't face much risk of it. Is that right?
Eric
pls help
p.s sorry for my english
http://replacement.autopartswarehouse.com/parts/autopartswarehouse/quote.jsp?yea- r=1995&product=P2020-131380&application=000639967&part=Relay&dp=false
12.65V is a bit low, you want your alternator to be at around 14V.
Well, recently the car began to struggle starting. Sounded very sluggish, and it turned over slower, and slower, then wouldn't start. I figure either the battery or starter died. I took it in to a mechanic and as it turns out, the starter needed to be replaced, battery was still good.
I start the car up, it runs fine. The next few times I start it up, its turning over, but is struggling to start. I can feintly smell gasoline, and the car eventually starts. Once it starts going, it runs fine. Sometimes, it won't start, I need to give it a rest, and then try again after a few minutes.
I took it back the mechanic, he replaced the spark plugs and occassionally, the car would start just fine but still struggling other times. He thought there was an electrical problem, specifically with the fuel injectors, but couldn't pinpoint it. Diagnostic came back that everything was okay. I noticed the check engine light doesn't come on anymore when I turn the car on prior to starting it.
Thanks for reading. Any suggestions?
Im not totally sure, when I attempt to start the car, I get nothing at all..no noise or anything..the car seems like it has NO power whatsoever..radio..windows..locks..nothing
it seems like something is draining the battery, I got a new one yesterday, and the car started up fine, after I turn the car off, the radiator fans keep going, and thats the same thing that has happened everytime, so I always end up knowing it wont start after those fans stop.
