If that was in response to my comments, the resetting sound heard at power up does seem to be just that-"normal". My friend's inst cluster that was just fixed 2 weeks ago makes a slight sound at initial power up when the tach pointer sets to "0", just like mine does. But you should not hear a noise coming from it when the engine is running. My friend's emitted a noise continuously when the engine was running. That is NOT normal. His didn't start making a continuous audible noise until he had 15K miles or so on it.
Other than a TrailBlazer? Olds Bravada, GMC Envoy, Buick Rainier, Isuzu Ascender. Nothing else compares power- and price-wise for a full perimeter frame, truck based mid-sized SUV (or Passenger Truck as I prefer to call them).
canddmeyer stated: "Toyota 4Runner is an alternative. I believe its the best vehicle for the $ in this class, & a V8 is optional. I currently own a 1997 Blazer, but due to owners statements here there won't be a replacement Chevy in my future. While I'd really like a Tahoe, my needs don't call for anything bigger than a midsize SUV."
A 1997 Blazer doesn't even compare. These are well past their second year of production and the majority of glitches are resolved. Plus, GM stood up and took responsibility for any engine block sleeve problems in the initial first year batch without us even asking for a warranty extension. But a Toyota 4Runner may be an OK alternative too.
Didn't Toyota have a serious engine oil sludging problem they took several years to finally admit to? Just remember, even Toyota/Lexus has service departments that are kept very busy. I saw one of the sludged up engines apart last time I visited a friend that works at a local Lexus dealer. What a mess in a 3 year old engine.
Dealership is going to love this one, we are now their "favorite" customer after starting a Lemon-Law claim due to the AC system. Mysteriously soon afterwards we got a call from a GM rep stating that they have found the issue with what is causing the AC problems in the TB's and they had a truck come to our house and replace a module of some sorts , end of claim for us. We are now called Mr and Mrs McKinnon by the dealership service staff and get first priority. This after my wife laid a verbal whooping into the General Manager about service and the service department lax attitude to our problems. Mind you losing the AC in FL in May is not a pleasant thing when it is the family ride. We have had the TB in the shop every moth since Jan for the AC going out as others have described in this forum. In April they had to replace a connector too as it was partially melted! I knew that was not the root cause.
We sure like this vehicle but this is the biggest POS GM we've ever owned. We had a wiper problem with them not working 2 months after we got it, now this again. I smell a lemon law re file again!
If anyone wants a list of the parts "changed" for the AC problem we had, email me at dmckinnon@asttechlabs.com and I'll get back to you as soon as I can.
Don McKinnon
2003 TB Ext
Dean
You only need to connect the wire under the hood if you require 12 volt power to your trailer. It's not necessary for 4 wire trailer hook ups."
Huh? The standard 4 wire hook-up under the dash includes 12 volt power thru the brake controller to the electric brakes on the trailer. What does this extra wire do? Still confused. My controller works fine. Will have to ck and see if I have an extra wire in my engine compartment.
Air Conditioning (A/C) Inoperative/Intermittent, A/C Blows Warm Air (Replace A/C Low Pressure Cycling Switch) #03-01-39-007 - 05/29/2003)
2002-2003 Chevrolet TrailBlazer, TrailBlazer EXT
2002-2003 GMC Envoy, Envoy XL
2002-2003 Oldsmobile Bravada
Condition:
Some customers may comment that the A/C system is intermittently inoperative or blows warm air.
Cause:
An intermittent inoperative (open) A/C low pressure cycling switch may be the cause. This is an intermittent condition and temperatures may play a critical role if the vehicle is in the failed mode or operating as designed.
Correction:
Make a service appointment
OR
HVAC System Inoperative for a Drive Cycle, Poor HVAC System Performance in High Ambient Temperatures (Update HVAC Control Module Software) #02-01-39-005 - (09/23/2002)
Condition:
Some customers may comment about no cold air from the heating, ventilation and air conditioning (HVAC) system during a drive cycle. This concern may occur at any time during the drive cycle and at any temperature setting. The HVAC system operation returns to normal after the vehicle has been keyed to off and restarted. This concern is intermittent and most likely to occur on hot days. This concern may be found on vehicles equipped with manual (CJ2) and automatic (CJ3) HVAC systems. Other customers may comment about poor HVAC system performance in high ambient temperature conditions. This concern may be present in automatic (CJ2) HVAC systems only. An HVAC control module software update was put into all production vehicles beginning in September 2002. Vehicles built in September 2002 and earlier may need this software update.
Correction:
The experience at the dealership wasn't an easy one. We had agreed on the price, but their mechanics are on lock out. The car was poorly prepared. Tires unballanced, alignment off, engine light and 4x4 light came up. In any case, it was all fixed easilly. Engine light was caused by the fuel cap.
I don't know why car salesman need to lie, even if the truth is not that bad? It seams that telling the truth scares them, even if that truth is quite fine. I have received the 3.42 although I had asked for the 3.71 axle rating. But I asked for the 3.71 after i had ordered the car, and I was too late making the change. But instead of giving me that story, the salesman tried to convince me that 3.42 was so much better and could even tow more then 3.71. I had to tell him no to even try.
They were also very surprised when I toom by air thingy out to check the tire pressure, which was at 37 and 38 PSI when it should be at 32. They were also surprised when I checked the trailer wiring 9which was fine). Lovely when you hold the knowledge (thanks to this board).
What do I like I (remember that I had a one week rental on a 4runner, a explorer and a Grand Cherokee in the past 2 months)
Great ride. If you don't like the ride, you don't want a truck but a minivan or a CUTE-UV. This ride is outstanding for a truck. Beautiful vehicle. The seats are very comfortable (unless you use to drive a BMW). The inside finish is excellent (except for a few exceptions). Lights come on and off by themself. Power remains on for 20 minutes inside after you turn off the engine. Very quiet (those ventvisor do a great job). Engine is very quiet and very powerful 9no problem with my 3000 lbs trailer). Doors lock and unlock properly when you start and put on park. Sound system is fine on the LS for the price. Rear and front wipers work excellent (up to now...). No vibration on the gaz pedal (but it isn't cold yet...). Gaz mileage is better then expected. It cost me only $10 more for a 600km drive (about 420 miles, and about $7.20 US). Not bad for a truck this powerful. This is not an off road vehicle like the Jeep or the Toyota, but it is much more comfortable on the road. It is powerfull, but will not take a Civic at a red light. Its power is constant (I guess they call it torque...).
What I would suggest GM improves for next time:
Don't start on a new vehicle, but improve the TB like Nissan has done on the pathfinder, which is now a perfect vehicle (hope they don't Ford it up with their new model). Add the little things that you expect in a vehicle of this price. Look at Toyota and the new Sienna which has all the goodies of other minivans (and I mean all). The difference between low end and high end should be limited to leather seats, navigation system, rearward drive assist (cameras), automatic ac and heat, etc... things like compass, outside temperature, leather steering wheel should be included. Pls remove some functions from the flasher stick. G that thing is busy. Hope it doesn't break...
But wow, I love this vehicle. GM has a real winner if they can make it reliable. Can't wait to take my trailer out.
BTW, there is a special letter gone to Canadian customers for the engine on the 2002. GM is taking responsibility for the engine break up up to 160 000 Km (100 000 miles).
Also.. my first UH-OH's! Well.. this past weekend I experienced my first set of problems at 1600K on the odometer.
1st.. My steering wheel control volume control button has begun to intermittently fail. It will sometimes work ONLY when it wants and at other times, it will not work at all. Very odd indeed considering that the other buttons on the steering wheel will work?? After letting the vehicle sit for a few minutes and then restarting, the problem seems to go away? Anyone else experience this?
2nd... Wandering mirror trouble again? My driver's side mirror has started to do some very odd things.. I have the "curb view" feature activated on both mirrors because I wanted to make sure that I did not experience any issues with repositioning like I had in my 2002 Envoy. For starters, once I shifter into reverse and the mirror tilted UPWARDS towards the sky, then when shifting back into drive, the mirror went back to it's original position? I was a little spooked by this.. To correct the problem, I fine tuned the mirror while in reverse and so far it's held the correct position. Additionally, I've noticed on several occasions that the driver's side mirror would be off by a hair when returning to it's original position, so once again I would fine tune and hold down my memory #1 button. Does anyone know if GM has done any additional fine tuning to correct this problem? My vehicle was manufactured in March 2003, therefore I know that it's pretty current in terms of past-posted software calibrations and mirror actuators.
3rd... Hmmm.. sometimes I notice that when I go over 70 mph, I get that awful steering wheel shake from the tires as if they are unbalanced? Some days are worse than others but today was by far the worst! I had both hands on the steering wheel and it felt like I was getting a arm massage? I have yet to check the wheels to see if maybe a weight had been thrown, but I will. I am guessing that maybe the wheels developed flat spots in them while sitting on the dealer's lot? I am kinda afraid to have the dealer rebalance the tires because they don't use the same weights from the factory, plus if they do what they did on my 2002 Grand Am GT, after they removed the original weight, there were severe visible scratches from where the original weights used to be. It was not appealing at all. Can I continue to drive the vehicle (if the weights are intact) and will the flat spots eventually become ROUND again? Ha, ha.
HELP!
IExplore2000
The cover can be anything, chrome plated steel, aluminum - it doesn't matter except that aluminum will dissipate heat better.
Dean
This is a PCM programming issue the gurus at GM need to work on. I am afraid though it may be just the nature of the beast. The pressure WILL get high with +100 to 110°F air moving across the evaporator. Kick in the engine cooling fan duty to 100% before the pressure gets too high to move more air across the condenser coil would help keep the high side pressure lower, but then everyone would complain about fan roaring noise.
Todd
On another note, I've started getting postcards from my dealer telling me I have not complied with the instrument panel/shift override recall. Has anyone been successful in just doing the instrument panel but not the override?
Frank
Just like the theater lighting. That is all controlled by the BCM pulse-width modulating a solid state relay from 100% full on to 0% off over a preprogrammed time, and they could set it up to turn down and off in 2 sec or 2 min.or anywhere between. What would be nice would be a user-adjustable delay. I actually thought they did that on the TB to do a soft turn on and turn off so the bulbs won't burn out so fast!
A TSB is just a repair bulletin for a known specific problem which your vehicle MAY have. They are written to help a technician find the source of the problem. So the answer is no, you will not get a TSB done for free after the warranty is up. Recalls are something totally different.
I am working on a few aftermarket upgrades to enhance performance, and if anyone has done this already, I would like some feedback. Three in particular. Airaid intake, Jet power Module, and Borla cat-back dual exhaust. Yea, I know, middle age trying to be a teenager again, but these are a blast to drive. Anyway, hope you all have good luck in the future with your vehicles. They are fun to own.
Recall no. 03012
Part is here-sop
performed 03012 recall
V0994.3
Recall no. 01065
Programmed TCM
V0789.5 4941
Recall no. 03013
Installed plug
V0995.4
(plug p/n 15107205)
Recall I1191
Void
Only recall 03013 required parts. That's the one for the theft protection. The dealer told me the computers were updated to the latest 2003 specs, which definitely included firmer shifts in the transmission. (Noticeable and improved). Don't know if that was one of the recalls or a bonus freebee. If you want me to I can get more detailed info from the dealer and post it. Let me know.
They mounted the antenna on the drivers side near the windshield pillar,mast towards the dash.
Two wash mitts.
Some good car wash detergent.
A clay bar kit
A good polish and some microfibre towels.
A good wax.
Some tire cleaner.
So, any tips? What products have you had good luck with on your Envoy/TB? I have an Indigo Blue exterior.
Any tips for interior work?
thanks,
-John
Lurker01 - love the clay bar :-)
Mothers California Gold Clay Bar kit also comes with Carnauba Wax.
02 Envoy W/16,000 miles - paint as good as brand new. No problems, no complaints, no whining.
Todd
I just looked at alldata.com, but they didn't show any of the TSB's/recalls on the 2002 Envoy that have come out since Jan. 2003, including the recent shift override/instrument panel reprogram. I'm not a paying subscriber though. Perhaps one has to pay to see the most recent list. Or does it take a few months for something to show up on the list?
Purchased a rubber rear floor mat at Walmart (I chose black, but color coordination is optional). Measured the "dead pedal" space height and width (lower & upper width are slightly different). Cut out a sized piece from the center of the rubber mat (slightly undersized to avoid having shoe soles catching on it all the time). Applied some narrow strips of heavy duty carpet tape near the edges and top center. Then installed the rubber "pedal" to a cleaned carpet surface.
I've been using this "dead pedal" for almost 3 months now and haven't encountered any problems with it. With the way I cut the rubber mat piece, water on my shoes drains down the mat grooves to my WeatherTech floor mats. Large ribs on rubber mat piece provide a comfortable, non-vibrating place to rest your left foot while driving and it sure is saving my carpeting from rapid ruin.
BTW, hit 5,000 miles on my '03 Bravada (8/02 build; 10/02 purchase) this week. Still no problems to report. Warm weather commuter mileage holding steady at 15.2 mpg.
Ordered the Borla system for my TB this morning. Plan to document the install with pictures and take before and after sound level measurements with a sound level meter. Get to do it after hours in the air-conditioned comfort at the Lexus dealer my friend works at. (If I can get over the anxiety!)
