In the article, it states that JD Powers rates DCX 15th in initial quality - - 2 spots *below* Chevy!
Now, I'm not saying that being rated 13th in Initial Quality is anything to brag too loudly about. I'm just trying to point out that we all could've paid a *lot* more money and been having the same sort of "glitchy" electrical problems that many people on this board seem to be experiencing.
So Take Heart: The next time the mirrors wander on your TB/Envoy/Bravada, just smile to yourself and be thankful it didn't cost you an extra $20k for the pleasure of returning to your dealer for service for the gajillionth time.
Windshield-wiper woe may force GM recall (Salt Lake Tribune)
Saw that one coming. As I predicted we will all probably be getting recall notices about the water that gets in the wiper motor cover.
18% spelling errors just in that sentence!
SHOULD be better!
GAM
From my experience these "programs" have nothing to do with quality. They define it as a process and focus entirely on the paperwork. As long as you've documented your processes, you can get be ISO qualified, even if the processes suck and the product falls apart (actual truth at my old employer). It's just more bureaucracy. . .
They obviously haven't found it.
(actually my 03 LTZ just has an annoying door rattle at 3600 miles, that's it)
By the way, the water leak was on the E column on the passenger side. This is a hollow column and it filled up with water from the outside via a poorly sealed seam. Once the water fills above a column insert hole above the floor level, it starts to leak and the rugs soak up the rest. This is a factory defect caused by the robot arm that does the sealing on that side of the vehicle. The dealer knew exactly what to do when I showed them where it was coming from.
Anyway the new Envoy has a 3.73 gear ratio. Any pros or cons about this. I don't know much about the difference.
"Replace front sway bar link rods (loose rods causing noise)" R&R front stabilizer shaft at control arm. Link kit 12479231 and 12479233. I just drove to Ottawa and back 1100 km (684 miles)and I have to say I really enjoy this truck. For those of you wishing to do business here....definately Toronto is the decision making place to be.
P.S. Even though this Envoy was $1000 more MSRP, it costs us $2000 less with all the huge rebates going on. Wow!
As much as I like driving the TB, I can see that they are just not dependable and will be a very expensive vehicle to drive after warranty expiration, not to mention the unsettling feeling that something is likely to break at any time.
Well, today I got a call from the Owner of the dealership, who also thanked me for our recent purchase and inquired if everything, was satisfactory with our purchase. He went on to say, if for any reason I was not content with any aspect of transaction or the vehicle to let him know so that he may correct and make it good. He provided me with his phone number where he could be reached in the future for any concerns.
Wow! I impressed... by him taking that extra little effort. To bad I’m short on cash, I would buy one more.
I have the latest updates and code for the dash.
Frank
Frank
Clink, I have it, I believe its a design function, .125 of a second delay in transfer of power due to "The Auto 4wd Function" Gives time for the pins to lock in in case wheels slip.
Gear ratio explained!!
3.42 @65MPH 2100 RPMS
3.71 @65MPH 2300 RPMS
4.10 @65 MPH 2500 RPMS Closer to the high point of torque curve!!! used for towing, higher the ratio the more times your engine spins!!!
So with 3.71 you will get to the red light faster and with more power than the 3.42, or beat him into a parking spot at the starbucks, you get the point.
Anyone know the part number for this orange lever? My dealer wouldn't give me mine back when he removed it. I think I'll order one from gmpartsdirect.com to keep in my glovebox.
I had the same problem back in April. Had the low pressure cycle switch replaced and all was well until a few weeks ago when the A/C started going in and out again. I contacted GM customer service and opened a case file on my vehicle for this problem. GM got the service manager at my dealership involved. They did some research and determined that the switch replaced in April was the old version, and he told me to come in and get it replaced, which I did yesterday. Here is the part number info:
Switch replaced in April - FP# 1132749
Switch replaced yesterday - FP# 89040362
Description - Updated switch re-replace low pressure switch with even newer updated switch
This information was taken off of my invoice.
Curious how you came up with that. My TB with 3.42 gears turns about 1900-1925 RPM at 70 mph. A friend with 3.73 runs 10% higher than mine- about 2100 @ 70. Numbers with the torque converter in full-lock, no slippage.
As for car washes, I'll know better to unscrew the antenna now.
A big thank you to who ever wrote in about the front sway bar links! I am making a list of the items needing attention under warranty. I have 27K on my Envoy XL SLT. I still love it but I am going to get that low speed front end noise fixed once and for all. Also, I've got the rear license plate gasket problem.
Chris
I did have low a battery this morning and had to jump it to get to dealer for replacement (would not hold a charge). No charge of course, still under warranty. 21 mos. old and 25,000 miles seems a little soon for a battery to go, even here in Phoenix. Anyone else have a battery go this soon?
Allen
Also, the rear end clunk was investigated and they reprogrammed the PCM. I have noticed that the drive train seems to respond a little better when I step on it, but I can still make it clunk at low speed. I will admit, it is harder now to make it do that. I suppose the reprogramming changed some of the timing on the transmission shifts and drive train engagement time. I will keep a close eye on it incase this gets worse than it is.
So far, the repairs done to my vehicle under warranty this year have been around $2K+ based on what I have seen written up by the dealer for billing to GM, plus rental expenses. I just do not see how they can make money off these vehicles with the rebates going and warranty repairs. Low margin business I guess.
On my 03 Envoy, the shift knob was loose. I found a small set screw in front of the knob to tighten. Did not have to bother boot.
I'm curious as to what the Zone Rep does and how much authority he has. What I really want at this point is for Oldsmobile to oversee a final repair attempt to see if the shudding can be fixed or at least minimized. I figure this will be Olds' last shot at fixing the problem before I see a lawyer.
BTW, it's pretty clear that at least some of the problems I'm having stem from the Smart Trak AWL system, which is exclusive to the Bravada. Hopefully, owners of the other triplets won't get this problem.
Otherwise you can try this yourself
Tools needed: socket wrench and socket (can't remember the size)
1) Park vehicle with brake ON,
2) turn on vehicle,
3) turn on headlights, and fog lights .
(Note... It is best to have a background in front of your vehicle so that the lights may reflect off, ex. wall or garage door)
4) Next slide underneath front of vehicle directly underneath fog light, look for the fog light, and you will see a little metal stub, turn with the socket wrench and you will notice light and the reflection of the light move up or down on the wall/garage door.
5) adjust to your desired height (less than a full turn most cases).
6) Then adjust the other light to the same position making sure both reflection from the lights lineup.
7) Then test drive... (Make sure they are not adjusted so high that they blind the on-coming driver).
Frank
manufacturers, I wouldn't be surprised if the mark up was close to 50%.
It certainly hurts GM to spend $2K on warranty work for a triplet but not every triplet gets that kind of money spent on it.
Chris
I'm wondering if anyone has first hand inof/experience with the 3.42 behind the in-line 6 cyl. engine versus the 3.73.
I'd like to pick up the better mpg the 3.42 affords but I also would like to know how noticeable a difference there is from a standing start and when passing at, say, 55-65 mph.
The dealer doesn't think we'll notice that much difference in the exceleration from a stand still and actually thinks it will perform better when passing. I suppose that could be due to catching the engine in a higher performance range at some given rpm that with the 3.73.
Another way of saying all the above is, How much more "sluggish" with the (short body) Envoy with a 3.42 feel versus a 3.73 from a stop sign/light?
All of the above assumes that there is nothing being towed.
Thanks in advance.
