Tom
Did you perform #10826 fix for wind noise - if so, did it work?
Also, thank you to GAM for giving me some direction with my very annoying problem. Eack time I hear the noise, I feel very taken from GM. I failed to mention that when I test drove the vehicle my salesman immediately asked me what was my favorite radio station and proceeded to put it on - I am probably reading into this too much but feel as if he knew of the wind noise problem. I also did not exceed 40 miles per hour in the test driver, which I so sorry I did not.
Thanks though for your help.
Surprisingly enough, I usually run 35 lbs of pressure in each tire. I checked them all today and the lowest had 26 lbs of pressure! I was shocked! The pressure varied per tire, but were very close to 26 lbs. Does the change in temperature change your tire pressure that much? Well, I took a gamble and filled each tire to 37.5 PSI and now she rolls good as new again! No tire squeal when cornering, etc. Also, it seems a tad bit more responsive and accelerates quicker than it had earlier. The ride is a little stiffer, but not punishing at all.
Just a suggestion that if you notice a deterioration in handling (sloppiness and squealing), be sure to check your tire pressure!
Frank
Fill up a hog and pigs will fly!
GAM
IExplore2000
I LOVE IT! I have had it a month and have now put over 3000 miles on it. I was terrified buying it after reading the negative posts on here, but went ahead and traded in my Grand Prix Gt on this. It is wonderful for long trips, and if you dont like Mini vans, (me) This is great, it seats 7 easily and we are comfy. I highly recommend a Extended now avaliable in 2003's.
LoL! Actually, you are thinking of Helium. Obviously Nitrogen isn't lighter than air because it essentially IS air! (about 79% of it!)
It won't make grass greener.
That would require certain nitrates.
Nitrogen is best used bubbled through a pint of Guinness.
would that do the same for my Envoy if I used it in the tires? I bet GM has a TSR out for just that problem....................
GAM
~Ken
"I've read that air pressure in tires can drop up to 1 lb. per month and 1 lb. for every 10 dg. drop in outside air temp"
I checked last night. I filled up exactly 6 weeks ago to 35 psi(air temp that day was 82.4). Last night all tires were at 28 psi (temp 42.8) So that was 7lbs over 40 degrees or 1.75 per 10 degrees. I guess they would expand at the same rate if it warms up as well or maybe slightly at higher elevations.
lovemytblazer...I would appear that you've made your first post at one of the boards most brilliant moments lol
Read up on it here:
What Happens when a Radio is Swapped? 9-01 Techlink
Jim
I got to buy myself a compressor for father's day this year. Now I check the tires in our three vehicles every weekend. Up a little when going on long road trips. Down a little when puttering around town. Up a little when hauling a ton of cargo. Etc, etc.
Granted, It will take me the rest of my life to offset the cost of the compressor and all of the tools versus what I would've spent at $.50 a pop at the gas station, but at least I'm happy and it's another excuse to play in the garage, which keeps my wife happy.
I will be traveling more in the TB and I enjoy the digital music stations (commercial free) that I get through my cable company at home (can't find a cable line long enough for the TB). The XM radio seem like a better idea that trying to download and burn cd's for .99 cents per song (legally).
I live in Columbus and trust me, I have found several service stations that offer FREE AIR! Maybe it might be worth a trip to search out nearby service stations in your area that may offer a free air filling station?
Personally, I would love to own a compressor too, but at the same time, it's like an automatic reminder whenever I hit the service station to fill up with gas. Although, I quite often will skip "checking the oil" but, this usually allows me a chance to walk around the vehicle and inspect for scrapes, scratches, windshield wiper blades, etc.
Just my .02 cents!
XM Radio: To those out there with XM radio, how do you like it? I've toyed with the idea of purchasing the Delphi in home boom box system with receiver, but at the same time I would rather have a more permanent OEM type solution installed into my Envoy if I were to go that route? Also, what about the SIRUS radio systems? I've been browsing a couple other auto manufacturer websites in hopes of selecting my first sports car for summer 2004 and I have noticed that Infiniti (G35 coupe) and Nissan (350Z Roadster) all offer the luxury of choosing between XM Radio or SIRUS? Is one better than the other?
IExplore2000
Seems like Delphi has an aftermarket XM radio that "might" interface with these radios we have in our dashes. Surely someone here has done this. Anyway good luck, let us know what you get!
But in all fairness, my Envoy XL rides on standard air in the tires. My other vehicle does have Nitrogen(N2)filled tires that use to be filled with standard air. I did notice a ride difference from the moment I switched. The tires are always cooler after any drive. The ride is smoother too! it was much bum pier prior. My Envoy is fine with air for the moment.
Mine floats better when I use helium.
No it isn't, kilopascals is the standard but the
air pumps (free) have both units, gas is in
liters and the weather man is also metric. Millimeters of rain, K pa atmospheric pressure etc. I set all read outs on my Envoy metric but switch to understand where you guys are at (see host i'm on topic). As a matter of fact grocerys are sold in both units. Standard? What standard. Yes we are very metric 99% but that would depend on who is asking and what is being sold. I work in commercial construction. The drawings i'm looking at today are imperial...yesterday metric and I sell in sq/ft. Not only are things sold in both units, labels on products are in French and English? Didn't you guys shoot a rocket at something (Mars?) that ran out of gas because some idiot mixed his units up? When posting here I always would try to respect your system.
Actually the problem wasn't running out of fuel - it was too much thrust being applied due to mixing English and metric units of force. The probe went down in a blaze of ... well it wasn't exactly glory!
It's been a while since I've been on here and I would like to add that with 75,000 miles on the TB -LT I've been basically pleased with the overall vehicle. I have to admit that I'm a little worried the closed that I get to the magic 100,000 as then the engine comes out of warrenty but I believe that I'll get rid of this and buy again.
The last service stop about 2,000 miles ago, the dealer perfromed warranty work and reprogrammed the instrument cluster as per the TSB or recall. Now the blasted climate control has it's own mind--turns on when it wants and off also! Any ideas out there? Dealer claims that they want to investigate ---at about $85 and hour! Can it be reprogrammed to what it was before? I had no problems with the instrument panel of this prior.
Also the muffler went in the TB at about 45,000 and it keeps eating baffels out of the Mineke replacement at a rate of about 1 every 3 months. The poor Mineke guy keeps replacing it for free but I think that it's going to stop soon. The dealer wants $600. $466 for the part and about a buck fifty to install--way too much in my book.
Has anyone had to change 1 yet--aftermarket hopefully?
All have a great day!!!
If you were local I could probably be talked into making you a deal on my factory muffler I took off with less than 10K miles on it. It sits in the attic out in the garage collecting dust. Doesn't Mineke sell a stainless steel muffler?
Interesting comment about the instrument panel reprogram recall and the after effects. A friend took his in back when they first sent out the recall letter, and they somehow "crashed" the programming on his, had to take out the instrument cluster and send it out for repair! 3 days without his TB for a 10 min reprogramming. Mine is still original, and I have never had a problem with the instruments not working. I am sure they will insist on doing it if I need to take it in for any other problem, since it is supposedly a safety related issue.
Great to see the boards active again and I have to chime in that I love my Envoy. Almost 29K on it and it drives and looks good as the day I drove it out of the dealer in May '02.
I have the license plate gasket thing going on and will take it in to get fixed soon. That's about it.
An earlier post recommended Chrysler mini vans. A friend and his wife won't buy another Chrysler mini van--had to shell out about $2K for a new transmission just after going out of warranty. His wife is convinced going Japanese will cure it all. Been to the Toyota discussion group lately? They were talking LEMON LAW over there the last time I looked (has been a couple months.).
Chris
Yeah, seems like I'm the pilot program sometimes--interesting--. Nuyorker it appears has alot of very good answers to a lot of good questions. Would really like to hear his viewpiont on the climate control.
Thanks tblazed!
I worked on the wind noise issue a couple days ago. I gave the driver's door the GAM2 treatment (foam and RTV).
I gave it a road test today and while there seems to be less wind noise, it's still there. And annoying. I'll keep experimenting.
Borla might have a stainless muffler that would fit. The one on my system has a full 3" inlet and two outlets for the duals, but it is possible they could make the same size muffler with a single outlet.
Montana...excellent option)and the Bose..I could kick myself for that. Oh yes, I have no tv but I use the factory sunroof all the time. I also have three wiper motors (two of them won't operate full of water though). Does any one find the drivers heated seat will fry your butt twice as fast as the passenger side or have you ever sat over there? How cold does it get in Texas? On occasion the mirrors tell each other to piss off but thats nothing a few hits on the mem button won't cure. Actually with all the many options that could go wrong it's held up pretty good. I'm 497 miles (800 km) away from the end of the warranty. I'm going to go through this site and make a list of anything I can find that would remotely go wrong. I hate to make you all sick but my dealer will most likely fix everything (must be a local condition). This truck is good, it will be dashing through the snow soon. I'm not whining!
