Thanks for any input.
Ken
BTW, the latest consumer alert regarding tires over 6 years old (side-wall deterioration due to aging of the tire compounds) also would impact my tires if I keep them beyond this year. They were manufactured in August 2002.
I also noticed that there aren't the constant tire sale ads in the local papers like there used to be a few years ago. Something has definitely changed in this market in the five years or so since I last bought tires for anything.
"the price of oil, now at all-time highs, makes up 60% of the raw materials cost for a tire. Natural rubber, a commodity nearing 28-year price highs, makes up another 25%."
As tire prices rise, drivers delay purchases (USA Today)
Edit... I next went to www.gm.com, selected GMC, then went to Build Your Own.. chose 2009 and the Envoy does show up there. So, maybe they are still building them after all.
SUVs and Smart Shopper
handyandy3
I do not have the ability to turn the air suspension on or off in my Envoy. It is "on" all the time and usually I hear it come on every time I start the car. It has done that since new. I can turn on or off the aux. air pump outlet located in the passenger side rear panel in the cargo area. I cannot imagine why someone would not want it on when towing unless there was some fear it would overload the system. That has never happened to me. I would think that even if you could turn it off while towing that the back end would sag lower due to the extra weight of the trailer tounge. My Envoy has the extra duty towing package so I have always assumed that the air rear suspension was designed to work in towing situations. Mine is a 2002 that I bought new 7 years and 1 month ago and the air suspension has worked the entire time. We have towed with it during the summer since new. Our boat/trailer weighs 5000# and the Envoy tows it just fine. Does your owner's manual say anything about it? Do you have a switch that lets you turn the air suspension feature on and off? On mine the air suspension has air bladders instead of rear coil springs. I replaced the rear shocks last year but they are not connected to the air suspension bladders and are just plain old shock absorbers.
Good luck and keep us posted!
Hardhawk
handyandy3
That sounds like the absolutely most absurd "customer service rep's" advice I've ever heard.
If towing something caused an adverse response in the model you own, the manufacturer would have designed something a little more "sophisticated" than pulling a fuse.
And I would sure get hold of the franchise owner and get, in writing, what he would suggest in the situation you describe.
thanks again
I tried
ken z
thanks again
ken z
Here are the issues:
1) lights have gone out while driving during the night (this has happened 2 times) I put my flashers on then fiddled a little with the ignition and after about a minute they came back on
2) Sometimes the car desn't want to turn over it grinds 3 revolutions graoning and moaning then kick on...sometimes I have to resatt then kicks over ok. Thia has happened about 6 times
3) Stalled at a red light. 1 time
4) "no air bag" light comes light comes on. 2 times
5)" get engine checked" light always on. Depending on whether I'm hauling a trailer it is intermitten
6) Battery light came on the a message about no charge getting to the battery. That went away after I jiggled and fiddled with the wires.
7) Today I put the air on 74 degrees and blew the fan on hight for about 8 minutes...then turned the fan way down to lo and as I accelarated the fan blower went from lo to high depending on the rpms and as I accelerated the sound was louder than normal. Usually I hardly here my car running. The blower issue went away when I turned the air off.
8) The other day I noticed that all the little buttons on my steering wheel were burning hot.
Any ideas as to what might be ailing my Trailblazer? It's an 03' straight 6 and I replaced the alternator 2 years ago and the battery 6 months ago (3rd one) And I live in South Florida...
Chevygirl
This assumes you have the load leveling suspension.
-Jason
New to the forum, so please bear with me. I have a 2002 Trailblazer LTZ which i am very satisfied with. I also do almost all of my work on my cars (have been since I was 16, and am now 53). Howere, I have a problem I can't seem to solve. I was replacing a rear w/w switch and had the left IP panel closeout and knee bolster out. After the repair, I put it back together and lo and behold - half of my IPC backlighting is out. I can still see the speedo and gauges, butthe tach and half the speedo lights are gone. I took the IPC out to see if there were any burnt bulbs and the IPC is sealed and is just a circuit board. Also, the dimmer switch works still, but its backlighting is also out. All other IP lights work and will dim via the dimmer switch. Are there TWO wire power feeds to the IPC and maybe one circuit needs to be repaired? Or could it be the dimmer switch itself? Or, because 1/2 the IPC lights up and reacts to the dimmer switch, am I looking at an IPC repair or replace? Can the IPC circuit board be that fragile that a slight jar would burn outthe LED lights? Really looming for some help here. Even the actual Trailblazer OEM Service Manuals (I get them for all of my cars through Helm Inc.) does not address this issue. Can someone help me or point me in the right direction? It is a shame that I would have to replace the entire cluster for just a lighting problem...
Thank you so much for your time!
Slipkid1
Ive checked all related fuses... no idea where the sensor is so i havent checked it... any ideas?
