Second- my dealer said change oil between 3000 and 7500 max regardless of oil change monitor. Makes sense to me. I plan to go 3000 mi or six months whichever comes first.
Seems like the recirc feature should shut off after a bit of cooldown. Why would you want it to stay on?
MK
"Within the past 6 weeks I have posted complaints about the recirculate button shutting down after 8 minutes. There wasn't much buzz about it except for a few stating they have the same issue. Well, my dealer found that it is due to a mechanical failure in the A/C system. A part is being overnighted to fix the problem. So, if your recirc button shuts down after 8 minutes, then you are affected. I'm crossing my fingers that this will correct the problem. I'll post again after they replace the parts."
SO Hambone7, Did it work?
One question, I read somewhere adding dual exhaust would increase HP to an even 300 ponies.
That with the K&N filter should help it breath and increase both power (not that it needs it) but also MPG. Has anyone installed dual exhaust yet? If so any results?
I'll be keeping an Eye on the mirrors and paint around the license plate bracket. Too bad I didn't have it the last few days when all of this snow hit.
-Brian
One other thing, where is the "puddle lamps"?(p.22) I thought they would be under the outside mirror, but I don't see them.
My Envoy SLT is running great. Only one problem: missing drivers-side bolt for front air dam. I put in a temp and will get it replaced at first oil change. At 3000 miles by the way. Oil only breaks down while it is in use. It doesn't get better with age. So changing every 3000 miles or so can't hurt it.
Remember the manual says if the Oil Life System is accidently reset, you must change oil at 3000 miles after your last oil change, then reset the Oil Life System. In all cases change your oil at least once a year.
Mike
Not anymore.
I got off to a bad start with two potential dealers -- one on the Net, who responded to my query with a "you drive to much for a lease" response and demanding to know how much I wanted to spend (even though I never mentioned lease).
Then I found this website. Now I realize happy customers have little reason to post here, but the fact that the same problems are cropping up all over the country -- and GM refuses to deal with them -- is all I need to decided NOT to spend $30,000 on one of their products.
I wonder if you owners are looking through rose colored glasses, and that's why you're not all in revolt over paint chipping license plates, droopy mirrors, missing trim and problematic pumps?
Surely some GM Corporate folks read this site. To them, I ask: Get your act together!
You cannot say every car needs an oil change at 3000 miles. That's why GM had it computerized. he problem is on a global scale, all these unnecessary 3000 mile oil changes wastes resources. Used to be based on mileage, now it's based on how hard the oil is used, as measured by the computer.
I always changed my oil after 3000 miles of city driving, and ignored any long trips. So if I went 4500 miles, and 1500 was interstate travel, it was time for a change. Now I'll just do it when the computer sais to, and use Mobil 1, and Go.
I have 162,000 on my 1985 4x4 S10 blazer. Works for me.
Buy the Bravada. You'll get a nicer interior, better deal at the dealer, and 5 yr 60k warranty.
also, the sterio head units are didderent. Different to the core.
Greg
Wichita
If you "hover" your mouse over the visible number, the "real" number will appear in your browser status bar (this post is "really" number 3801 for example).
The Jump To box uses the "real" number to navigate by, and that's why you are often thrown off trying to get back to a specific range of posts.
Hope this makes sense . It's a "feature" of our software.
Steve
I don't know that I'll let it get to 12000, though, but one thing that seems to be overlooked
is that these things have big 7 quart oil pans.
That extra oil does let you go longer between
oil changes.
I changed the oil for the first time at just over 7000. It looked good. Not too thin, not sludgy.
The first thing the dealer did was check the A/C system since I also complained that the A/C clutch cycled on and off a lot. The A/C system was out of spec (sensed a -40 degree F temperature) and a part was installed to correct the problem. I don't think the mechanical part corrected the recirc button issue because they went on the reload a new BCM (Body Control Module) program. I am about 99% that the new program corrected the recirc button issue. I don't believe that a mechanical failure would cause the recirc button to shut off after EXACTLY 8 minutes consistently.
You know they can't get all the little metal bits of metal completely out when they built them! Two quick oil and filter changes gets all the little pieces of junk out. I also installed a magnetic drain plug to catch any floating metal savings in the oil. Put the plug in at 600 miles and when I change the oil at 1200 there was a lot on metal shavings on the end on the magnetic Buy the third oil change (4500 miles) the magnetic was almost clean!
After the two quick changes I usually go about 4000 to 5000 between changes. I use to do it at 3000 but oil is better now and new motors don't contaminate the oil as fast. I had a 1985 S-10 Blazer that had 217,000 miles on it when I sold it. I know it was all the oil changes I did over 11 years that keep that motor going. I never had to touch the inside of that motor!! and that old 2.8L was never known for its longevity.
Allen
I must have fielded a dozen or so email flames from various boards, but thankfully the recent Motor Trend proved me correct. It's not in production yet, but IMO, it will be a reality come 04.
How many would pay $45-$47k for one though?
HTH, Tim
HTH, Tim
Allen
http://minimopar.net/oilfilterstudy.html
My 40 yrs experience and .02 worth, Tim ;-)
The extended oil drain intervals given by the vehicle manufacturers (typically 7500 miles) and synthetic oil companies (up to 25,000
miles) are for what is called normal service. Normal service is defined as the engine at normal operating temperature, at highway
speeds, and in a dust free environment. Stop and go, city driving, trips of less than 10 miles, or extreme heat or cold puts the oil
change interval into the severe service category, which is 3000 miles for most vehicles. Synthetics can be run two to three times the
mileage of petroleum oils with no problems. They do not react to combustion and combustion by-products to the extent that the dead
dinosaur juice does. The longer drain intervals possible help take the bite out of the higher cost of the synthetics. If your car or bike is still under warranty you will have to stick to the recommended drain intervals. These are set for petroleum oils and the manufacturers make no official allowance for the use of synthetics.
More at http://www.vtr.org/maintain/oil-overview.html
Tim
Carl
Sure would save me climbing under car, removing plug and then running around hoping I can find one before I refill oil. I don't want to rely on counterbooks since most do not have current vehicle information.
Any help would be appreciated
Paul P
This is my first exposure to GM's oil life algorithm. I trust it, or they wouldn't have put it on the vehicle. Any one want to offer comments about the value of the first oil change being done at an earlier date.
Paul P
Allen
Allen
forward and the thin, sharper part in the back.
This is much like an airplane wing, except an
airplane wing is asymmetrical top to bottom.
To some this may sound counterintuitive, but
just think of how a raindrop is shaped.
I don't know the answer to your question; someone else might. In effect I guess you want to know the reserve capacity once the light comes on. But it's been recommended to me to never let the fuel get that low; that's it hard on the electronic fuel pump and sending unit. I've heard that the fuel pump will last a lot longer if you fill up your tank every time it gets down to 1/4-1/3. They say that tank levels causes increased sloshing of fuel and allows for more condensation of moisture in the airspace. I don't know if this is fact, but it sure sounds reasonable, especially when fuel pump replacement in these new vehicles runs about $600 or more since the entire module must be replaced as a unit. So I hope to try to not let mine get below 1/3; perhaps at rare intervals on a long trip, I'll let it go to 1/2. Anyone else have any thoughts on this?
Also, I checked the mpg with the trip meter. I got 16.5 mpg. The DIC (which I had reset at the same time) showed 16.7 mpg. Since there is no easy way to replace the exact amount of fuel to full, I would say the DIC is right on target.
(Total odometer = 476 miles w/4.10 rear axle)
-- Mike
My understanding is that GM will start making the EXT at the end of this month. Given how long it took the Avalanche to reach dealers after they started production, I would say that they could be ready for pickup at the first of April.
Maybe if there is enough interest, the fine people at Edmunds.com could start a new board for the Trailblazer EXT and Envoy XL. I really like the way that the Avalanche Owner site is setup. (Join other Avalanche enthusiasts in Edmunds.com Chevrolet Avalanche Owners Club!) I could give you insights into my new truck when it arrives.
Any chance of that happening, Steve? Please, please, please!
Snuffy '92
Steve
I just thought I would do some checking. It gets better gas mileage than both the Explorer V8(comparable power) and the Dodge Durango.
The Acura MDX, Lexus RX300, and The BMW X5 all require super unleaded, which in my area all require an approximate 20% price surcharge. When these things are factored, it has to be the most fuel efficient vehicle in its class. More certainly, better than any SUV with a real truck frame and comparable power and weight.
Thanks in advance!
I think it is hard to compare gas mileage with great accuracy, there are too many variables. I have the 3.73 axle ratio, and we've recently done more highway driving then city. I also reset my average reading at about the 500 mile mark and will probably reset it after the first oil change thinking that it should be further broken in at that time.
My main point is that I have seen references from places like Edmunds and other reviews that the Acura MDX and the Lexus RX300 get better mileage than other SUV's in their class.
However, if I take Acura's 23 MPG highway rating and reduce it by 20% to reflect the difference in cost by using Super Unleaded, I then come up with approximately 18.4 MPG compared to 21 for a similar GM triplet. The GM triplet is much heavier(because of real truck frame) and has more horsepower and torque.
The only item that I really wanted to emphasize is that when we compare gas mileage, it should be an apples to apples comparison. Comparing the Durango, Explorer, and other truck based vehicles that use regular gas makes sense.
Requiring the usage of Super Unleaded increases your real world cost significantly.
Trailblazer club
Oldsmobile Bravada
GMC Envoy
(or do you really want separate EXT/XL discussions in there?)
Steve
(I have a brand new Bravada with 450 miles on it now!)
I plan on using 87 octane gas.....
He now fills up around ¼ tank and has gone 125,000 miles with no problems.
Allen
