Jeep Grand Cherokee engine cutting out
I have a 1994 Jeep Grand Cherokee with 80K miles. (4L six) I am having intermittent problems with the engine cutting out for about 5 seconds occasionally. I have replaced the ignition coil, distributor cap, rotor button, and spark plugs. Does anyone have any ideas what this problem may be?
Ted Lawrence
Ted Lawrence
Befor you entertain replacing computer control moduals or fuel pumps, install a fuel pres. gage on the fuel rail & tape it to a windshield so it can be monitored while failure is occurring.
I can not count the number of times I have found this type of problem to be caused by a bad ground or connection.
If you told a mechanic about this ether-only starting, and he replaced your plugs and wires, that was a waste of money, he should have known better. The fuel pump was a good guess, however.
Check the fuel filters and fuel relay circuits. Also, there may be a SECOND filter somewhere that you don't know about...perhaps one of those ribbon type that sit in the gas tank? Sorry, it's been a while since I've worked on one of these.
This problem occured in two different instances about 3 months apart. The first time, the dealership told me the idler speed control motor was going bad. They replaced it and everything was fine. The second time I took it in for the same problem, they knew they had replaced the idler speed control motor and they asked if I had to have the Jeep jumped. I did and the problem began occuring about 4 days later. It turns out that by jumping the Jeep from another computer controlled car, I had inadvertentaly messed up the setting in my Jeep's computer. It was a simple thing for them to reload the proper settings and off I went. They didn't even charge me. It perplexed me a bit, because the first time the incident had occured, the Jeep had not been jumped, the problem occurred on it's own. But now, It's been six months no and I have had no problems whatsoever. Needless to say, I'm careful about making sure that everything is turned off when I go backpacking and leave my Jeep for several days at a time.
