Common General Motor's 2.8, 3.1, 3.4 V6's engine problems
rbentonrbenton Member Posts: 30
edited September 2015 in Oldsmobile
Hi I am have a 96' Oldsmobile Ciera series II 4door with 79K. With 3.1 series 3100 V6. I just found out why car was using coolant for the last six month's. It appear's that one gaskets is letting coolant out the top of the engine. The mechinic said in could be the Intake mainfold upper and lower, head gaskets or the throttle body gasket's. I am wondering which gasket it is? I am wondering how common this problem is? I also like to know how time (aka work is involved to fix). And Lastly how other engine damage I might have. By the way I had checked my oil and it does not show any signs of contaimintation (the oil looking cholatety, or thick and murky).
See Also
The Lost Art of Diagnosing Engine Problems
    They tend to leak between the lower intake manifold and cylinder heads. In extreme cases, the intake will reqire replacement due to metal erosion. The problem is common because people still haven't figured out that "permanent" isn't "forever", and the coolant requires replacement every 2 years due to the corrosion inhibitors becoming depleted.
    Mitchell Mechanical Labor Estimating Guide times:
    1984-96 Ciera
    Manifold gaskets................ 5.4
    Head gaskets.................... 9.8
    Add:
    where A.C. interferes........... .3
    where Air Pump interferes....... .5
    where Cruise Control interferes .. .2
  • stealth1969stealth1969 Member Posts: 162
    What alcan said is right on target. I have a 95 Buick Rgal with the 3.1 V6. I bought it used. To make a long story short, my car had to have the intake manifold and one of the heads replaced due to metal erosion. Mine was bad enough to have water in the oil. The previous owner did not maintain the coolant system. Lucky for me, the maintenance warrenty covered it and there was no other engine damage. That was at 90,000 miles, I now have over 145,000 miles on it and it still purrs like a kitten. I would recommend not wasting time getting it fixed. The longer you wait the more it could cost. Like alcan's post, it will take about 2 days or so for labor. Mine took a week because they had to wait on parts.
  • kcwolfpack59kcwolfpack59 Member Posts: 122
    My 1997 Monte Carlo overheats after I idle it for more than 5 or 10 minutes. I get the same result with friend's 3.1 motors. The temp needle climbs way up more than I am comfortable with before the fan kicks in. The way I prevent it is to turn on the a/c. Dealer says within specs. I dont think so. Anyone else have this problem?
  • 79377937 Member Posts: 390
    Alcan is right about metal erosion and gasket leaks. Also right about the coolant. What I do now is siphon the coolant overflow tank empty every 2 months or so and top it up with fresh coolant again. In this way the cooling system is getting a fresh transfusion all the time. It's easy and cheaper in the long run and very simple to do. Just take a length of small hose, prime it with water, ( don't suck it) and dunk the one end into the overflow tank and the other into a suitable container at ground level and drain the tank. Just be sure to get the right coolant for your car and mix as per instructions.
    By the way, Dex-Cool is available at K-Mart and similar outlets at very reasonable prices. Don't buy it from the dealers.
    kcwolfpack59, it looks like GM allows their engines to get hot. My 99 Cavalier also seems to get very hot while idling in stalled traffic before the fan kicks in. I'd never let it go into the red though and it never has. Like you say, it does make a person uncomfortable. Seems as if that's the way GM likes it.
  • jeneppjenepp Member Posts: 3
    Help! I have a 1990 Grand Prix 6 cyl with 199,000 miles. I have had very few problems with this car and have been very happy with it. Up until a couple weeks ago it still rode extremely smoothly and was a comfortable ride. One afternoon on a rainy day, the car would not start. The engine turned over and sounded like it almost started, backfired a few times. The car was under a carport, but there was condensation under the hood. It rained for a few days, and I tried unsuccessfully to start the car the next day. A friend looked at it and thought it was the timing chain. He replaced that, by chance, on the first dry day. The car then started, but since he did not try to start the car beforehand, I don't know if that was really the problem. Four days later, the car would not start again, but this time was different. It acted like a dead battery, but the headlights and interior gauges were still bright. After a jump-start the car started and drove fine. Three days later, again on a rainy day, the car wouldn't start AGAIN, this time the same as the first time, turning over, backfiring. It finally started that night, but then it ran terribly rough. Also, when I held a dollar bill at the tailpipe, it blew out and sucked in. OK- so I drove the car for a couple days. It was very rough. Gradually, it got better, though. By the time I got an appointment with my mechanic, it was fine. The mechanic found no problems. Some things I suspect: an electrical problem, something shorting out because of the rainy weather; also I heard the catalytic converter can cause all kinds of problems on these model cars. Any ideas? I would appreciate any help.
    The first thing to check with a wet weather no start is secondary ignition system: distributor cap (if equipped) and plug wires. The symptoms you describe aren't consistent with a plugged catalytic converter.
    I wonder if you had a sticking valve that came unstuck with driving......certainly could happen at high mileage, and the symptoms are similar to a slipped timing chain.
    Thanks! I'll check these things out!
    If I had a stuck valve, does that mean it will stick again? Or might it be okay for a while? Thanks!
    My son once had a German built Chevy Chevair 1.8L. It had the same type of formed rocker arms used by GM today. These had a tendency to break after high mileage and would prevent that particular valve from opening. In one case an exhaust valve rocker broke and the exhaust valve was not opening. That cylinder would fire but, on the exhaust stroke, the gas had nowhere to go and was blown past the piston and into the crankcase. This happened at highway speed. So it was with much bucking and snorting that he managed to chug home a few miles further on.
    I'm not suggesting that's what Grand Prix's fault was but, while we were on the subject of valves....
    Sorry, meant to say jenepp.
  • rwingerrwinger Member Posts: 6
    I just bought a used 97 Venture (130K km) and while changing the oil, the dealer tech told me he could see evidence of coolant condensed on the filler cap. They suggested it was the intake manifold gasket. Is this the same problem as for the 3.1's covered earlier in this discussion? Is it the upper or lower manifold gasket? Is this a common defect with this series of engines, or is it a symptom of poor maintenance? I've heard that coolant replacement is the culprit, but isn't this dexcool stuff good for 5 years?
    Thanks in advance for your insight,
    rwinger
    Dexcool (orange/pink coolant) is good for 5 years. The deposits on the inside of the filler cap are often caused by short trip winter driving. Check the oil dipstick for signs of coolant contamination. Is the coolant level in the recovery bottle dropping?
  • lngtonge18lngtonge18 Member Posts: 2,228
    I have a friend who owns a 92 Buick Century with the 3.3 liter engine. He is having intermittent problems with the car running rough (bucks and misfires) and than sometimes stalling at idle while the check engine light comes on. The car only has 80,000 miles on it. We tried changing the spark plug cables and the spark plugs. The car ran better for a week and than it went back to the same thing. What could be causing this problem? Is it a clogged EGR valve? Any other ideas?
    My 95 Regal with the 3.1 liter engine had a somewhat similar problem. I had rough idle and it would miss while crusing down the road. I never had a check engine light though. I had changed the plugs and wires and it did seem to help mine a little also, but did not fix the problem. After time it just got worse to where it was missing on one cylinder. One of the coils for the ignition went bad. It was strange because the coils fire two cylinders but only one was not getting the fire. Replaced the coil and it has been fine since.
    I've only had it for a week, and my mechanic (who inspected it before I bought it) must have missed this. The coolant level was low when I bought it - bottom of the reservoir, it took about 750 ml to top it up and I've been driving it very little since then. What would I be looking for on the dipstick?
    The coolant looked like it was a mix of dexcool and regular AF. I say that because it had a green shade to it (it was still basically that fluorescent orange/pink, but it sure didn't look like fresh stuff) Would the intake manifold gasket deteriorate as a result of mixing the two?
    rwinger
    Stealth1969, if one end of the ignition coil were shorted to ground you would get the effect you mentioned. The 2 plugs and secondary coil are all connected in series. The coil sees the plugs as 2 capacitors. So, you have a capacitor, coil, capacitor. When a high voltage is induced into the coil by the primary winding, the voltage will travel from the side electrode of one plug, through the coil and to the centre electrode of the 2nd plug. Take off the wire to one plug and short it to ground and, the other plug will still fire. Not recommended though!
    How do you determine which coil is bad? There are 2 or 3 of them no? These are the black boxes where the spark plug cables connect? I kind of figured that area might be a problem since it is normally where a distributor cap and rotor would be located, which is a normal wear item. How much did the coil cost for your car?
    intonge18, the coils are marked where the plug wires go on. On the 4 cylinder engine one coil fires plugs 2&3, the next coil fires 1&4. In the case of a 6 cylinder, the coils are marked and fire 1&4, 6&3, and 5&2. Each coil can be individually removed and replaced if needed. I am of course refering to the Direct Ignition System that uses no distributor. Hope this helps.
    I pulled one plug wire at a time and attached it to an extra plug. I postioned the plug so the electrode was grounded and would not move, you could use a pair of insulated pliers but be careful not to get shocked, like I wouldn't touch any part of the car then. I had my wife crank the engine while I looked for the spark. As soon as I saw the spark, I had her turn it off. Do this for each wire. I had one were I wasn't getting a spark. Replaced that coil and she runs fine now. The coil cost me about $13 at Autozone. Hope this fixes your problem.
    I know I'm not Alcan and he can correct me or add if I missed something. Is your car using coolant? Have you had to add more since the first time? Does your oil level seem to increase? A little goop under the oil cap can be normal, expecially during the winter months. If the head or intack manifold was bad, you should see some coolant loss from the reservior.
    Unfortunately, (or maybe fortunately for the engine) I haven't been driving it enough to notice any consumption of coolant. At the time it was spotted by the tech, he was changing the oil, but I also had him flush the cooling system at the same time. Other than the coolant levels decreasing (and if its happening, its not a large amount) is there any other telltale signs that the gasket is leaking? The oil dipstick was mentioned by alcan, but what would I be looking for? I want to avoid driving it too much with this problem, cause coolant doesn't make very good oil. Is there any other way to detect a faulty gasket without running it enough to consume a noticeable amount of coolant?
    Its going to another mechanic tonight to take care of something that was supposed to be done when I picked the car up, so I can get a second opinion from him before I go spending a ton of money.
    How common are intake manifold gasket failures in these engines anyway?
    Any help is appreciated, Thanks
    rwinger
    I don't know if is common for the intake manifold gaskets to fail on these egines. I don't work in the auto industry. Let me tell you about my car. I had to fill my coolant reservior every 1 to 2 tankfuls of gas because it was empty even the radiator would be low. I also noticed my oil level would increase, I check it every fill up. At that time I drove 60 miles to work one way. So it was very obvious. It took the dealer 3 times to totaly fix the problem. To make a long story short. The head gasket was replaced 1st, then they tried to patch the head and the intake amnifold, which did not work, so the head and intake were replaced. I haven't had a problem with coolant loss since. Lack of maintenance was blamed for the head and intake needing to be replaced. It took about 3 to 4 months for it to be finally fixed. During that time I put about 7,500 to 10,000 miles on the car.
    On the dipstick, I would look for an increase in the level or if there is a kind of goop like what is on the oil cap. If you trust the mechanic, I would also talk to him about it.
    Thanks stealth1969
    Something bugs me about this failure - I'm still puzzling over the reason that (at least for this vehicle - 97 venture) they sell it with dexcool, which is good for 5 years, and then can blame lack of maintenance in the cooling system for the gasket failure. The service advisor at the dealer was quite sure it was the intake manifold gasket leaking, so I assume he's seen this a few times. I've only had it 1 1/2 weeks so I can't comment on what the previous owner did or didn't do but given the van's age, the coolant shouldn't have been in bad shape for too long if its designed to last this long.
    I guess I'm wondering why this failure is common, and usually blamed on the coolant maintenance which only needs attention every 5 years. Should I be changing out the dexcool every two years like the regular stuff?
    A little miffed, Not enjoying spending $$
    rwinger
    I can understand what about your frustration. I have a 3.1 in a 95 Buick Regal. I had mine for a month when I saw the problem. A little older than yours and I know more miles. I don't know if they used Dexcool then. Is there any kind of warrenty you got with the van? Did you buy it from the dealer or a private party? Like Alcan and I said, a little goop on the oil cap can be common. Check the dip stick to see if the same type of goop is on it. Also does the oil look different? By all means, I would talk to your mechanic about it. I think he would have checked the condition of the oil when you had him check the van.
    I got this thing from a used car dealer/wholesaler. He gave me a 3rd party powertrain warranty with it, but of course gaskets are excluded. I'm working on him to at least cough up 1/2 the repair cost, but he's obviously not interested. He put the onus on the buyer to have it inspected and will fix what's wrong, but after you pick it up, its your problem. I think that he has a responsibility to ensure the car doesn't need major repairs for a reasonable amount of time (at least a month).
    I'll talk to the mechanic and see what he says. I just would like to know that first, it needs doing, and second that it should be OK after as long as I maintain it properly. I like to have my cars in the shop when its convenient for me.
    Am I bitter? A bit.
    Mastercard likes me though.
    rwinger.
    I know what you mean. It has been about a year since mine was fixed and it has no coolant problems. It now has over 147k miles. I would also check you state laws to see if there are any pertaining to car sales. Would the warranty cover the labor part? That is going to be what costs the most.
    Sorry to take so long to get back to you re mixing of antifreeze types. Here's a quote from GM:
    NOTICE:
    When adding coolant it is important that you use DEX-COOL (orange colored, silicate-free) coolant meeting GM Specification 6277M.
    If silicated coolant is added to the system, premature engine, heater core or radiator corrosion may result. In addition, the engine coolant will have to be changed sooner -- at 30,000 miles or 24 months, whichever occurs first.
    The problem is that silicated (conventional) coolant can damage aluminum parts such as the intake manifold and cylinder heads on 2.8's, 3.1's, etc. Re your question as to whether this is common on these GM engines: yes, very. That's why they had to develop the silicate free coolant.
  • kwagkwag Member Posts: 1
    My 96 Grand Prix also has a 3.1 and as you can guess the intake manifold gasket is bad. For the past few months I have been adding dexcool about every two weeks. After reading through your previous posts I'm even angrier with GM for recognizing this as a problem and then charging ridiculous amounts to have the problem fixed.
    I was quoted by a dealership that it would cost upwards of $700 to have this problem fixed. I think I'll get a quote from another mechanic before I do anything.
    The part that really upsets me is that the entire coolant system is advertised as "no coolant change" for 100,000 miles. What could have caused the gasket to go bad? I never added dexcool coolant to the system until I noticed it was leaking. I have never considered buying a foreign car, but it's expensive repairs like this that make me wonder if its worth sticking with GM cars.
    I now know I'm not the only one out there with this problem. Thanks for the insight.
    You're definitely not the only one with the problem. Ask any tech at a busy shop about coolant in the oil and you'll probably get an immediate response re intake gaskets.
    Thanks a lot guys. Its good to know I'm not alone (scratch that - it's even more of a pi$$ off if the problem's that common. Sounds like a defect that GM should be kicking in for)
    One more thing... has there likely been damage to the engine as a result of this leak? Am I going to be plagued by recurring problems because of this?
    Again Thanks,
    rwinger
    If you've been circulating massive amounts of coolant in the oil for some time, you could damage the engine bearings, yes.
  • corsicachevycorsicachevy Member Posts: 316
    I own a 1996 Chevy Corsia with the 3.1L V6 and "lifetime" Dexcool coolant. The car has 87,000 miles on it. During my last oil change it was noticed that my coolant level was low. In fact, the reservoir was almost empty. Despite this low level, the engine never ran hot. I contacted a dealer service center to schedule an appointment. I was told that over time the coolant may evaporate and that it isn't that unusual to add coolant given the age and mileage of my vehicle. I have been monitoring the coolant level over the past few weeks and have noticed that the level has dropped about a 1/4 to 1/2 an inch in the reservoir. I have not noticed a decline in performance or fuel mileage. There is a little slimy, discoloration on the oil fill cap, but I haven't noticed any residue on the dip stick. Any suggestions for a logical next step?
    Read all the posts in this forum. The problem should become evident.
  • stnelstnel Member Posts: 338
    I just read these posts a couple of days ago and am responding to the earlier ones on overheating. I have a 91 Grand Am, my brother has a 91 Grand Am and my father has a 90 Chevy van. We've all had the same problems with overheating. GM seems to have had problems back in early 90's but apparently still are (up to '97 anyway).
    Anyway, my father put a fan in the engine so I could turn off AC and still have a fan on to cool off the engine in stop and go traffic, red lights, etc. He put a switch inside the car so I can turn the fan on and off as needed. I don't know how much that would cost if you took it to a mechanic. It does help though.
    I'm buying a new car soon and have been considering the Impala and Taurus. After reading car reviews on Taurus's as well, I may just flip a coin on which one to buy! The Impala owners seem to be satisfied customers anyway.
    I have recommended 7 Impalas to our company sales reps and not one has chosen a taurus,intrepid or anything. one drive will convince you Impala is the one to go with. I think they have most of the bugs worked out of the 2001. The 3.4 is ok but If I had to do it again, I would go with a 3.8.
    Just about everyone in various forums I've read all recommend the Impala. The gasket problem really had me concerned though. The forum on Taurus problems was so long I couldn't read them all. Their main problem seems to be the transmission. I like the Impala better anyway. There has been a lot of dialogue on the Impala XI forum under Sedans. It may be quite informative for people having these problems. The posts were over this past weekend - mostly by platour and bearmer if anyone is interested in reading them.
    I hope you get your overheating problems worked out. I've been dealing with it for 10 years with this Grand Am!
  • poisondartfrogpoisondartfrog Member Posts: 102
    Found this link about Dexcool and whether it is linked to contamination in the cooling system. Have you checked your radiator cap lately?
    http://www.imcool.com/articles/anitfreeze-coolant/dexcool-macs2001.htm
    This link found at:
    http://www.s-series.org
  • adc100adc100 Member Posts: 1,521
    I have a '92 Corsica 3.1. Decided to replace heater hoses. They are buried low on the firewall. I got the upper one going back to the engine from up top-no problem. The two going to the heater I think I can get from under the car. The one coming out of the engine is 1" below the one going back to the engine and It's blocked from the one pipe from above. I think other than a bur grinder to slit it (hate to do- risky) a locking Vise Grip C Clamp appears to be the only option as it sill allow the throat to get around the upper pipe. Any other Ideas??? Alcan - have you done this nightmare job??? Back three spark plugs are easy compared to this!!!!
    Al
  • alanwagenalanwagen Member Posts: 28
    I noticed some seepage from my 96 Chevy Lumina 3.1. What I did was to tighten the intake down.
    I think it loosens up after a while. (116,000 and still uses no oil)
    My advise is to torque it down, so far it has worked for me. It uses a 10mm socket and/or wrench.
    Also in the owners manual it said when you change coolant to put a stop leak additive, I. E. Bar's Leak Stop.
    Has the problem been fixed in later model versions of the engine?
    has been fixed. My '92 Corsica was in the shop for the problem $420 worth. They also did valve cover gaskets and a couple of other things. Anyway the service manager pointed out another vehicle in the shop with less than 36,000 (warranty) which was being operated on. He said it's still occurring. I believe it was a Malabu 3.1. Did you put the Dex-Cool in?
  • yurakmyurakm Member Posts: 1,345
    http://www.imcool.com/articles/antifreeze-coolant/dexcool-macs2001.htm
    Thank you for the link!
    I had the same contamination in coolant tank of my 98 Chevrolet Malibu with 3.1l V-6 engine. I would say even much more pronounced.
    Recently asked for coolant system service at my local Firestone, because of the sediment and because I had to add a quart of 50/50 DexCool solution every tree months. Was not sure if this is an evaporation or small leak, even more that the Malibu manual states it is normal to add coolant up to four times a year.
    The mechanic told me DexCool does not need be replaced before 100-150,000 miles. I told them about the need to add coolant. They started from pressure test and found a leak on the top surface of the intake manifold gasket. Now the car is in shop, undergoing the gasket replacement.
    Had the the reddish sediment in the coolant tank from the very beginning, when I bought the car used with 15k miles. Serviced it first at dealer, than at a very good local Firestone shop after the original warranty expired. They added coolant every 3 months. But nobody told me before this sediment is not normal.
    The contamination looks natural with the orange DexCool coolant: the iron oxide, i.e. common rust, have practically the same color, only more dark Most probably, even certified mechanics may not know this is tell-tale sign of rust.
  • jajacobsjajacobs Member Posts: 1
    Hi guys! Just reading the posts about intake manifold gasket leaks. I have had the same problem with my '99 Malibu LS with the 3.1L 3100 V-6, 170 HP NE emissions version. At 16,000 miles I had the lower intake manifold gasket replaced. At 24,000 I took it back to the dealer and told them oil and coolant are leaking from the lower intake at cylinders 2 and 6 AGAIN. This time they told me there is no leak. (This is the same dealer that tried to tell me that it is "normal" for the front crank seal to leak too. After told them that I am not that stupid they replaced it for me. Yes, the front crank seal and oil pan gasket has also been replaced) Something is visilby running from the lower intake I know it leaks, in fact the car hesistates throughout from about 2000 RPM to 4000 RPM, indicative of internally leaking gasket (OBD II obviously has not yet detected the decrease in vacum, no check engine light). For those who are wondering my car is maintained and kept in top running condition. The car is treated with finest care and service the entire vehicle personally. I use standard petroleum high-quality 5W-30 oil, changed every 3,000 miles. My car looks perfect and is treated as a fine driving machine (even if it isn't a BMW). Just wanted to let you guys know that even the new 3.1's are still leakers in the top-end.
    I've owned a '92 and a '94 Corsica 3.1. It's a great engine, but I have also had the leak in my'92. The other thing to watch out for is those damn Delco/Packard Plug wires. I have had multiple failures on different sets even after replacement. I finally switched to Autolite. I am assuming this is not the cause of your hesitation??
  • parkavenueparkavenue Member Posts: 2
    I own a 1995 Buck park avenue with close to 80,000 miles.
    When cruising at aproximatly 55 MPH ( aprox 1,800 RPM) if I try to encreasy the speed the engine start missing, it feels like one cylinder is missing).
    Where can I find information to troubleshoot the ignition and fuel injection systems in my car.
    I need the wiring diagrams of the ignition and fuel injection systems and the physical location of the sensors associated with the systems.
    Several years ago a had a similar problem with an Oldsmobile 6 cylinders and found the problem to be a spark plug wire, the wires in the Buick check ok as far as continuity is concern.
    Any sugestions will be apreciated.
    Abel
    I'd check the coilpacks. Frequent problem at low rpm, hign gear on the 3800 V6.
    Does the problem go away if you shift out of overdrive at the same speed?
    First I would go ahead and change plug wires. They are inexpensive. Also if you plug wires are bad, they will cause your coil packs to go bad.
    As the car heats up the wires break down and start arcing.
    Try that and that alone may fix your problem.
    GM ignitions are of such high voltage that they tend to be hard on plug wires. If you have ever noticed that the plug gap is something like .60 which takes big volts to jump such a large gap.
    But that is one reason GM motors have decent HP and torque and yet get decent mileage.
    I have a 2000 Impala with a 3.4 and I got 33 mpg on a highway trip.
    Alan
    Thanks to all of you for the sugestions, I will replace the spark plugs wires first and check the coils if wires change don't work.
    I will also try the overdrive sugestion and let you know.
    Thans. Abel
    I had my intake manifold and valve cover gaskets replaced about two months ago. I hope this is the last time I have to make this repair. Has any one had an unfortunate return trip to the service department for this fix?
