I do find it interesting that the 2.2L in my wife's old Cavalier had no power at all compared to the 1.8L in my Protege. And let's not even talk about the 2.3L in my old Mazda b2300 pickup, 8 plugs or not. Let's hear it for DOHCs and 16 valves!
Meade
If you like 16 valves in a 4, you should try 20 with a turbocharger attached...
This link ought to help prove my point. If you own a turbo, you've got to be meticulous with it!
http://www.turbotechnics.com/turbo/tips.htm
Sorry friend, normal aspiration for me anyday!
Meade
Meade
Anyway, the point is, the turbo in the Jetta, used in many other vehicles such as the Audi A4, is a much better turbo than any prev. gen. Saab.
And if you ever dump soda on the floor in your car by accident (hopefully not on purpose), you will be darn happy to have black instead of gray mats. Also, black doesn't show dirt as easily either (at least the VW's doesn't).
The 1.8L is a much happier engine, IMO. It feels smoother and stronger, and sounds much much much better than the 2.0L. My first comment when I drove the 2.0L was, "Is there something wrong with this engine?" It sounded a lot less happy than the 1.8L. The 1.8L growls as RPMs rise; the 2.0L whines. I drove more of the 2.0L's... Same thing.
There is no doubt in my mind that the 1.8L cars are quicker. The 2.0L has more power, but it has to pull around that extra weight. On an interesting note, my '99 ES was recently tested on a dyno before and after my Injen Technology cold air intake. Compared to dyno's I have seen for the 2.0L, the 1.8L actually has a flatter torque curve and puts just slightly more power to the ground! I am not sure why, but the tech guru's on ProtegeClub.com were not surprised. I think it has to do with the shorter stroke and the 2.0L's larger brakes, wheels, tires, etc. More weight to move between the engine and ground...
You can see the dyno results on my webpage:
http://www.caliprotegemeet.1hwy.com/mycar.html
C'mon guys, why are you arguing? Ever had a black pair of pants? Ever had a pair of khakis? Which shows lint, hair, etc., more?
No-brainer! Stop arguing!
Meade
Meade
Meade
I know black clothes have a lint problem (I have on a black shirt right now), but never really did notice it in the car, especially not on the floormats.
Yeah, I find it on my gray seats and mats too -- but only after I find it in clumps on the vacuum cleaner brush.
Meade
"More info and not some new 2.0 owner trying to justify why his car is better than my 2-year-old car!"
You asked this morning and I answered. I have a feeling you were looking for an arugument by the way your original post was worded. I guess I didn't give you the right answer. I prefer the 2.0L because I like low end power. I haven't driven the 1.8L, but I know that it is more of a peaky engine. There haven't been ANY 0-60 tests by reputable (C&D, R&T, Motortrend, Automobile) mags on the 2.0L sedan with a 5sp. I told you that if there is any difference in acceleration between the two, it's small. What's wrong with that? Did I say that my car is better than yours? What do you want me to say? The 1.8L is MUCH, MUCH better. I wish I would have bought the 2000 instead of the 2001. Geez, I guess I have to learn to never, ever, disagree with you.
Meade
"Lack of power had been one of the few negatives leveled at the Protege. That claim will probably not be heard again. The car accelerates easily — though still rather noisily at low rpms — and sounds happier the higher it's revved, finally red-lining at 6,500 rpm. This results in good mid-range acceleration, just where you want it for passing or powering out of a curve."
The 0-60 times, 1/4 ets and speeds are about the same, IIRC, so I don't put much stock in the claim that one is quicker than the other. On the other hand, they do have different power curves. The 2.0 has more low end torque. Personally, unless its something like one of the Honda VTECs which do the high end so well, I'll take it down low. Besides, the engine is the weak point of the Pro IMO. I personally am not too fond of either engine. If my first concern was engine, especially if I want a high winding engine, I wouldn't purchase either a 2.0 or a 1.8 Pro. YMMV
http://www.permatex.com/auto/autogr.asp?f_call=get_item&item_no=16067
Apparently, it can fix minor chips in your windshield...something I'm really into as I have a fair share of tiny chips out of my windshield that I don't want to become full blown cracks!!
Ya little whipper-snappers.
Meade
Whipper-snapper? Hmm. I'm pretty sure we're the same age.
Does not compute. Does not compute. ;-)
-Jerry
"Plus, the 1.8L's horsepower curve is higher across the board!"
That doesn't make any sense. Mazda must have fibbed on the output of the 2.0L just like they did with the Miata.
"5-7 lbs AT THE WHEELS is actually quite an improvement and the gain comes in the RPM range used most often."
I'm happy that's quite an improvement, because I got a 6 ft-lb increase at the wheels with the Injen CAI. However, those 5-7 ft-lbs at the wheels is taken up by the 2.0L's heavier overall weight. I've driven both cars (over a hundred, literally) and the 2.0L offered nothing more than the 1.8L down low and the 1.8L was definitely better above 4,000rpm. However, in the automatics, there was a difference with the 2.0L giving better power down low, but the 1.8L still offered much more performance up high.
I gained 5 hp (102.8 to 107.8) and 6.2 ft-lbs of torque (105.0 to 111.2). Under 2,500rpm, I lost between 1hp and 5hp but above 2,500rpm there is a constant gain across the board. On the torque side, torque is pretty equal under 2,500rpm but a constant increase across the board above that.
The Injen intake looks and sounds terrific. Under normal cruising or light acceleration, the intake is quiet. Actually, freeway (65-80mph) cruising is quieter. But, under moderate to full throttle, the intake lets out a deep roar that sounds so much better than most "performance" exhaust systems. It really turns heads, especially from those modded Civic's and Integra's. The increase in throttle response is amazing and the engine revs so much easier, particularly 5,000rpm to redline.
The MAF sensor is positioned about midway in the intake. As you can see, the entire stock air intake system is removed and replaced. The Injen CAI runs from the throttle body into the fender well where a cone (cotton gauze, mesh reinforced) air filter resides. The stock MAF and IAT sensor are used. Also, the purge solenoid valve and coolant resevoir had to be repositioned. The only downfall to the Injen system is the price... about $320. But hey, I got mine for free! :-)
-Jerry
BTW, the Injen CAI isn't really loud, from what my friends tell me. They say it is a low rumble which, unfortunately, can be heard several blocks away. It does attract a whole lot of attention because it sounds like some kind of exotic sports car. I love it, but I don't want the attention of the police. If I do see police around, I just take it easy with the throttle and it's as quiet as stock. What is strange is that this CAI is loudest between 3,500 and 4,500rpm. I wonder if it has to do with VICS opening up at second intake runner...
You can get a bypass valve to shed any water that does get in, but the guys at Injen told me it produces enough drag to almost negate the effect of the CAI.
-Jerry
-Jerry
actually that works out perfectly, by that time I should have the Protege paid off and will be free to make any move I want without fear of going upside-down on loans
These are the same graphs for a 1.8L 2000 ES.
95 Mazda Protege. I've never done this before though
I do have the Haynes manual. If anyone has experience
doing this I'd
appreciate an email at mikemore@rocketmail.com
Mike Morehouse
http://mazdaprotege.net/tech/howto/rightaxle/
Like that's ever stopped anyone...teeheeheehee.
"Like that's ever stopped anyone"
HeHe... :-)))
-old head
-PF Flyer-Host
Prepare me! I haven't read the letter yet, but I just want to know if these changes have been tested MORE THOROUGHLY than the last major changes that took place here? I know you weren't HERE then, but I'm sure you heard all about it! It was a DISASTER. NOTHING worked right,...
-fastdriver
...were going down for at least 4 or 5 days, yikes
-Larry
-Larry
