Mazda Protegé
1682683685687688754
  • ashutoshsmashutoshsm Posts: 1,007
    The Mazda numbers include (unfortunately) the badly built Ford trucks and SUV resold, respectively, as the Mazda B Series and the Mazda Tribute. Leave those aside, and consider only Mazda's sedans (the Protege and the 626, then the 6) and you have ratings WELL below industry average. I wouldn't be surprised if they were better (ratings for just those 3 models) than most other supposedly better manufacturers'.
  • mdaffronmdaffron Posts: 4,421
    You mean well ABOVE?
    Why am I Discussion Editor this morning???
    Wordman
    LOWER numbers are better, when what you're measuring is problems reported per unit (whatever).
    Get Falkens for Zoomster, rid yourself of the slow (larger diameter!) BFGs. You'll get back up to speed and more satisfactorily discharge your pro-bono duties as self-appointed Discussion Editor ;)
  • anonymouspostsanonymousposts Posts: 4,202
    ashu: The Tribue and B-series are still Mazdas and should be counted against them much as the Passport and SLX were still counted against Honda/Acura. And even if you only want to count their cars you have to consider the Protege is 5 years old, the 626 has been made since 1998, and the Miata is essentially unchanged since it's introduction in 1991. Other higher-rated brands have had several new models introduced in the last couple of years and are still ranked highly.
    Basically, you can't take the models whose quality ratings you like and say those are the cars which the manufacturer should be judged by.
    For every turn of my axle, I'm going farther -- they're FASTER!
    And the wider footprint means they corner better (well, theoretically, all else being equal which it isn't).
    How'd that Pontiac ad go? "LA HOOLA OOOOLAAAHHHH!!!!"
    Meade
    Mazda's presence under some Ford hoods probably saved Ford from the Kia end of the list too.
    Meade
    ... explain yourself in a bit more detail.
    So - they're 5 years old. So what? They've won or been in the top 3 of every comparo ever since they were introduced.
    And the Passport built by Isuzu isn't nearly as bad as the problems the Ford truck lines seem to have that creep into everything.
    SLX - what's that?
    How do I need to explain myself in more detail?
    Even if you only look at the Mazda cars such as the Protege, 626, and Miata you must realize that none of them are new models so they should no longer be plagued by "first year jitters". Other higher-ranking brands have had several new models introduced which might have a couple of first year bugs which would lower their score.
    Regardless, you can't look at a couple of models that rank highly and say you should only look at those and disgregard their lower-ranking models.
    "So - they're 5 years old. So what? They've won or been in the top 3 of every comparo ever since they were introduced."
    What was the last comparison test a 626 won? Even the 6 has had only 1 win in a comparison test and that was against a Jetta and an Altima, not against the real heavy-hitters in the mid-size sedan category. Or maybe you are talking about the Protege...could you explain yourself in more detail?
    So Ford is worse than Isuzu? Isn't Ford helping with the new Protege (poor Protege)? And isn't the Mazda V6 a Ford-based engine? Hmmm... sounds like you shoulda bought something else if your opinion of Ford is that low.
    The SLX was a rebadged Trooper but became extinct when the MDX came out.
    Seems kinda dead horse material to me ... but since you brought it up ...
    I don't really put much stock in those quality surveys because of their limited scope. I go by personal experience. Here's mine:
    1992 Protege - flawless until it got totaled at 28,000 miles.
    1992 Protege No. 2 - flawless. Traded for Mazda B2300 pickup (aka "Ford Ranger") at 83,000 miles.
    1994 B2300 pickup -- I have a stack of about 50 service receipts that aren't routine maintenance. I'm not exaggerating and I'll show 'em to you sometime. Met with Mazda NA regional service manager three times; Mazda wound up paying for most of the trouble and rental cars but that's not saying anything about the inconvenience of having to visit the shop and car rental places nearly every month during the 4-1/2 years I put up with this miserable example of Ford Quality.
    2000 Mazda Protege - Flawless. 59,000 miles on it now.
    Wife's 2002 Mazda Protege5 - Flawless. Wife has 20,000 miles on it now.
    Just speaking from my personal experience; YMMV.
    Meade
    Almost bought a new F150 the other day but Ford's quality scared us off, especially if we are going to pay $20,000 or so. Might as well buy an Element.
    To save ourselves about $15000 vs. a new F150 or an Element we are about to buy a 1997 Dakota V6 club cab to satisfy our need for a Home Depot-mobile and something to get our bikes to the local trail. A little scared of it too but it's cheap so if it's a piece we will sell it .. QUICK.
    I have no doubts the Protege is a reliable car. My only argument is that you can't say that you should only judge Mazda by cars you think do well in quality tests. We all know that is unfair. You could turn that around and say the Corolla is more reliable than a Camry so only look at the Corollas quality ratings.
    But I digress...zoom,zoom.
  • mazdafunmazdafun Posts: 2,329
    If the vehicle in question is what you're considering, then its own reliability should be examined, in addition to the overall record of the make. Why would I consider the record of an SUV when I'm interested in a compact? Or vice versa?
    I seem to recall R&T or MT correcting a DIRECT comparison article between the Accord and 6, stating they'd tied, or the 6 was slightly ahead instead of the Accord being slightly ahead.
  • oskwioskwi Posts: 88
    I agree with mdaffron regarding those reliability reports...IMO, it's all a conspriacy benefitting whatever car manufacturer they want to. Having a plethora of stats. and research education, I consult these reports but remember to keep their bias in mind...you have to as a researcher! Personal experience carries substantial weight. Having come from a VERY troublesome Chevy, I cannot fathom that their cars have less problems then the industry average. A red flag should go up!!! My Chevy had over $10,000 of repairs made on it in four years...these were not the average tires, belts, fluid changes, brakes, etc. These were a transmission, three air conditioning systems, several ABS sensors (at $500 a pop, these can add up quick!), cooling systems, etc. The experience, and that of many of my friends and colleagues, soured me on ever buying "American" again. I went to Mitsu and took a gamble since much of the car is Chrysler...luckily no problems. The only repairs I have made are a radiator cap ($14), a faulty transmission pan gasket ($40 w/ new tranny fluid), and some burned out switches over the course of 180,000 miles. In comparison to the Chevy, ZERO tranny problems, and the original coolant in the air conditioning system that still provides frigid air.
    All in all, go by research COUPLED with your experiences and the experienes of other owners. I have a tough time with the latter because no one drives my 36,000 miles per year so that part is a gamble.
    mdaffron...new Protege sitting in my garage with 3000 miles in three weeks...ZERO problems, not even the new car worries that need to be corrected...couldn't be happier!
    The 6 has won numerous comparisons. The one where it was edged out by the Accord (Car and Driver?) the next month's issue cited a mathematical error and declared the 6 and Accord joint winners. It won Automobile mag's All Star. The others were all tested and eligible and lost.
    I bought the 4 cylinder Mazda6, but only because of availability/gas prices/demand-supply (on the manual V6) issues. I would have happily bought it if I didn't value my gas money, and if they were available and the demand didn't force prices through the roof! And stop insisting on carrying on with the disparaging and misleading "Ford-engine" story - the block is Ford casted, the header, valves, VVT(-like) system and everything else are all Mazda designed!
    I'm only responding to this here since you brought it up - we shoul take this to the 6 and comparison boards, although this is truly a dead-horse discussion there (Ford input on the V6 engine)
    Check all the car washes.
    Check all the schools.
    Check all the police stations and holding cells.
    It's been 10 days since Dale has posted.
    I think she really may be lying face-down on the kitchen floor with maggots all over her this time.
    Meade
  • chicagoprochicagopro Posts: 1,009
    it's been even longer since Krotine posted.
    Where the heck is he??
    BTW, I'm doing just fine...hit 26,000 relatively flawless miles last night. :)
  • meinradmeinrad Posts: 820
    was with us Tuesday afternoon!
    Wow, same make and model year, more than twice the mileage.
    Speaking of MIAs -- where's Love Train?
    Fell into that fryer at CB and all they found was a can of Mother's and a clay bar?
    Meade
  • dinu01dinu01 Posts: 2,586
    some other PRO owners are:
    Pete
    Larry
    Mike and Michael both from Calgary
    Dinu
    PS: The PRO's doing great! I should clean it this weekend.
    Another question: Is it ok to call a certain car the PT Looser instead of its correct name? Meade, any thoughts?
    BTW, my Pro's just fine. Finally got to wash her a couple weeks ago and she was so sparkly!
  • speedyptspeedypt Posts: 200
    Sorry for my absence of late....work is extremely busy and I don't get much "surfin" time.
    Had some good size hail here in IL and Trigger suffered a broken windshield and a few dents. The dents are barely noticeable so I doubt I'll be having them fixed, but the windshield will be done as soon as I find a good place.
    Can anyone share windshield replacement costs as a reference? Did anyone else insist on a new gasket or OEM glass? Insurance is picking up the tab on the windshield which is nice.
    Nice to see some of the originals still here!
    Pete
    P.S. Hi Pat!
  • fowler3fowler3 Posts: 1,919
    Is that Paul Trading again? LOL!
    When I washed my Pro a while back first thing I looked for was scratches or chipped paint on the rear bumper. From when a Lexus RX300 rearended me at a traffic light. Only two tiny marks about the size of pinheads. Sure sounded like they would be a big.
    fowler3
    When I lived in Virginia, a neighbor traded cars every 30 days -- all new ones. Said he wanted to try them all. When he ran out of cars he traded for pick ups. Doubt I would like all that haggling.
    fowler3
    Reminds me of a neighbor that would trade a brand new car every four to six weeks for another brand new one...status was more her thing...we're talking Saabs and Mercedes mostly. Then she would get miffed that you didn't waive to her when she drove by your house...who could keep up??
  • vocusvocus Posts: 7,777
    This time, it wasn't me trading. My Jetta was totalled, so I didn't have a choice. I got the PT because of the good price, couldn't resist. Starting to really like it alot.
  • protegextwoprotegextwo Posts: 1,265
    “Speaking of MIAs -- where's Love Train?”
    “I wonder where some other PRO owners are: Larry??”
    I would post more often, however I prefer to post at web sites, which allow a tad more freedom of speech. Nothing against this thread or Host/Hostess, mind you. :-)
    I do miss the Mazda Protégé chat and give and take at Edmunds circa 2000 – 2002.
    Respectfully,
    Larry
    To fix a very big stone chip on my hood. The stone hit with such force it chipped a half dollar size out of my hood. Took the clear-coat, paint & primer down to the sheet metal. Left a tiny dent in the center. Well, there goes my $400.00 Bush Child Dependant tax refund! I'm so mad I feel like setting my car on fire. Yikes, never mind, I heard that doesn't work....Hey, Meade give me a call sometime. :-)
    -Larry
  • heyjoe11heyjoe11 Posts: 20
    Did the 2001 pro lx come with standard keyless entry? I thought it did, but when I took it to the dealer to get a key fob the mechanic took a quick look at the drivers foot well area and told me it could not be done. Where is the unit needed to program the key fob located? I'm pretty sure the 2001 lx had keyless entry and if I can tell the mechanic where to look for the control unit I can have one programmed. I searched the forum before posting but could not find any info that answered my question.
    In Canada one had to get a special package to get it and it was only for the 2 front doors. It did come standard on the ES though...
    US specs have always diferred from Candian ones, so I can't say for sure...
    Dinu
  • boggseboggse Posts: 1,048
    Is yours a 1.6L or the 2.0L. The offered both in 2001. That may have been the difference.
    My LX is a 1.6L.
Mazda Protegé - Page 685 — Car Forums at Edmunds.com
