Jeep Owners: Accessories & Modifications
I just bought a 2005 Wrangler (Rocky Mountain Edition) and I'm excited by the idea of just hosing everything down at the end of the day (I'm hauling salty/sandy scuba gear to the beach and back all year).
On an unrelated note, I really like the look of the wider tires that stick out a bit. Can I just offset my existing tires (30x9.5x15) or is a wider tire (11.5 or 12.5) needed? Can I fit a 31x11.5 or 31x12.5 on my Jeep without lifting or cutting the fender?
Thanks for any tips/suggestions!
What would everyone out there recommend? I've heard that some of the crossbars create a whistling noise while you're driving?
What do I need in the way of skid plates (I'm a newbie to 4-wheeling)?
How much can I expect a dealer to charge for this?
Are the crossbars something I can install myself, keeping in mind that I'm not the handiest guy, and can I get them cheaper going through someone like Kragen?
Thanks for everyone's help
craig
There are a couple of companies that plan on offering an interface for the NAV system. These interfaces are not out yet. Check out these websites:
http://www.discountcarstereo.com/detail.aspx?ID=885
http://peripheralelectronics.com/web/home.asp
I like my carpet and how it looks, so I'm inclined to keep it until it looks lousy. But a sprayed in bedliner would sure make having it in the water and mud a lot easier.
-Paul
i think i'm gonna pull the trigger on this... won't be worried about sandpiles in the jeep anymore!
My estimate wasn't TOO far off. Maybe call around - I bet you can get better pricing.
-Paul
1- clearance in the wheel wells (esp when turning)
2- backspacing of the stock wheels (probably 5.5").
Wider tires mean generally that you need less backspacing like about 4" to fit wider tires. Straightline driving won't be a problem, but when turning, your tires could rub the underside parts of your Jeep.
If you are insistent on keeping your factory wheels, you can use wheel spacers like the ones found at Spidertrax. They have their own lugs, and are not like the older style spacers which fit on the same lugs as the wheels themselves.
Here's what the spidertrax spacers are like (on my Wrangler):
You can see where the original lugs attached.
-Paul
-Paul
Jake
Here is a pic of it (kinda) on my dash...
Bigger units have been mounted alongside the center console on either passenger or driver side.
Some mount under the dash on the passenger side.
Now for the antenna, most mount it somewhere on the back. I had an Arizona Rocky Road antenna mount (www.arizonarockyroad.com) that held a 2' wilson antenna about 1' over the roofline. It mounted with the stock tire carrier.
I now have a Jeeperman tire carrier and I have my 4' Firestik attached to it.
Hope this helps some.
I have seen some that mount to some kind of mount tied into the taillights too.
I have found that with offroading in the trees, having the antenna mounted closer in to the center of the vehicle helps quite a bit.
-Paul
Another question....What do you guys think about Lift Kits....is it a better route to spend 500 dollars or so and get the supension lift?...or should I save the money and get the do it yourself lift kits? Someone told me if I do it myself I will run into problems with it in the future...and in the long run The supension lift is the better deal....but I dont know.... can someone help...
- Springs - front/rear
- Shocks - front/rear
- Sway bar connectors (Running JKS quicker discos now)
- installed sway bar relocation bracket in back
- installed adjustable front end swaybar
I've had the lift on for a year now, and I've had ZERO problems with it.
My lift is actually 2 lifts - one is a suspension lift that I just detailed, and the other is a body (spacer) lift that lifts the tub off of the frame 1.25".
If you look at the pic below, you can see the gap in the rear wheel well between the tub and frame. That is the body lift. Again, a simple DIY job, provided you have a floor jack or some way to safely lift up the tub a bit while you do the work.
Lifts over 3-4" will lead to bigger issues and may be what the guy was talking about. However, properly addressing all the issues, such as with steering geometry/drop pitman arms, etc, track bar adjustments, etc will eliminate the problems. One issue with bigger lifts is that the wheels/axle will be rotated 'in' closer to the center of the vehicle so the effective wheelbase is shortened even more. A Long arm lift or adjustable control arms for the axles can both address it.
Personally, a 3" lift with a 1" BL will give a 4" overall lift and is about ideal for a Jeep, IMO.
-Paul
One of the 4 was a PAIN for me. They are held in with LocTite. If you can head the bolt up a bit w/o hurting the paint, that will help.
Ways to get em off are:
1. GOOD Torx bits, not the cheapies from Autozone. We're talking Craftsmen here. Less likely to bend.
2. Insert the Torx bit that fits - THEN go the next size up and make sure it doesn't fit. It is easy to use the wrong size Torx bit.
3. If it gets stripped out, you can try using bolt extractors (reverse drill bits).
4. If your bolt extractor breaks, you can use a small drill bit and drill a hole through the flared part of the bolt's head. Once you have a hole, a hole punch or other long slender object can be put in that hole and hit with a hammer (in the direction of removal - counterclockwise).
Don't ask how I know about 2, 3, and 4.
-Paul
Keep in mind, part of the process of offroading involves looking out your window to see your line. With a 4 or 5 point harness, that range of motion will be seriously inhibited.
That said, the best way to do it is the right way. You will probably need to install a cross bar to your sport cage (you have a full cage right?) that goes behind your seats. This will hold the harnesses on properly.
Another option may be to get deeper bucket seats, like PRP or Mastercraft and use your existing seat belts.
The Mastercraft, SummitRacing, or PRP websites I think have links to properly installing a 4 or 5 point harness system.
-Paul
My jeep has the standard roll bars. I thought to mount them to the bars or drill into the body of the jeep at a 45 degree to the seats. since i dont have any back seat. but i also dont like that idea because i would not be able to use any best top products like the duster etc. I just want to be safe.
You making the Windrock trip this week in that YJ of yours?
-Paul
Windrock is in Oak Ridge, TN and our trip is this weekend.
-Paul
TJ's can run 31" tires without any lift, provided you're not offroading it. Are these tires going to be 10" to 11" wide? I'm assuming so since you are wanting 9" wide wheels. You'll need anywhere from 3.75" to 4.25" of backspacing to keep the front tires from rubbing the control arms at full turn. The less backspacing there is, the further the tires will stick out.
Mileage will depend on your engine, tranny and axle gearing. I have a 4 banger with 4.11 gears and 31" tires. I get a whopping 13mpg if I'm lucky!!! If you have 3.07 gearing, you'll wish for 3.55's, 3.73's or maybe even 4.11's. Even if you have the 6 cylinder.
Tire changes to a 31 inch wheel has a history of costing 1.5 to 2 mpg, you'll need to lift the rig at least 2 inches to fit them and probably also have the trim some plastic and flatten the pinchweld at the back of the front wheel well. Going over 2 1/2 inches of lift on the Liberty is not recommended if you want the front CV & ball joints to last. Even at 2 1/2 inches you'll possibly have problems bringing the wheel alignment within specs.
I am new to the Jeep world after driving Chevys for 10 years. And I love the 2005 JGC Limited that I bought. There are only two downfalls to it. I can not get the data center (where it tells you miles, mpg, temperature etc.) to stay in english. Is there any way to set it so it defaults to english? Every time i start my car I have to set it back to english.. I also cannot figure out how to change the time.. it has the navigation in it so the time is on that screen... help would be much appreciated.
If it is just the dongle, you can get it cheap off eBay and the owners manual tells you how to program it.
I have a used one that I can give you, just pay shipping.
Dan
1) 2007 Jeep Liberty Sport 4x2
2) 10,900 MILES!!!
3) 4-speed auto
4) PERFECT interior
5) [Rockred?]
Anyway, the price was just below 15 grand, and I was looking for one. Luckily I decided to stop at the dealersip because originally I was looking at their wrangler, but agreed on this. Thus far (a little over a week) it has been an exceptional vehicle. Although there are a few things i would like to ask about it.
I like a car with a little bit of pwer, which, in my terms, the Liberty holds. But when I am starting off from a stop sign or a redlight, it seems that when i push down the petal it takes a while for the transmission to kick in. Now, granted, this is nothing serious. It is probably something I will have to get used to. But its better to ask.
Next... What are accessories that are a MUST HAVE. Not a "must have" in the sense that you would enjoy them, but something that would make the car's resale value sky-rocket, or something that would make the car look better.
Lastly, I am having a problem with the front windsheild. In the bottom right corner there seems to be an air leak. Again, it is nothing serious, and does not get on my nerves at all. Is it something that I should get fixed now, or wait? Better yet, is it even something would be considered "fixable?"
Thank you all SO much!
I am the guy on the left, and after searching for a car for 8 hours (alone!), I was EXTREMELY tired, but in the same sense, i was very proud! It was the first car that I have bought after moving out of my parents house. Tell me how you like the car! Thanks, Trevor.
(if the picture doesn't show up, here is the link to it).
http://tinypic.com/view.php?pic=jpx004&s=3
