Many thanks
http://www.tirerack.com/tires/tires.jsp?tireMake=Bridgestone&tireModel=Blizzak+D- M-V1&partnum=475R6DMV1&vehicleSearch=true&fromCompare1=yes
I'm just wondering, it seems to not be getting fuel, its got a brand new fuel pump in it, was just put in in April, I'm trying to diagnose to see if its a problem other than the fuel pump, anyone who has had to change one knows why I would look and eliminate any other possibility.
Is there anything between the ignition switch and the fuel pump that can cause the problem at hand?
But if it is open, the fuel pump doesn't run at all. Now there are connections there that could be starting to have problem. The truck is now 15 years old...
Other possibilities, and probably a better possibility, is the fuel pump relay. There are beside or inside the fuse box under the hood are I think up to 3 identical relay boxes. If their plug in connectors are getting dirty, this could be the problem. Or could be failing. I don;t know which is the fuel pump one. Wiggle them around. Switch them around, they are all the same. Buy 3 new one. If you can decide which is the fuel pump, buy one new one.
On mine,t he fuel pump relay is the one in the center, there is a diagram underneath the power distribution top, so that I found, I will look into it further tomorrow when I have the day off.
Might be worth it to just buy one and replace it and see if your problem stops.
I replaced the coil pack and all the plugs and wires.
Does anyone have an idea of what this might be?
-A defective new thermostat, stuck open.
-A clogged up heater core, or if the system has one of those vacumn operated valves in the heater water line that is frozen closed - this would cause no heat. But, the temperature guage should show heat.
Why?
Of course, if it is the relay you should NOT be able to hear the fuel pump work when you first turn the car ON, before you start it. If you hear the fuel pump run, it isn't the relay.
There is also a 'rollover' switch under the end of the carpet, passenger footwell, to the left, on the tunnel actually. These probably hasn't been triggered unless you hit something or hit a big bump. There is a reset button on it. But the wires plugged in here may be loose. But also, if you hear the fuel pump, there is nothing wrong with this either.
If my son can't fix it, at least I know what I'm talking about when I go to the auto shop. Thanks again.
If you do get air into the ABS system, you cannot 'manually' bleed it out. The 'special tools' are electronic equipment that will fire up the ABS pump to purge the air out. Not sure of the cost, but probably expensive. I recommend it you get air in the ABS, you take it to a good brake shop.
If it's shaking but otherwise sounds normal, you may want to check the motor mounts... may have been compromised during the swap.
kcram - Pickups/Wagons Host
if it's taking to long to shift that could be a problem in timing or exaust clogging up exaust could also cause a loss of power making it take to long to gain speed.
the best way to check exaust is put your hand over the tail pipe with it running to see how much exaust is comming out, if it doesn't have much comming out there are 2 things it could be, flange pipe or catylitic converter. or timing belt might be off just 1 tooth. that would also cause your problem
