Honda Civic Care and Maintenance
The stock suspension system while it does have some drawbacks is really built for durablility and longevity.
Two obvious things that you have not mentioned come to mind.
1. What is the total weight of all that you transport? Next I would see what is the max vehicle load rating (mine is 850#'s). Then the obvious thing is to make sure you are within the parameters or more directly don't exceed it.
2. Upshot: do not overload your car. Is your tire inflation pressure enough to cover the load bearing requirements? So for example on my 2004 Honda Civic VP, the placard states 30 psi. However, I run the Honda's recommended (owners manual) 35 psi or higher speed psi recommendation.
Of next importance; longer wearing tires such as GY Comfort Treads or GY Triple Treads. You might lose .5-2 mpg but the better ride will be the reward.
The next thing that I would do given your situation is to go to (when the struts and shocks actually do leak or really crap out) an adjustable set such as Koni Reds/Blacks.
If you decide to go to a stronger REAR spring rate, then you really need to get softer shocks and NOT stiffer shocks than most rocketeers advocate. The adjustable ones are important for the "goldilocks" touch here. (Koni Yellows)
If side to side handling with the loads you carry are important, I would go no further than rear anti sway bars.
Can you get air struts to be able to maintain the right ride height for the springs and alignment?
There are no other symptoms, i.e. oil level/pressure is fine, runs fine, coolant level ok, nothing amiss other than the orange/yellow glow of the light.
(1) Does it hurt the car to drive?
(2) Is the brain really bad after only 35K miles?
(3) Any other ideas as to fixes besides replacing the brain?
I'm still curious to know if others have come across this DTC.
So a few months back I bought a 94 honda civic DX with just over 150k miles on it. I have always done all the regularly scheduled maintanance myself on all of my cars. Normally I run out and grab a couple manuals but the auto stores in the surrounding areas all seem to be sold out and I need to change the oil soon, as in I probably should have done it about 1000 miles ago.
I had all the usual things I need to do the job except I couldn't find the oil filter itself, maybe I'm blind or something. I checked the owners manual and it doesn't say where to find it. Instead it tells me to take it into a shop because I don't have some Honda specific tool. Now, I'm pretty sure I could find a way around this and if not I know I can get my hands on one. But none of that matters until I can find the oil filter.... So my questions are:
1. Does anybody know where the stupid oil filter is on this thing?
and
2. After all this, I've begun to wonder is there any honda specific or civic specific information that I need to know before doing this once I do find it (extra steps, tips, etc.)?
I don't want to have to take this into a shop just to get this done. I know it doesn't cost that much, but I'm a student and I'm honestly cannot afford even that right now.
Plus I'm cheap so I balk at the thought of paying someone else to do stuff that I should be able to do myself without too much of a hassle.
1) At what mileage does the timing belt need to be replaced? (110k?)
2) How much does it cost to replace the timing belt? ( dealers say about $1000)
3) How much do pair brake pads cost? (dealer - $250)
4) how much does the 60k service cost? (dealer - $500)
I interested in your answers based on your experience of owning a Civic.
I want to give my car for 60k service. I am looking for dealers in the Fairfax, VA and Vienna, VA area who do a good job at that. particularly Fairfax honda or Rosenthal Honda. If anyone has any experience dealing with these dealers please reply to this post.
-Rohan.
for the past 3 years, i drive only 4-5K per year on average. what kind of maintenance does it need at this time?
the auto shop suggests:
- replace spark plug (again)
- replace ignition wire set (plug wires, expensive!)
- 3-step fuel system cleaning
- throttle body cleaning
which ones are needed and which ones are not?
i noticed the tires rotation was done 9/05, does it need another tire rotation?
thanks so much in advance!
Sue
Question: who has a '99 Civic with over 300,000 miles and what major problems did you have? If any?
Thanks folks.
I have a japanese honda civic 98 and would like to know if it needs only coolant or I can also add tap water to the radiator.
thank U
ale
I am a little concerned about it, b/c I used to have a car that made a similar noise with the A/C on, and it turned out to be a bad bearing in the compressor. I was advised not to use it because the bearing could seize and cause an engine belt to fail. Am I taking a similar risk here? How big a deal would it be to fix?
Last, but most important, find another service place if the one you are dealing with now is insisting on doing things not in the manual. Even if you manage to override their insistence, can you trust them? I wouldn't. :sick:
Anyone else using synthetic oil already?
http://neptune.spacebears.com/cars/stories/mobil1.html
http://www.filtermag.com/
I will use mobil1 5-20 true synthetic (not blend):$6, m1-110 (for extension PURPOSES):$11, filtermag: $30 (magnet). I will change oil and oil filter every 8000 miles or 8 months to be safe.
QUESTION:
Is it possible to change tire size like 215/65/15, 205/65/15 or 215/60/16 for honda civic lx 2006?
i am using Royal Purple "synthetic" and i change it at 5000 miles - i know that's expensive, but two things: its not just oil floating around inside the engine after 5k, and, more importantly, its much easier to keep track of. if i was using regular oil, my oil change would be at 3k. oil is alot cheaper than an engine. i don't skimp on oil.
truehonest - are u running 15 or 16's - check tire websites for changing tires or wheels. although why you would want to run 15's on an 06 lx - came with 16's.
jopadman - i have 06 lx - bought in december - waxed it twice already, but that was about 4 mos later. if you don't have to, i wouldn't.(unless you need to get away from the significant other).
everyone... get a service manual - the one the techs use so that you can see exactly what they see, and they can't sell you crap that doesn't need to happen. yeah, its expensive, but it'll save $$$$$ in the long run.
Many cars are shipped by rail and they get a light coating of iron oxide on them from the rails. Some of the Subie guys did some fairly major detailing work to remove this. I think it invloved using a clay bar. I'm not 100% sure.
Most people don't see or feel this oxide from the shipping and never even realize its there. Washing doesn't remove it.
--jay
You'll want to get yourself a clay bar or two (Maguires is good), and go over the entire car, to clean out the paint. Here's a pretty good tutorial on what clay bars are, how they work, and what to do with them.
Your paint will thank you for it!
Advice?
now i just purchace 4 use tire, put it in the car and the steering wheel turn to the left a little bit when i drive. do i need to do wheel alignment. where is the good place to go to?
If I keep it for the entire 3 years, I would have about 135,000 miles on it when I sell it.
How many service intervals should come up and would it also need any very expensive maintenance service like a timing belt replacement?
The Sandman :confuse:
Just bought a '98 EX auto coupe with under 120k on it in great condition for 16 yr old son. Did major maintenance of timing belt, water pump, plugs and belts - everything else is great per trusted mechanic. Has brand new battery, new exhaust system up to manifold & almost new tires already.
One issue is key seems to struggle with turning in ignition and in door locks, really have to baby it to get it just pulled out a bit and then turn to unlock, start or remove. Any suggestions on resolving this troublesome issue?
One thing that I did slightly different from the get go was to put in the "high speed PSI" as per owners manual (again in my case- 35 psi) I think I will see (BARELY) 55-60k. As a comparison, I will see 115-125k on a Goodyear LS-H 195 65 15 H tire on a VW Jetta TDI, which is almost universally vilified as not the best OEM tire on that OEM and model. On a 44 psi max tire wall pressure I have run 38 psi fronts/36 psi rears.
While I think the Michelin Hydroedge and Goodyear Triple Treads and GY Comfort Treads are probably real good. I will mount up the Toyo Spectrums. Everything I have read and also my experiences with another Toyo tire has the preliminary indications that these will be good on durability and fuel mileage.
I'm enjoying my 2006 Civic immensely, and I recently gave it it's first oil change. Unfortunately, the oil life computer doesn't seem to recognize that I've actually changed the oil and filter. When I'm driving the little orange wrench light stays on, and when I start the odometer flashes negative mileage at me (presumably how far I've gone since it thinks I should have changed the oil) until I change the odometer mode.
The filter and oil change HAVE been done, at least 500 miles ago, and the car is running fine. It has plenty of oil and no leakages. Is there some trick to getting the oil computer to *realize* the oil has been changed? Any trick or gimmick I can use to shut off the warning?
It's an annoyance more than anything, but I'm hoping it's not pestering me just so I take it to a dealer and have them shut it off! Thanks for any input.
