Honda Civic Care and Maintenance
If you are technically inclined, the shop manual.
I need to change the oil on my new 2006 Civic soon and have a few questions. Did you find out how to reset your 2006 Civic oil life indicator? Was the oil change straight forward (excluding the oil life indicator)? Did you drive the car up on ramps or use jacks to get under it to remove the oil pan drain plug? What weight oil did you use? Where do you live, a hot or cold winter area? I live near San Francisco, CA, and have used 20-50 weight Castrol oil in all of the cars I've owned since the early 1980's. Got well over 180K miles on my previous 1981 Civic, with my only major engine repair being a valve job and no signs of engine wear when I retired the vehicle.
Thanks for any assistance, it is very much appreciated.
Lowell
Hope this helps.
Do such products hurt the finish, make them fade or degrade or void the warranty?
Does the shine produced cause glare for driving (dash area under the long sloping windshield is longer than most cars)?
Thanks!!!
There are low-gloss versions of Armor-All and the like that don't shine up the dash as much.
I can't see how using Armor-All on the dash could void the warranty--unless there is a warning about using silicone protectorants in the owner's manual.
I was thinking that the rougher surface was porous and more prone to retain dirt.
So a layer of Armor all would seal the pores somewhat.
I wondered whether Armor All would react with the material some way and cause it to deteriorate faster.
Only problem is, my town is bad for car accessory stores. Only basic parts chains like Kragen or Auto Zone. Or pay through the nose from the dealer.
So I'd probably have to shop online.
Need to get a good wax, some chamois. There was also a gloss protectant, called Der Shiny back in the day. It was suppose to give a glossy finish and used for aircraft.
P.S. Should I still follow the manual on the 10,000 oil change intervals for moderate driving?
i like Meguiar's interior cleaner. It cleans the rich, textured dash (which car manufacturers go to great pains to achieve) without that greasy shiny crap.
Regular oil, in my experience, doesn't hold up for 10,000 miles. in past cars, (toyota corolla mainly, and a couple of vw's), you can really tell when the oil is no good any more. changing it made the engine purr. so, with regular oil, i would recommend between 3000 - 4000 miles for oil.
you could probably get away with 10,000 mile intervals with synthetic oil - or so i have heard - i've never tried it.
other factors that come into play are - and this is all speculation - how long can the oil filter handle it - will it be clogged and/or can the filter element stay intact that long
with reference to the oil itselfafter so many miles, its not just oil floating around. moisture, acids from combustion and who knows what else could be in there.
my philosopy is this - oil is your engines life blood. its not worth messing with it. Its alot less expensive to change the oil regularly than a new engine. I change oil between 3 - 4K with regular oil.
i'm using synthetic now in my 06 civic and i change it at 5000 miles - mostly because it is easier for me to remember 5K intervals.
If not, follow the severe schedule. The mileage intervals are listed in the manual.
It's that simple.
But I wonder if I'm suppose to use it on the textured dash and also the front of the stereo and such, which is not textured.
Or the doors, the area around the window controls for instance.
If it's just a cleaner, no big deal. But if it leaves some kind of polymer film, maybe not a good idea?
I called 2 local Honda dealers and they also verified with me to wait until the oil minder tells you. Just curious why you don't follow what the manufacturer recommends about oil change intervals?
The Sandman :confuse:
I purchased my 06 civic in November2005. I had first oil change when it was 7500 miles. My dealer told me that I should have changed it when it was 5000 miles. I told him that I just followed maintenance reminder screen. Now it is 12300 miles and maintenance reminder says 40% to oil change which will be the time I guess 10% about 15000 miles. The dealer sticker says 10500 miles or 9/1/2006. I am confused what I should do. Listen to the dealer or maintenance reminder. I need an advise for the time period of oil change.
I get Emails and phone calls from the dealer telling me it is time to change the oil.I think Honda knows more than anybody what is considered proper oil change intervals.
I think the new system accounts for the variation in driving
conditions.Dealers don't care about your car just your money.It bugs me that dealer employees are not car nuts like me.I love cars,always have,always will,and if I was rich I would have a bunch like Jay Leno.So I will let the car tell me when to change the oil after all the reason we buy Civics is to reduce driving costs.
You can go by the oil life indicator up to a point. There is some maximum time interval though.
Even if you only drove the car 10 miles a month, you are still required to change the oil after some period (maybe 12 months) no matter what the oil life indicator says.
Folks,
I posted this to other boards in CIVIC with no replies. Hopefully, this board will get one:
I just spent over 780.00 on trying to get my check engine light to go out on my subj Civic. The final answer is "you have a bad computer" and to replace will cost 980.00. Well, if they ran diagnostics on it in the first place to correct a temperature Hi/Lo sensor and a transmission part (which makes the car run excellent now) how can that be. Now the answer is you need a new computer?
I own a car made in Japan, with a JHMED VIN...
it ststates on the computer:
37820-PM5-A550
601-139748
8 B
with a manufacture date of 87-12-24
I bought this car new in 1988, it has over 178,000 miles, it drove me to 5 ships and 5 shore stations and will be featured in my retirement ceremony after I get to 25 yrs in the Navy. Everyone hates it but I loove it. It is my baby blue car!
Are there compatability issues with the computers, some folks tell me that any computer in that family will work (1988-1991).
Happy Holidays!
Kevin, Senior Chief, Unitied States Navy
Why don't you also ask in our Got a Quick, Technical Question? discussion. Usually there are some pretty sharp gearheads hanging out there who may not see your posts here.
Good luck - let us know how it goes.
Try posting this also in our "No Start" Problems discussion. I think more people who can help will see it there.
Kevin
Transmission oil change? 40K sounds premature. More like 60K sounds right.
Simple enough, but the right front wheel lock was overtightend and ruined the threads. I was able to get
the wheel lock off but can't get it back on so I have to
take it to the dealer. They should take those impact
wrenches from the monkies who prep the cars.My only other thing is I bought the wrong car.If you have to park in
parking structures it is difficult to open the door wide
to get in and out unless you are short legged.So I try to
avoid having another car on the drivers side. :mad:
buggered wheel stud which was done under warranty and decided to have the oil changed since it was close to 6000
miles.I expected to have to pay for that but when I picked
up the car the invoice said no charge.I asked why and
the service rep said "for good customer relations".This was
in Poway California.One of the reasons I traded my Kia
Sorento in on this Civic is poor service.I don't think it is
Kias fault but Kia dealers are always combined with other makes and so the service department is not skilled in Kia.
I am so not happy with any of this along w/ the alloy rim damage from new tires being placed on it for the sale, backseat plastic shoulder guide broken and very evident (even though even I missed it during my review of car on day purchased)- and the trunk lighting is so dim! A glow stick lights it up better!
Lastly, can anyone explain to me what reasoning supports Honda designing the Civic without a under hood light? This is beyond common sense to me but last time I checked, lighting for the engine area was standard on every other car I've owned from Ford,Buick & Saturns.
Not a good experience and now having dropped it off earlier today to make paint and other repairs, I think I need another car.
hurricane Katrina.I saw on the news that those cars can be found in any state.
As for the lack of underhood lighting..well it is a Honda after all and they NEVER break down...joke, joke, joke. Seriously, most new cars don't have any type of underhood lighting any longer. There is nothing to see (most of a modern engine is covered by a plastic shroud) or repair by the owner under there anyhow. If your engine fails you can stand there all day and stare at the engine and see nothing amiss. It is all computer controlled with modules and sensors and various other black boxes that mean nothing to the average owner.
Ditto, it has suffered some type of environmental damage to the paint.
But this is a brand NEW 2006 Civic bought from Honda dealership! The title never left dealership until I bought it. I hear you on the rusting occuring in unusual places and very early in its life- and shouldn't be occuring at this rate from factory in Canada to U.S. dealership. I have contacted Lemon Law resources for the Mid-Atlantic to see what my rights are in this matter. This is pending as my car is still at dealership due to new issues on delays with parts ordered. I chose to leave car there to avoid only more inconveniences of ping pong dropping car off and getting loaners as the paint repairs only occur on Tuesdays and parts deliveries are further delayed. Did I mentioned they scratched glass with razor blade trying to remove film of unknown substance all over all windows said to be from factory window protection wrapping? This appeared 3day I had car and wasn't visible until after a major rain overnight. Dealership denies it is over wash from wax job but still hasn't gotten residue off all window surfaces to date.
These defects and damages are not what a new car should be sold with or that quality control missed, skipped what have you. I've been told by Srv. Mngr. the Manufacture Rep. will be back soon and I will have to discuss this with him.
Oil change was also done with 30% on the monitor with 5050 miles on the car and 7 months of ownership. Just didn't want to go much more on the break-in oil actually. And today was a holiday for me also. Turns out the oil change was free also & finally got some touch up paint to fix my garage door incident.
The Sandman
Will post back here next Monday nite after the TSB is performed.
The Sandman
