I was told that only a Jeep dealer can resolve this by applying some type of reset.
I hope this helps you, and good luck m8.
SO... try this. Once you have peeled back the rug in the driver's side footwell, look for anything suspicious as to where the water may be entering, pay close attention to the front tire well area. Next place a lawn spinkler under the front of the driver's side area to mimic driving on a rainy day, and locate your problem leak.
Question: Does your jeep still stall at stop lights?
Well, did they ever check the idle air control, located on the throttle body. This sensor, will do the exact same thing when they are dirty/gummed up, or need to be changed out. Oh, and so will a throttle postion sensor.
On a more happier note, your ignition system won't need replacment for a good while.
Check the inside of the tires, and fenderwell, for signs of rubbbing to see if they are in fact rubbing. Generally, the lower the vehicle, the more stability you have. If you install a 4" lift, then your center of gravity raises 4", and your stability decreases moderately. DEpending on your gear ratio, and im guessing it's 3:7:3, you may have to change your gears out to a 4:1:0 ratio for 33" tires. The 3:7:3 ratio will accept up to 32" tires without putting to much pressure on the drivetrain to turn all that extra rubber around. :sick:
The 4" lift is a good idea :shades: . Just be sure to get a good lift kit that will have everything you need, such as longer brake lines, poly bushing, new castle nuts/cotter pins where needed.ect.ect. ;
When the Jeep shifts from 2nd to 3rd, there is a noticeable "thump" or jerking motion... Almost as if it is holding on to 2nd a little too long... The thump is particularly noticeable 20% of the time, 70% of the time its modest, and 10% it shifts perfectly. Other shift points are smooth (making the hard shift from 2nd to 3rd even more noticeable).
My brother's 7 year old Isuzu Trooper (with 100k miles) shifts smoother...
Anybody have a similar problem and perhaps solution? Dealer says its "normal"...
I have a Jeep Grand Cherokee Laredo and this parts embarressing i think i have 31" tires but i am not forsure because i keep getting confused on how to read tires.I think that you take the P235 and X it by the /75 am i correct??because that would be 31"and that sounds like it would be right.so what do you think?sorry i know it must just be a girl thing hehehe.
-Jeeper 96
that is really nice.well,i have a 96 grand cherokee laredo and as you can see in my last message i am not totally forsure about my tires size.so i just want a small lift and was thinking about doing it this summer and i just want a few inches on the lift and the tires. i don't want a monster truck because i would then have to put little step bars on it to get into it.so just something that will look kinda cool to go along with my new custom paint job,its like when you start to go custom you just can't stop. -Jeeper96
So, the mfg reading from the table would be better than trying to calculate it out with rounding, etc :-) Looking at the table as well, you would probably have to adjust for rim width :-) good luck whatever you decide to do.
bill
I too had that problem, which I called the dealer about. You've described the problem perfectly, even regarding the other gears shifting smoothly. The service manager told me that this "jerking" motion was due to 2nd gear being such a low gear. I've also noticed some struggle when going up steep hills. It seems as though you've had better luck than I have. I've had problems every 3,000 miles that I've had to take it in for; it now has a little over 10,000 on it.
Paula
Thanks for the response. Interesting. Dealer's answer to me was Euro (Mercedes) trannies are harsher and that new trannies designed with less "slip" to prolong life... I actually took it to another dealer today (second opinion wouldn't hurt). So far, they seem mystified and have actually held the Jeep overnight for "more tests"... Will let you know what the diagnosis is.
I also reviewed the gear ratios and while there is a difference in ratios b/w the 3.7 tranny (Mercedes) and 4.7/Hemi tranny (Chrysler) - relatively speaking, differences don't seem that huge (I've driven a Durango with the Hemi and same Chrysler transmission and it shifted fine across all gears too)... This tranny is used in several Mercedes cars (E Class for example) since 1995 - makes me wonder, could they really all be like that? :confuse:
It was mostly HW miles at 75 mph.
Is that about the right mileage?
I would have expected 19 to 20 as it was level cruising with the Cruise Control most of the time.
What is everyone else getting?
Thanks, CK
Width x Aspect Ratio = Section Height;
Section Height x 2 = Combined Section Height;
Combined Section Height + Wheel Diameter = Tire Diameter;
(Example: 235/75-15)
235mm x .75 = 176.25mm (a ratio is a percent; 75%or.75);
176.25mm x 2 = 352.5mm (section above and below rim);
[Then you need to convert the mm to inches by dividing by 25.4, which makes 352.5mm = 13.9"]
13.9" + 15" = 28.9" tire height.
(I actually had to relearn that formula as I was typing it!)
Now that you know your current tire height in inches, we can forget about that for a while. I noticed that someone else replied to you about your tires and whether or not they rub. If they do, something isn't right! That "grind" you hear has got to be either some of your inner fenderwell is lose or something not related to your tires. As far as being easier to flip, the higher your center of gravity, the higher your chance of rolling. Most rollovers can be prevented by the driver. Once lifted, you'll notice that your Grand's body roll will have increased during turns and in curves. All you have to do is stay off the "go pedal". Lots of people seem to drive their SUV's like they're sports cars. That's dangerous enough stock. Add a lift and you've more than doubled your chances of rolling in a turning or lost control situation that could be just "scary" at stock height. Now I am definitely not trying to scare you away from lifting your truck! You'll just have to think about how careful you are now, and then be triple careful. You'll be a good bit more stable with a 2" to 2.5" lift compared to a 4" lift. Now I know your probably thinking "this guy is a sissy", but from the time I bought my 2000 Grand in Aug.'05, I could not wait to get it lifted. I finally convinced my wife to let me lift it as a Christmas gift to myself, and on Christmas Eve '05, in my garage, it took me about 45 minutes to add 2" in the rear and 2.5" in the front. Now it doesn't look like the front fenders are sitting on the front tires. And I had tires two sizes up from stock on it, with no rubbing, before I lifted it! This posting has become huge, so I'll start another in just a little bit! - dixiecrawler
mamby som body now wy the blower moter suddenly stops
thanks harry
If your brake pads are bad, and you choose to take them to a brake shop, and you have a 2- wheel drive, have them inspect and repack the front outer axle bearings.(most brake shops will do this for a small extra fee)
