I love my Jeep, I love it's body style and performance. Though, with the new body style I can't see myself buying another one.
I have driven both Dodge Durango's, Mercury Mountaineer and Mitsubishi Endeavor within the last two years. I get out of them realizing just how bad the Jeeps brakes are. My stopping distance is more than double either of these three vehicles. Even with new pads/rotors the stopping distance on the Jeep was long. It only gets worse as I drive on them. I live in the mountains I have to go up and down hills. I try not to break and instead down shift to a lower gear this does not help. The breaks still go bad every year.
- Stalls from time to time when idling - usually pretty soon after it has started up, and when the engine is cold (when it has been sitting for a couple hours). This has happened probably 6 times since I have owned the vehicle and I bought it new.
- The drivers’ side carpet gets really wet. There is no rhyme or reason for this one. The wetness is located just inside the door frame, but it gets better than half of the carpet wet. This issue has been apparent since I purchased the vehicle. This occurs in wet or dry weather, a/c is usually on all the time. I thought the carpet was dirty because someone got in with dirty feet and wet because it had been raining. Crazy me!
I took the vehicle to the dealership – Ferman, on Kennedy in Tampa, and they informed me that they could find nothing wrong with the vehicle. I currently have the vehicle at another dealership to see if they can solve the problem. I was wondering if anyone else has experienced these problems, and if so will you offer some guidance? Thanks.
and with your wet carpet, running the a/c all the time might be your problem. when an a/c runs, it needs to evaporate the heat, hence causing water, i know in my 2000 my drain line was ran inside but it was on my passenger side. the thing to do is to take off your door sill, note sill not seal and then take off the other plastic piece that is along the side. dont worry they snap right off and right back on and there should be a hose. if its not there it should be on the passenger side. it maybe a cut in the drain line as well and its leaking to the drivers side. i believe the condensor is on the drivers side and the evaporator is on the passenger.
Hopeless in Kansas! :confuse:
Today I noticed something on my Jeep that could be the culprit of all my troubles. How I missed it I'll never know, but I have a cross member,(at least that's what I think it's called) that is located under the tranny on the forward half of the car, that is bent. I've never noticed it before. I've got a 94 JGC that pulls slightly to the right. Could this be the cause of my problems? Please say yes! How it got bent is not known. No rough driving of any sort. I suppose it could be age, but...
Any replies will be appreciated!
is there any easy to get rid of this nuisance
what happens is my security system occasionally will come on and drain my battery and i have to jump start the car
most of the time i can prevent this by turning the door key
first to the left and then lock it by turning it twice to the right, but not all of the time, especially when it is cold
i have had my battery, starter, alternator etc checked and it is definitely the security system that is doing this
any suggestions
i want this thing removed without having to pay someone $$$ to do it
I wanted the same thing and got it. Go to a tire store; Discount, Big-O, Les Schwab, Pep Boys...tell them what you want and they will fit the tire properly into the wheel well without it rubbing. Don't forget that you have to take into account turning tight corners and such so the tire cannot be too big or it'll scrape. They will also set you up with the best tire for your driving conditions...no need in having a heavy duty mud and snow tire if you drive in the city...it'll just be too noisy. :shades:
I just recently bought a 95 jeep GC. I love this thing but quickly found a bunch of problems that have been discussed here. I took her to my local jeep dealer to find out they want to charge me over 4,000, bux to fix everything. like: rear needs to be rebuilt, viscous cup needs to be replaced, steering box is leaking, motor mounts are bad, and needs a trailing arm
You can find the cooling fan cheap on E-bay, or spend about $370 at the dealer.
There is no known way of fixing light, so I ended up replacing mine on my '01 JGC. The light circuitry is prone to having problems. And at the dealer, the lights are $150 a pop, so I went on E-Bay and got a set for $60.
thanks!! :P
FYI... My brakes sucks as well. Warp rotors every 10k. Has anyone tried buying third party calipers to see if that fixes the problem? It seems like the braking system on the Jeep only brakes on the front two wheels. Since my rear wheels are still in their virgin rotors and pad.
Husband took it to have a computer diagnostic done and it said the error # 1762. The Governor Pressure Sensor.
He gave that Number to the Jeep Dealer parts dept. and bought the part...which was a Governor Pressure Solenoid. Hubby replaced the solenoid and fluid/filter. It did not fix the problem and husband now thinks he should replace the Governor Pressure Sensor too, but doesn't know the part #.
He is going to take it to the Jeep Dealership to have a scan run on it tomorrow.
Any help in this matter would be appreciated.
This morning I had a flat tire and I had that changed(Right rear tire) with the same size tire as the other ones. It was fine until I got on the interstate. The Truck started pulling to the right and I could not get that much control of the car. I can go under 50 and it is ok. When I stop at a light, the front end almost is pushing down and makes a grinding noise. Any thoughts?? Something with the axle or bearings I believe? Any help would be awesome!
This is the 3rd time in 2 weeks that the radio and interior dash lights flicker and the brake and ABS warning lights stay on---and yes it has died after one of the episodes.
PLEASE HELP!
I can not get it fixed. Had back to the dealer 6 times and still no luck.
Did you get it fixed?
what was the problem if so?
any help would be greatly appreciated
