1- I have no brake lights, and my left turn signal works when its warm out. I dont know if these problems are connected, but thought it worth mentioning.
2- When I come to a stop, I hear and feel a cluck near the pumpkin, or center of car. Could this be a tie rod?
Can anyone offer any suggestions,Please
Could you please reply with any advice and possibly share how your issue was fixed?
DO it now or you'll be doing it later
Anyone else have a similar experience?
I thought possibly the corrosion on the battery cables and battery connectors combined with the increased moisture might be causing the problem. I have since replaced the battery cables (about $57) and the battery (about $79) and have had no more poltergeist problems. But it's difficult to know conclusively that the problem has been solved.
-chris
1. Control Panel Fault
2. Passenger Blend door actuator Fault
3. Circuitry between those two either open or short
4. Blend door blocked or broken.
Some of the newer Jeeps have self diagnostics. For instance, You can retrieve the fault codes for the HVAC system on the 2000 Grand Cherokee by simultaneously depressing the 'AC' & 'Recirculate' buttons and rotating the left temp knob clockwise one click.
If you attempt to repair it yourself...you may want to check if you vehicle has self diagnostics. It will give you a better starting point.
I just started to have problems after 45k miles. Passenger power window failed. I've got leaks under front end... afraid of what it might be. I'm thinking of buying an extended warrantee.
I'd like to fix on my own without spending a boat load at the dealer.
Any suggestions on a solution????
Any ideas as to what could be making this sound?? (I can just picture my Jeep blushing in embarrassment every time it happens !!)
Thanks in advance....
Has anybody else noticed this on there Jeeps?
2006 Jeep
http://rides.webshots.com/album/548697188kmhzhY
After I sold it I heard it might have been the MDS causing the noise. Good luck!
Thank you,
-a
