ebizsearch
Good luck-----------Smokey Swann-Odessa, Tx
One can easily see how dumb downed Mfgs and government(with regulations-- of nonsense) want us to become.
It simply means that should U lose the rear seal or tranny cooler and lose fluid you are forced to have it serviced by the Mfg--Dealer.
Have a good weekend
Smokebee
What does it mean?
Smokebee
Smokebee
SUVs and Smart Shopper
Smokebee
Today wouldn't shift into park, RND were fine. I drove it home.
Now won't shift out of R. Can't get it into neutral to start it. Shifter will move down to N and D, but remains in R. Will not go into P. :confuse:
Thanks for any ideas.
(1) When the vehicle is parked with no key in the ignition, the headlights come on, stay on for less than a minute, then go out.
(2) When driving the vehicle during the day (with the auto headlamp control in the "Auto" position), it seems as if the headlights flicker on, then off intermittently.
Any ideas on what my problem is??
F degrees. Might check radiator coolant temp to verify high enough temp to turn fan on. The fan relay is located in the same control center(box) as the fuses--passenger side ajacent to fender just in front of the coolant tank.
Smokebee
Short in the radiator fan? -- any other ideas?
Good luck,
Smokebee
Altitude
Help me if you can. email me at adolfson3hd@,mac.com
heater box is like flat with a bump hanging down on the bottom
easesy way to clean is drill small hole in the end of the bump and clean with wire through the hole then plug the hole up again
