Even Corolla will have to jump up a bit in the next iteration - all of its major competitors except Civic are above 140 hp now.
But today I cheked out that 05Matrix made some improvement and avaliable soon, I would like to test one and see how's going. Cause as a full-loaded XR, it still will be couple thousands cheaper.
All I need is a city wagon, and have good MPG, safe and perform great in like 5 years. I do worry a little about the maintance of diesel engin. So, what's your guys opinion? Appreciated.
Most of guys here on the 'trix group will feel, and I'm sure of this, that you should go with the VW. In part because your initials match...
Seriously, though, these are two different animals. Drive both, see what you like. The only way I'd get the TDI is if I were doing well over 20k per year, or I REALLY wanted a Diesel. The Matrix is more plasticky and louder, you sit higher, it'll be much more reliable, and I don't know which ones is more fun to drive.
I like both, but the only thing they have in common is the hatch and the 5speed....
-Mathias
The Matrix will be a LOT more fun. If that matters. Also cheaper to operate (virtually zero-maintenance) and most likely won't need a repair you are on the hook for in five years.
I'll echo steine also: Matrix will be a bit louder, more plasticky, and you sit higher. It also has the advantage that wherever you stop for gas, the station actually sells the kind you need. Unlike diesel.
-Mathias
I didn't pursue the Jetta after I found out that you can't buy them in Massachusetts. You can't even register a new one here if you buy it out of state. If you have one already and move here, then you have to apply for a waiver. All this should change in a couple of years when the cleaner diesel fuel is required in the USA.
The Matrix has much better passenger room in both front and back, and it gets better gas mileage. (Even my Highlander gets better gas mileage than the Jetta, and it runs on regular gas.) And in terms of reliability, I wouldn't consider a gasoline powered Jetta after reading the Edmunds forum on those vehicles. The Matrix does better than the Jetta in crash tests, too.
Yes, the back seat of the Matrix is super-spacious when compared to its peers.
The seating position gets a lot of comments in reviews. I am 5'11" and it suits me just fine.
The gas Jetta is particularly unimpressive for fuel economy and has been for some time. Too heavy for the small engines being used in it, I think.
Isn't EBD standard with Matrix if you opt for the ABS? And isn't it weird that the $14K Scion xB has standard traction control, but the $16K Matrix does not? Never thought about that until just now...
Does anyone know how to disconnect that ANNOYING reverse beep? Also, I would love to disconnect the passenger side seat belt indicator. Sometimes I'll set stuff in the passenger seat that is just heavy enough to activate it. It's also very annoying.
Likewise the passenger seatbelt indicator doesn't bother me and though I put stuff on the seat all the time, it has only activated one time when I did so. It does seem to go off after a while.
I think there may have been another TSB or two after the twilight sensor. Dash rattles, and perhaps the center console bin door I think. Maybe.
Same thing with the squeaks and rattles. My last car (91 Civic Si) was so full of them by the time I got rid of it that the Matrix is virtually silent by comparison.
After 2 months of owning this car, I can say without hesitation that is the best car I've ever owned. It's surprisingly speedy, the lift in first and second gear and revving to 8000+ RPM is so adicting it's hard hold back. Inside, the thing is cavernous and holds just about anything you'd want to haul. The seats are very comfortable and I can tolerate 500 mile car rides without that gotta-get-outta-this-car-right-now feeling that I used to get after a couple of hours in the Honda. If they ever decided to turbocharge this thing and boost it to 225 hp or so and give it some low end torque, I would likely call it the perfect car. But until that day comes, I'm extremely satisfied with the way it is now.
The XRS is a hoot. This same engine (with some minor tweaks) is now in use in the new Lotus Elise, which has programmed it to go on the high-lift cam at a somewhat lower rpm, and to transition in a more smooth manner. I wish Toyota would do the same for its own cars!
While I would absolutely LOVE to see the old Supra engine in a car like the Matrix, it is ancient-tech at this point. Emissions are too high for the new millennium, and fuel economy is terrible.
At their heart, I feel models like the Matrix and Corolla XRS are supposed to be go-fast economy wagons/sedans, and there is not much "economy" about an 18/25 EPA rating! :-P
Now, the Scion tC gives me hope. If there is a next-gen Matrix (and I truly hope there will be), I am betting they will drop the Camry 2.4 in it, which should be good for 170 hp or so by then. They could then give the XRS the S/C version of this engine, with nice low-end torque and 210 hp or so on tap. I imagine fuel economy of all versions would drop a little, but it would be worth it for the power you get.
Now...if only I could get my XRS motor into my 1990 Miata!!!
yes, you have mentioned a salient point: the Matrix is a FWDer and with too much power the wheel might become a handful. Still if Honda can stuff 250 hp engines in FWD sedans, Toyota could probably make that work out if it tried.
OR they could do what I would like to see and make the Matrix the first Toyota model to go back to RWD - yes! :-)
I'd bet that Toyota would go AWD before they go RWD.....but one can only hope.
Are you perceiving a difference in shifting with AC on?
I just put Redline MTL in my 90 MIata and it shifts much more smoothly, especially with the AC on...I may try it in my Matrix.
I didn't think I ran the tank that dry - I gased up about 5 miles after the yellow (low fuel) light came on - but being able to put 12.833 gal into a tank listed as 13.2 gal seemed unusual. Makes me wonder if the tank is actually larger.
It's hard to understand him at first since English is not his first language. He is asking me if my car is the expensive version. I say yeah. He asks how much it was. I say $20k, neglect to mention that that was out the door. I say they can go higher with a moonroof and navigation though. He seems satisfied and says that's how much the Mustang was supposed to cost. He got it for $16.5k and the reason he got it was he could get that deal. But he says he really would have preferred having the Matrix.
He asks what my payment is and I tell him. His payment and mine are about the same. I await the follow up question about interest rates, but it doesn't come.
He tells me again that he really wanted the Matrix but that he bought the Mustang because of the deal and that's the end of the conversation.
I didn't think the markets for Mustangs and Matrices overlapped at all.
I can't imagine anyone cross-shopping the Mustang and the Matrix either. I bet the Matrix handles better in the canyons, though I am sure the Mustang is quicker off the line.
silverado: yes, ABS would add a certain measure of safety for an inexperienced driver. I don't know about the side curtains, though, with regard to the child seat. Can you put it in the middle? If so, I wouldn't worry. otherwise, I would contact Toyota USA or the manufacturer of the seat for further information before going ahead.
Silverado, I don't want to dissuade you from the Matrix. $19K including tax is well below average these days for a new vehicle, especially one that is as well equipped as a Matrix. But if you have a 2nd kid while the first one still is in a car seat or booster seat, would you be comfortable with the older child in the rear close to the side airbag?
So, if any of you fellow Matrix owners (esp. fellow XRS owners) can help me, I'd appreciate it.
typically -- and I'm talking VW/Audi here -- there is a drain plug in the bottom of the tranny and a fill plug ~halfway up the transmission housing. the level is supposed to be "just below" the fill plug, and the precision instrument used is a finger of your choice.
-Mathias
