Subaru Impreza WRX Wagon
I wouldn't call them negatively biased either. CR has raved about the WRX. It has been one of their favorites since they first tested it. It was their cover car on last years annual auto issue and selected as "most fun to drive".
It is almost the same reason the Civic was downgraded last year to average, and is back to above average this year.
BTW: The WRX was selected again this year as "Most fun to drive" by CR.
I have to temper my enthusiasm when driving my car,but after a wicked east coast winter and a cool summer of auto cross, I must say that the car handles like a dream still. The Stock Tires are a little worn but thats all the better, now I have to step up and buy some nice_______"s from Tirerack.com or does anyone have some nice suggestions????? I have the stock 16" rims.
Also keep in mind it's normal for version 1.0 of any car to dip a little - it happened to the Civic, the Altima, even the Camry. I bet next year it climbs back up above average.
For one, they put that force-limiting valve on the clutch, and one thread on NASIOC about tranny failures were limited to just 2002 models, no 2003s at least in that thread.
-juice
-mike
-scott
Gottawrx, i've put my MPH plans on hold for a while. I'm probably going to wait till my wife finishes her Physician Assistant program. I'm doing well with AFLAC right now, so we'll see what the future holds.
Another thing - does the aligment need to be adjusted for the tire change?
I switched to the 20mm sedan swaybar on my wagon and I would definitely recommend it. The car understeers less and corners more flatly. I think it's a great low-cost upgrade. The only caution is that in adverse weather the tail end has a greater tendency to get loose. Even with winter tires, I have to be pretty cautious taking turns when there's snow on the road.
BTW I'm ordering some 225/17s today to put on a set of Rota rims. I'm anticipating another big improvement in handling.
Where did you get the bar, how much, and did you install it yourself?
-juice
-Dennis
Put them on Sat. morning - I'm totally pleased with the appearance (ASA FR1s, S-03s) and performance. And tire rack sent me 17x7.5 rims instead of 7.0 for the same price - I'm pleased about that since the tires are 225s. All in all, VERY pleased, very smooth deal - I also discovered that the S-03s from tirerack cost about the same as RE-730s at Costco. Couldn't be happier (well, OK, if it was FREE, i'd be happier...)
Now awaiting the rear sway bar from sooby-parts, any day now.
The tires themselves list a max pressure as 44 psi on the sidewall. The Subaru sticker inside the driver's door says to inflate front tires to 32psi and rear to 29psi. This seems like quite a difference to me. I also don't know why the front and rear require different pressures.
My theory is that higher pressure will give better performance in terms or cornering and handling, at a sacrifice of ride comfort. I was thinking of running somewhere between 35 and 40 psi, still well below the 44 max.
Any advice for best air pressure?
Higher pressure will yield more control, better milage, and a stiffer ride.
-mike
Can you safely inflate to the max pressure as indicated on the tire, no matter what the vehicle maker recommends?
Why the front/rear 3psi difference?
How would Ford and Firestone answer these questions?
-mike
-Colin
-mike
-B
-mike
Ford's recommended tire pressure on the previous gen. Exlpoder was around 26 or 28 psi's, IIRC. Factor in that most people rarely check their tires and you have a recipe for disaster. Americans love a cushy ride.
Anyway, back to Subes.
Even going up as little as 3-4 psi's cold (over SoA recommedation) will improve handling. Just do a little sampling. Don't forget that different pressures for 17's are also listed on the door.
Check out the Tire forum on nasioc.com. Tire Rack has a "Tire Tech" post there with some excellent info.
-Dennis
I'm running 32 lbs. front and rear, handling is superb, ride is "firm" - but hey, it ain't a Town Car, thankfully. I'm finding them acceptable from a comfort/noise stanpoint.
-mike
I bought the 20mm swaybar used through the nasioc.com private for sale section for $50 shipped. I had read that the install is easy but has one bolt that's a PITA to get at, and that some have disconnected the fuel filler pipe to access it. I just had my Subaru dealer handle it -- 1/2 hour, $37.50.
The difference in the front and rear pressures (32/29) is mainly due to weight distribution. The 29psi is probably for a light/empty load. There should be a second number (around 36psi) for a full load.
Tire pressure differences can also impact understeer and oversteer. Fronts greater than rear tend towards oversteer and the reverse for understeer.
Ken
-B
The concern for AWD is that the tire diameters stay identical front and rear, otherwise the center differential is under stress. Subbie owners that let their tire pressures go off specs soon find that their MPG drops off also. Also note this is the reason for the full size spare tire too.
John
The reason is due to the weight carrying abilities as a specific pressure for that axle, higher pressure yields a higher carrying capacity.
-mike
add that to the FAQ thread.
-Dave
-mike
Center differential binding is an important issue and tire diameter is one of the factors.
John
-Frank P.
Why not set them at max pressure? Because at full PSI the tires would be rock hard. Also the tire psi is for max weight carrying of the tire. For instance that tire might be used on a larger vehicle which would require a higher PSI to hold a higher weight.
SOA recommends F->R tire rotations, same as 95% of other vehicles out there. Not sure where you are going with that. Replacing all 4 tires at the same time is due to the circumference difference that would be created by a worn v. new tire.
You can believe whatever you want however...
-mike
On the rotation angle, I wasn't going anywhere, just bringing in important SOA recommendations for keeping tire diameters uniform.
John
I don't know exactly what too high or low is. I have always gone a few psi above recommended and have experienced pretty even tread wear.
Also, higher pressure does make handling a bit more agile, reduces rolling resistance and improves fuel economy, but it also reduces traction.
John
-mike
A bit on a tangent, but I believe the reason why the owner's manual calls for a front-to-back rotation of tires (no crossing) is that this pattern works with all types of tires (ie. direction and non-directional).
Ken
Using some algebra, 1/4" circumference divided by 2 divided by pi is equal to 0.0397" change in radius. That is nothing, a 300 lb weight can easily squat the tire down that far. But I don't think I can measure 0.04" change in tire deflection without a high level measuring device.
Mike, you are sure the 1/4" is for circumference? That is very little, I would guess even minor changes in psi would have that affect.
John
