Is it similar to the 4runner?
This newer system does not exist on most of their older models (I think it was on the older 4Runner models)."
All of the 4th generation 4Runners (from 2003 on) have a lockable Torsen center differential. The same is true of the GX470. I believe that the previous generation LandCruiser and LX470 also used the same lockable Torsen center diff.
Exactly what references did I make that were incorrect? I stated that the 4Runner had a Torsen Center differential prior to 2008. According to Toyota's press releases on the '08 Sequoia, the Torsen Center Differential was added to the Sequoia this year. I would welcome any information suggesting the Sequoia had a Torsen Ctr Differential since 2005 as I have been unable to find such information.
I made no reference to ALSD or TRAC. I simply stated that the Toyota system does not transfer torque across the rear axle upon slippage above 35mph. This is an accurate statement however I would again welcome any resource you have suggesting otherwise.
The addition of the mechanical center differential to the Sequoia, LX570, Land Cruiser and LS600h are an acknowledgement by Toyota that it is a better system than they used in the previous year's 4wd system. Why do you suppose they added a mechanical center differential when most of Toyota's 4wd systems have had open diffs in the front, center and rear prior to 2008? It clearly is a more expensive design however its also a better design for on-road 4wd operation.
I'm quite familiar with the system in the Sequoia and I believe the '08 design is a far better system than the previous design. The fact that the new system maintains a variable but minimum amount of torque to the front wheels when in 4wd hi (center diff unlocked) is only possible because they added the Torsen Center Differential which did not exist on any other vehicle in the Toyota lineup prior to 2008 (other than the 4Runner). This "AWD" mode with a minimum amount of torque always going to the front wheels could not have been achieved without a mechanical center differential.
My point regarding the new Toyota 4wd design was specific to on-road traction and that most of the top-line brands have had a mechanical center differential for years. Toyota's addition to the list is a good thing. For the same reason they added a mechanical center diff to their system, I wish they had also added a mechanical limited slip diff to the rear. As I shared earlier, most if not all of the major brands include a limited slip differential on the rear of their higher end 4wd vehicles. Most engineers consider a liquid viscous diff., mech. LSD and electronically locking rear differentials as all being superior to an open differential with TRAC or any other type of system that utilizes the braking system solely to distribute torque.
I would much rather have a system that starts with a mechnical LSD and fine-tunes traction with an electronic reverse braking system such as ATRAC. Toyota added a mechanical center differential because with the 5.7 they have added 105hp to the Sequoia/LX570/LC drivetrain that did not exist in prior years. Trying to manage over 400ft/lbs of torque with an electronic system is not practical which explains Toyota's conversion to a system used by most other brands. I just wish they had taken it to the next step and added a second Torsen to the rear differential.
BTW, I hope your appraisal of the Sequoia's ability to "go farther without getting stuck" is accurate as I just ordered a Black/Red Rock Platinum Sequoia with delivery expected in early Feb.
Here’s an interesting video on the rear differential and A-LSD in operation on the 2wd Tundra as compared to a 2wd Chevy with a locking rear differential. Its an exaggeration to some degree however it does highlight the limitations of a rear open diff with A-LSD vs a mechanical locking rear diff.
http://www.youtube.com/watch?v=Z8PpZF77tgk
Here’s the press release on the new Sequoia drivetrain.
http://www.pressroom.toyota.com/Releases/View?id=TYT2007110908452
Prior to 2008 the Sequoia, LC and LX470 had locking center differentials, however when the ctr diff was unlocked it was essentially an open diff. This design is significantly different from the 2008 design which is a locking design that still retains a limited slip capability when it is unlocked.
2008 LS400h http://pressroom.toyota.com/presstxt/2008lexuskit/2008LS600hL_sf.pdf
2008 Sequoia http://www.pressroom.toyota.com/Releases/View?id=TYT2007110908452
2008 LX570 http://jalopnik.com/336324/details-out-for-2008-lexus-lx-570-ndash-the-classy-wa- y-to-overcompensate
2008 LC http://www.caranddriver.com/previews/14080/first-drive-2008-toyota-land-cruiser-- high-tech-suspension-page3.html
Here’s a technical paper from Toyota on why they designed LC 4WD transfer case – VF4AM - for 2008 to incorporate a Torsen-C limited slip differential. This is the same transfer case used in the Sequoia, LX570 and LC. I believe the LS400h and the 4Runner use a different center Torsen unit from the 2008 LC, LX570 and Sequoia. As outlined in the article, the previous LC had an open center differential and relied solely on A-TRC for front/rear torque distribution. The article points out that traction is enhanced when A-TRC is used in combination with a Torsen differential. This means that torque transfer has been improved when transferring front to rear with the new design. Unfortunately it also means that the current design with an open rear diff using only A-TRC is not as good at transferring torque from left to right compared to a system that would have combined a Torsen rear diff with A-TRC.
http://www.cuneoclub4wd.it/fram1/rubriche/toyota/toy2/trasmissione.pdf
A Torsen rear diff would have added cost but would have resulted in a better 4wd system for on-road use. Namely 2sp transfer case + lockable Torsen Ctr Diff. + Torsen rear diff. + A-TRC. The Chevy system includes the 2sp transfer case + lockable torsen ctr diff + auto-locking rear diff + electronic traction control. IMO the Chevy design is still a somewhat better 4wd setup for flexibility and road use, however the new Toyota 4WD system is definitely better than the prior year’s models used in the LC, LX470 and Sequoia with open center differentials (as their own technical paper confirms).
Toyota claims having an open diff front and back is more reliable as LSDs fail more often. Perhaps, or perhaps it was just to save money.
I would like to have 3 Torsen units. Torsen is a family of systems and you can get them in various designs with different behaviors.
We had 6 inches of snow yesterday and I tested the new 2008 Sequoia up our driveway. Our 2006 Honda minivan cannot get up it. The Sequoia had a lot of trouble in 2WD mode but I could probably get it up with skill and momentum.
I could detect no difference in performance between 4WD and 4WD with the center-diff fully locked.
I also tried to wiz around corners on icy roads and also doing hard braking while turning, and the truck never spun out. I think that was the stability control working. I unfortunately did not try it with it turned off.
While I'm confident the failure rate of a LSD is higher than an open diff, I believe failure of any modern differential is nominal when used in normal road conditions (not off-roading, snowing plowing or extreme towing).
Does it make any sense to have both? I would think the virtaul (braking) LSD would be so quick acting that a mechanical LSD would NEVER come into play...
When a manufacturer says a vehicle has LSD but doesn't define the type how do you know which it is?
Spring-loaded friction clutch pak?
Viscous fluid?
Torsen?
Electronic via brakes?
Not talking LOCKING diff'l here, only LIMITED slip.
The traction system transfers power across the axle at any speed, it is TRAC in 2WD, and ATRAC in 4WD. ALSD only operates in 2WD and that turns off at 35mph, and then TRAC operates at any speed.
I agree the torsen in the center is an improvement.
The torsen splits power 40% front and 60% rear for normal driving in AWD mode. That is not minimum to the front.
Have you ever driven a Toyota with ATRAC in bad weather or off road? I had an 05 Tundra with a limited slip rear diff, and in 4WD with the center diff locked in the snow the truck was good, I then traded it for an 06 with ATRAC, and it is much better than the 05 in snowy and even wet weather. ATRAC works so fast there is no need for a limited slip diff on the rear.
In my reading on the subject, when detailed specs are provided, a manufacturer referring to a LSD diff is "generally" referring to a mechanical diff. This could be a viscous liquid, clutch plate type or Torsen. Most articles don't go into details since the vast majority of the public doesn't know the difference or for that matter care.
No manufacturer I've read refers to their open diff with electronic brake control of slippage as a LSD. Generally they will have some hi-tech branded name by the manufacturer that refers to their reverse ABS software designed to control slippage. The one exception has been Toyota which refers to their system as A-LSD. In reality the name is a misnomer since the differential plays no role in determining how much/little slippage there is in the Toyota design since its an open design. Its my belief, that Toyota has used the term to give their consumers the sense that their electronic approach is equivalent to a true LSD. In my opinion, it is not equivalent and it would appear that Toyota's engineers agree with me based on the Toyota technical paper I provided earlier.
Conclusion...while I'm sure there may be exceptions, for the most part when a manufacturer refers to their center or rear diff as an LSD, it most likely is a mechanical type. The exception would be Toyota that refers to their electronic approach combined with an open diff as A-LSD.
You would not want to drive with a failed LSD. It would make quite a racket after it fails.
As evidenced by the many manufacturers that include a LSD in the rear of their drivetrain, I think its safe to say that it offers a significant benefit to most drivers that experience slippery on-road conditions on a regular basis. Based on Toyota changing the design of the 4wd drivetrain to include a center LSD after years of an open center design, I think Toyota would agree that an LSD is with A-TRC is a superior design to an open diff with A-TRC.
I agree with "Limited". I agree with "Slip". I disagree that their system has anything to do with the "Differential" in LSD. If Toyota had called it "Limited Slip Drive" or "Electonic Limited Slip" or "E-LS", I'd have no issue. It just technically is not a limited slip differential and any reference to the "differential" in their terminology is incorrect at least from a design perspective. I view it as an attempt to mask the fact that the rear differential is a basic open design.
Actually the VF4AM transfer case with a Torsen-C center differential is new for 2008 in the Sequoia, LC, LX570. The addition of the Torsen-C center differential is what makes it unique from past applications in the Sequoia. The VF4AM has been used in the v6 4Runner since 2003.
http://www.toyota120.com/GenDocs/2003_4Runner.pdf
The v8 4Runner used the VF4BM transfer case. More details in the article below.
http://www.vibratesoftware.com/html_help/html/Toyota/Toyota_Transfer_Units.htm
Here's additional information on the older style VF4BM transfer case that was used in the previous gen Sequoia and 4Runner.
http://youronlinemechanic.com/2007/09/28/vf4bm-transfer-with-torque-sensing-type- /
You keep talking about ALSD as toyotas system. It is just a function of TRAC. You would only use ALSD if you needed rear wheel spin in 2WD when stuck, because TRAC would cut some engine power in addition to braking the spinning wheel. Once you are moving you wouldn't want ALSD on you would want TRAC on to keep stability.
"You keep giving the wrong info, and I will keep correcting you. The VF4AM is used on the V6 4Runner and 05 - 07 Sequoia. The VF4BM is used on V8 4Runner and FJ Cruiser with a manual transmission. The 08 Sequoia uses the JF3A transfer case, and the Land Cruiser/LX570 uses the JF2A transfer case. All four have a torsen center diff., the difference being that the VF4AM and the JF3A have a 2WD option."
I'd like to recommend that you take the time to read the source information I shared before suggesting I'm wrong in my statements. The Toyota information I provided above and that I will share again clearly states that the Sequoia through 2007 used the same transfer case as the V8 4Runner...namely the VF4BM transfer design. Here's the specific link again. If you believe you are correct and Toyota is wrong, let me suggest you contact them.
According to all the information available that I have read... the Sequoia, LC and LX570 drivetrains were updated to include the Torsen-C center differential in 2008. Here’s Toyota’s press release for the new LC describing the “newly developed transfer case with a Torsen center differential”. http://www.zercustoms.com/news/2008-Toyota-Land-Cruiser-in-Japan.html
All information prior to 2008 on the Sequoia describes an open center differential that can be locked by the driver. There is no reference anywhere I’ve searched that would show that the Sequoia had a lockable mechanical center LSD prior to 2008.
Its interesting how I provide resources for my comments and yet your assertions are based on "trust me because I know more". I welcome the opportunity to learn and if the information and resources I shared are incorrect, it might be best to share a source, any source, that can support your claims.
Please share any link that shows the Sequoia had a center Torsen LSD (4wd models obviously) prior to the new 2008 models as I've been unable to find any information that would support your claim. I'm confident that the center differential of the Sequoia is not a National Security issue and therefore if prior year models included a mechanical center LSD, it should be readily available on the internet. Perhaps I'm looking in the wrong places. I would welcome a link to any source suggesting the Sequoia had a Torsen center LSD prior to 2008.
I disagree because the Toyota system can apply brakes to just the slipping wheel. Since there is a constant amount of torque going to both wheel, braking one wheel has the effect of sending power (power being torque * rpm) through the open diff to the non-slipping wheel. So they are using electronics to make the open diff behave as an LSD. So calling it an electronic LSD "system" is fair.
That being said, it has disadvantages to a mechanical LSD in that slip has to occur before it goes to action. A mechanical Torsen system can redirect power before slipping occurs. That is why a combined system, like the 1997 and newer H1, is better.
You will clearly see the transfer was changed to the VF4AM which includes the torsen. This info is directly from toyota, your page is not. How can the Sequoia have the same transfer case as the V8 4Runner? The V8 is Full Time 4WD, and the Sequoia has a 2WD option? The VF4BM does also have the torsen in the center diff though. If you spend 10.00 for a day and go on techinfo.toyota.com which is also a toyota site, you can see all the features and how they work. I am not trying to go back and forth with you, but I will make sure you post the correct info. It is not fair to give people the wrong info about a vehicle.
 The ’05 Sequoia uses the multi-mode VF4AM transfer.
 Along with the adoption of the VF4AM transfer, the transfer lever has been discontinued. Thus, in the
4WD mode, the driver operates the 4Lo switch to switch between Lo and Hi.
 The VF4AM transfer is already in use on the ’04 4Runner with the 1GR-FE engine. For details on the basic
construction and operation of the VF4AM transfer, see the ’03 4Runner NCF (Pub. NoSpecifications
Model ’05 Sequoia ’04 Sequoia
Engine Type 2UZ-FE
Transfer Type VF4AM VF3AM
Drive Type Multi-mode
(Part-time & Full time)
H2 1.000
Gear Ratio H/H4 1.000
L/L4 2.566
Reduction Gear Type Single Pinion Planetary
Center Differential Gear Type TORSEN LSD*2 Double Pinion Planetary
Oil Capacity
Liters (US qts, Imp.qts) 1.4 (1.5, 1.3) 1.2 (1.3, 1.1)
Oil Viscosity SAE 75W-90
Oil Grade API GL-5 API GL-4 or GL-5
Weight (Reference)*1 Kg (lb) 41.2 (90.8) 42.8 (94.4)
*1: Weight shows the figure with the oil fully filled.
*2: TORSEN is TOYODA-KOKI-TORSEN’s registered trademark. NCF238U
The Toyota info you shared does clear the matter up regarding the type of transfer case used in the pre-08 Sequoias. Curious that so many other sources would either be incorrect or would not have referenced that transfer case in the earlier model years.
Based on your access to the Toyota site can you clarify which model years the Sequoia, LC, LX470 and the 4Runner each transitioned to a Torsen center LSD from an open center differential?
No, it wouldn't/doesn't. The spring pre-loaded clutch type, just as would a regular clutch in a stick shift, simply ceases to work once the friction surface has worn off. The VC type might "lock" in failure mode but since it is designed for "failsafe" operation that is rather doubtful.
So a driver probably wouldn't notice the failure until the moment of need arises.
Someone, please, correct this if you have information otherwise but I think I have read documentation indicating that A-LSD is a sub-mode of TRAC. Whereas TRAC's default, always on, mode will instantly apply braking to a slipping wheel and simultaneously dethrottle the engine, if you put the system in A-LSD mode it will allow a certain level of wheelspin/slip just as one might sometimes want to get unstuck.
I think, also, A-LSD capability is only to be made available on RWD or R/AWD vehicles.
For many years now owners have complained about this aspect of TRAC, no ability to use wheelspin, say for rocking the vehicle back and forth to get unstuck, out of a mudhole, and now Toyota is offering A-LSD as a possible solution. Previously the only solution was to somehow disable VSC/TRAC altogether.
"..want TRAC on to keep stability."
Methinks you meant to say VSC.
Assuming a VC, Viscous Clutch, implemented LSD is considered "mechanical" your statement is wrong, a VC must experience a period of slippage before it will "tighten" the coupling coefficient.
"A mechanical Torsen system.."
Doesn't this add to the confusion? I have never considered the Torsen system to be in the LSD "realm", more of a torque control/distribution system rather than an LSD.
You description of the viscous liquid diff is accurate and one of the reasons its not the best mechanical design for transfer of torque under severe conditions. It can be ineffective when operating in sand for example in transferring torque from the rear to the front of an AWD vehicle. It excels however at providing a very smooth torque transition when operating on slippery road surfaces.
I thought the Sequoia ALWAYS had a lockable mechainical center diff'l for 4WD/4X4 mode...??
And yes, while that was otherwise an "open" diff''l (or transfer case equivalent) I thought they used TRAC braking in AWD mode to effectively have a center LSD..?
And isn't that basically the same system used quite effectively on the RX330/350, the HL and the Sienna AWD systems today, the VC version of those systems having been dropped prior to the '04 model year.
I thought I knew the answer until 2Toyotas shared information from the "Pay for" toyota website. While the Sequoia has always had a Lockable ctr differential, I thought the addition of the Torsen LSD (in place of an open diff) was new for 2008. He shared information describing a Torsen Ctr Diff in the 2005 model. Therefore I do not know when Toyota transitioned from an open diff to the Torsen LSD ctr diff. for the Sequoia.
I was hopeful that 2Toyotas could look at his website to determine what model year the upgrade actually took place. (As well as when the upgrade to the Torsen occurred for the LC, LX470 and 4Runner.)
Most external information sources suggest the Torsen was added to the drivetrain for these vehicles in 2008 with the 4Runner getting it earlier. These sources must be wrong based on his review of the Toyota site.
The Sequoia used the VF3AM transfer from it's introduction in 2001 until 2004. It has an open center diff. In 2005 the Sequoia started using the VF4AM transfer already in use on the V6 4Runner, which has the torsen. For 2008 the Sequoia is now using the JF3A transfer which also has the torsen.
The Land Cruiser/LX470 used the HF2A transfer which has an open center diff. from 1998 until 2007. For 2008 the Land Cruiser/LX570 will use the JF2A which has a torsen center diff. One interesting thing is the Land Cruiser/LX used the HF2AV center diff until 1997 which had a Viscous center diff. They dropped it in 1998 for an open center diff.
ATRAC began in the Land Cruiser/LX in 2000, and the 4Runner and Sequoia in 2001.
The torsen center diff is definitely an improvement over an open center diff. I had an 03 Sequoia and then traded for an 05, and the big difference is on inclines, with the open diff ATRAC would brake up to 3 wheels at a time and 1 wheel would get power., it was not enough to get the Sequoia up inclines, you would need to lock the center diff. With the torsen both axles always get power, the front up to 53% and the rear up to 71%. ATRAC works side to side on both axles, while the torsen puts it front to back, so it climbs inclines with ease, without the need to lock the center diff.
In my experience with this system, on snow and ice unlocked with the torsen working, ATRAC brakes spinning wheels and also cuts power when needed, and keeps the truck in full control. In sand or mud it is better to lock the center diff, this way power is split 50/50, and ATRAC only brakes the spinning wheel, but does not cut power, so it keeps you moving.
Just to summarize...the Open to Torsen conversion for the center diff of these models took place in the following years:
4Runner - 2003
Sequoia - 2005
LC/LX470 - 2008
Is there any other Toyota made 4wd vehicle with a torsen ctr diff?
You also shared that the Sequoia and LC/LX changed transfer cases in 2008. The Sequoia from VF4AM to a JF3A. The LC/LX from an HF2A to JF2A.
Do you know what the primary difference is between the previous transfer case and the Sequoia's new JF3A? Also do you know what the difference is between the JF2A and the JF3A? Is the primary difference in the transfer cases between the LC/LX and the Sequoia the new "Hill Start Control" and the new "Crawl Control" which are in the LX/LC but not in the Sequoia?
The 2008 Highlander is significantly larger and heavier than the previous version, so don't expect to get significantly better mileage than your V6 4Runner.
Cannot find any documentation that the torsen was used after 2003 but lots of stuff indicating TRAC was used in its place. Same for the Lexus GX & LX series.
Strange, very.
Lot of component pictures/diagrams/breakouts of the VF4AM transfer across the years and models but only the 2003 4runner shows a torsen.
Look down at drivetrain: "Multi-Mode 4-wheel drive with Torsen® [1] limited-slip center differential with locking feature" for the V6 and "Full-time 4-wheel drive with Torsen® [1] limited-slip center differential with locking feature"
The 4Runner drivetrain hasn't changed since 2003.
Clearly, I may be wrong but the information at techinfo.toyota.com is pretty detailed, detailed well enough that a good mechanic could use it to overhaul the transfer system.
The word "torsen" is not used beyond 2003 in any of the documentation and I have no idea why that would be unless it isn't used or there is some legality involved.
Additionally if you read the document ion for traction control it appears that a torsen diff'l would be of no use since the TRAC system would quickly brake any wheel (and dethrottle the engine simultaneously) that exhibits spin or slip.
As somewhat of a parallel, I bought a 2001 AWD RX300 because it had HID VSC/TRAC and a viscous clutch across the center diff'l to provide torque to the rear driveline if front slippage occurred.
I quickly discovered that the VC was probably useless since the TRAC system activated at the first sign, seemingly the very instant, wheelspin developed.
Apparently Lexus discovered the same thing as the VC was discontinued for the RX330 series as was announced in NCF, New Car Features for the new 2004 RX330.
But guess what....??
Lexus continued to advertise, hardcopy sales brochures, on the internet, and in various PR pieces, that the RX330 had a VC, Viscous Clutch when the shop/repair manual indicated otherwise.
Lexus finally admitted, in writing (email), that the RX330 did not use a VC and apologized for the mis-information.
And now here I am arguing with Lexus as to whether or not the new(er) RX350 uses the VC. The advertising says yes but the shop/repair manuals say not and the TRAC use indicates it might be useless even if it is installed.
Sorta of like the issue of a torsen with TRAC in the 4runner.
If you have a torsen diff'l in the 4runner wouldn't you need to disable TC in order to put it to use...??
The front wheels are already slipping (abet at a rate limited by TC) an obvious indication of a slippery roadbed surface, and the Torsen will MULTIPLY the torque at the rear wheels (torque sustained via TC braking), or vice versa.
I would think one would want LESS torque at the opposite wheels, not MORE.
But how...??
http://youtube.com/watch?v=t09ExAUgtyE&feature=related
In reality these are FWD vehicles that transfer power when there is slippage using the brakes from the front wheels that are slipping to the rear one's that aren't. Generally these systems cannot transfer torque over a certain speed such as 35mph. Once you're over this speed, the brakes can no longer be applied to transfer torque to wheels that are not slipping and you essentially have a FWD vehicle.
This type of system will generally use up brake pads more than a vehicle with a center LSD or Viscous liquid ctr diff. While Toyota refers to the system as "AWD", it would not meet the definition of AWD by most other manufacturer's that use this term such as Subaru, Audi, MB, Volvo or GM, however it is nice marketing even if its not a very effective 4wd drivetrain.
Unless Toyota has added a Viscous Liquid center differential or a limted slip differential to these 3 vehicles, they would generally not meet the definition of AWD used by all other manufacturers of AWD vehicles.
Since there's no operator controls it wouldn't meet the definition of a typical 4wd system either. Best way to think about this system is that its a FWD vehicle with traction control that transfers power to the rear wheels when the front wheels slip, but only at lower speeds and only a small amount of the available torque as shown in the video. Better than FWD alone but not nearly as good as a real AWD system or a 4wd system.
Or is it just a matter of poor or inadequate TRAC design?
The video shows the significant limitations of using braking to transfer torque across an open differential. As the video shows, a system such as Toyota's that is solely based on braking to transfer torque is a poor substitute for a mechanical LSD or viscous liquid CTR diff.. That's why the RX330/350 can't climb a slippery incline even when the front wheels slip and the rear has traction.
If the vehicle was moving at speed, the system wouldn't even attempt to transfer torque in order to avoid causing an unstable driving situation, not to mention how much additional wear and tear would be place on the front brakes if the system attempted to use front wheel braking to transfer torque at higher speeds such as a highway ramp or even a high speed curve in a major highway.
This type of system is simply Toyota's way of keeping drivetrain costs down and giving the marketing department a "claim" that most consumer's will never understand or see the difference with real AWD and 4wd drivetrains. Their approach allows for higher prices with lower costs and a better margin on their "AWD" vehicles. Smart buyers will know the difference and see this drivetrain as nothing more than a glorified traction system for limited road situations.
Toyota loyalists will undoubtedly have a different perspective however the videos tell the real world story. Here's another example showing the difference between the Tundra's rear open diff with "electronic torque transfer via the brakes" vs the mechanical auto-locking rear differential in a Chevy pickup. A rear LSD would perform somewhere between the 2wd Tundra and the 2wd Chevy in this video. http://www.youtube.com/watch?v=Z8PpZF77tgk The video was filmed at the Eaton proving grounds which makes the Eaton auto-locking differential used in the 2wd Silverado pickup.
Thanks, DQ
As far as the Highlander, I would think it would do a better job than that, it looked like the TRAC system was disabled, but i can not prove that. I do agree, I would like to see the Viscous Coupling back in the center diff. My first Sequoia was an 03 which had a lockable open center diff. On steep inclines ATRAC would have to kick in to much and it would stop momentum. I would have to lock it, and it would be fine. I then bought an 05 which had the Torsen center diff, which corrected that problem.
In the 4Runner, the center diff is locked and unlocked by a push-button on the dash, low and to the left of the steering wheel. In the 2008 Sequoia, I believe it is to the right of the steering wheel. Look at this picture: http://www.autoblog.com/photos/2008-toyota-sequioa-limited-4x4/686920/
See the button in the middle that has a little drawing that shows 4 wheels and an x in the middle? That locks and unlocks the center diff. You might have to put the car in neutral to unlock the center diff.
I had thought mechanical limited slip was generally done with friction disks as was the case in my '60s GTO and Corvette. In that case I'm not sure but what using the brakes isn't a better solution. It is sure easier to replace brake pads and in those cases the limited slip did wear out.
