By the way, this is only the second problem I have ever had with this vehicle, the first was an idle sensor.
back up lights are really dim due to poor lense design
and remote key fob springs are weak- put it in your pocket with other keys and it goes off
Just hold the "pedal to the metal", brake pedal that is. The anti-lock system will do the rest.
You may have spent $350 bucks needlessly.
Also, I recently had engine trouble with my highlander and the manager at the dealership was a real jerk. The car wouldn't run and he said he needed to see the defective part in person. I took the part off and brought it to him and he wouldn't even look at it, he said if I need it replaced call the headquarters. I called them and they told me I should file a complaint with the Better Business Bureau. It seems like such an unorganized system. When I was buying they did everything they could to make me happy, once I owned the car the couldn't care less. My wife has a Toyota and has had similar problems. She got home and found out they charged her for a warranty that was almost $2,000 that she said she didn't want. When we went back up there they acted like they couldn't reverse it. After explaining that they'd better reverse or we'll return the car they did. Toyota seems very crooked to me and they don't stand behind their product unless they have to to keep their image up. I'll never buy another Toyota again.
Is it the brake foot pedal, under the rubber convering?
Is is the brake lever arm that attaches to the brake foot pedal?
Or, is the bend higher up under the dash?
I am getting more and more angry about this 2007 piece of trash Highlander that I just bought.
Gary
What state do you live in? I am in NC. I was supposed to meet with factory rep on Friday but I am going to be at a funeral out of town. Just wondering if we would have the same factory rep?
Getting stuck there and/or bending something is entirely a different story. I would suspect a poor return spring being at fault for being stuck or maybe whatever bends from your foot pressure holds it stuck.
I could see myself, if the brake pedal did go full stroke and the ABS activity being continuous due to a slippery surface and the car begins and continues to slid on that surface, being EXTREMELY hard on the brake pedal in my PANIC to get the car to come to a stop.
Just another reason, for me, to suggest disabling ABS unless/until VSC detects impending loss of directional control.
I meet with the Field rep this Thurs. I live in AZ. After they tell me they can't fix all the engineering defects, I am going to give mediation a try.
Problems: 1. Excessive engine vibration transmitted through steering column. 2. Excessive front braking, front brakes grab, seem out of proportion with back. Braking consistency varies. 3. Cold idle too high, 1950 RPM, transmission slams into gear. 4. Engine idle, loud resonance or “boominess”, growl in first gear. 5. Transmission erratic with inappropriate shifting. Transmission always shifting up to 5th gear at slow speeds, pushing car forward faster when not desired. Car will not downshift when appropriate. Car will drive for a mile without gas pedal input, stuck in 5th gear at 900 RPM. Car is easier to stop if put in Neutral. Excessive braking to keep car from surging forward. Toyota has had widespread problems here. It introduced a software upgrade in 2006, but it only improved slightly.
Don't buy this truck. Contact me with questions.
Did the rep at least acknowledge the vibration at 2000 RPM? Did he try to say it was normal? I suspect that since the new Highlander is coming out, any engineering fixes to the current model are not going to happen unless it has to do with a major safety issue. I just don't think they are going to allocate resources to investigate complaints like this, unfortunately and I don't think that the techs at the dealerships are equipped to diagnose things like this, especially if these things are "normal".
But your problem is excessive revs and braking harshly with vibration? Yeah, the brakes in my car suck too. I've been having a lot of grabbing. But my dealership sold me a damaged car and represented it as brand new one. So my problems are atypical, but Toyota's response is not.
I'd think that the dealership would do something about the rev problem though, because it's dangerous. There is a lemon law. I never used that law with my car because quite frankly I don't think it would apply. My car is simply damaged, but then a car dealership has to sell whatever they have, so you kind of wonder how many lemons are simply damaged cars?
A mechanic could go over your car, or you could write Toyota or the dealership asking what or if the car is damaged by certified mail. In some or most states they must answer or tell you if your car was previously damaged. I myself have to file two more complaints about my car (on my to do list.)
In general I think the dealership's cynically contemptuous attitude is simply business. They're cheap. They don't want to pay or fix things. But that's not consumer friendly and certainly not in your best interests, and certainly not your problem. You do have certain rights, strange as that might seem!
My dealership sends me get-55%-off-your-trade-in-and-buy-a-new-car crap in the mail.
Pretty cheeky huh? Sell a damaged vehicle with a coat of wax that has a gray rear bumper, gray side standoff panels, gray front left door, gray hood, all with a silver rear body--for 32,000 dollars.
And then send out a service tech to tell you with a patented piano tooth grin that your car was damaged-in-the-port, and then ask you to pay for a paint job on your previously damaged car, and then send out a Toyota Customer Service agent to scratch your paint and provoke you. But even better, come back in with the damaged car that you've been driving for three years, and we'll buy it back for HALF PRICE! What a great idea!
I tell ya, these kind of crooks stay up late at night thinking of this kind of crap. Ain't it the greatest? What a great deal!
Sell a damaged car to someone, buy it back for 50% of the price, sell that same person some more crap, and then sell the car that he or she traded in---to someone else.
I love it!!!!
My favorite though is the send you crap in the mail and then disappear when you go into the dealership routine. I like that one. You can't say they aren't trying even when
it's all just a contemptuous charade. I like too how my dealership places this-car-was-serviced check on my car's report history , as if they're really doing something, and not just play acting because they sold me something damaged.
But some things are dangerous. High engine revs and bad breaking are no joke. You should file some complaints at the very least. Check your tire pressure too; at my last service check at my dealership they refilled the tires to 35 pounds, when the car recommends 30. dangerous! And then too, I told the service guy not to work on the tires. But then again, would you trust a dealership that sold you a multicolored car (I haven't even figured out how MANY colors there are!)
you have to check things out.
Paul
Paul
Well I wish you luck there. There have been loads of complaints about a vibration issue with Pilots, at around 70mph. There are some on the edmunds boards and a huge long string over at hondapilot.org. Does not seem like it affects everyone though, so hopefully your new ride will be vibration free.
Does anyone know if Toyota/Lexus makes their Engineers and production people drive the models that the work on for their every day driving? I think this would be well worth the expense. If these people had to "live" with the car every day, I think that a lot of the things that we complain about would become evident to them and result in a better product in the long run.
It hasn't been but just a few years ago now that Toyota publically announced that they would begin raising prices across the board so as to allow a higher market share to Ford and GM.
Suddenly we now find that Toyota's QA is in the pits with Ford and GM still strugging and falling farther behind.
Yeah, I know the tire warranty is seperate but IMO it's still a reflection of Toyota quality. And I expected more from the assistance center.
Question: Is this a safety issue, or just an annoyance? You would think Toyota would have recalled the vehicles if safety were an issue, but maybe that's giving them too much credit.
So I would suggest that anyone with vehicles covered by this TSB should turn off the radio and listen very carefully next time you are in a parking lot pulling into or out of a space. Also pay attention to what you feel on the wheel. If you experience this clicking/popping it's not going to get any better. Get your service department to make note of it, hopefully before warranty runs out.
Is the pedal adjustable and is the brake force distrubution adjustable?
Gary
I told him this is hard to believe and if I check my owners manual in my Highlander when I pick it up if he will pay for the flush. He said that it is required and I will be responsible for damage if I don't do it, but he won't pay for it if the owners manual doesn't have it.
Looking for feedback please! :confuse:
http://smg.toyotapartsandservice.com/guides.php?xv=8&xy=2005&xint_id=12&v=8&y=20- 05&int_id=6
What have your experiences been?
Jonas
I also have a 2001 V6 Limited AWD and just had the brakes done last summer at about 55K miles. I didnt complain as all I have had done was replace tires at 35K as well as wiper. Oxygen sensor failed at 58K but nothing else in 6 years. Still have orifinal battery as well!
Mike
Good point about the battery, mine's original also. I was going to replace it preventatively before the winter, but didn't get around to it.
Jonas
When I get replacement tires they always last a minimum of 65K.
It is too bad that we can't have an "option" as to the tires we get on new Toyotas.
My old Camry got only 20K on its tires and again the replacement tires went over 65K.
