help programing a gm keyless entry remote
mrjfleming
Member Posts: 6
my 2 year old got a hold of my wifes keys and they have entered the land of lost socks. We own a 2000 pontiac montana, our neighbors totaled out there 2000 chevy venture (all the passengers were un-injured) and still have their old remote which they have given us.
I need help on how to program this remote so it will work along with our remaining remote.
thanks for the help.
Transmitter Programming:
1.Start with the ignition OFF ,hold down the power unlock button on the door panel. Turn ignition key ON ,OFF, ON, OFF. Release power unlock button on the door panel. The locks will cycle once.
2.Hold down the keyless entry transmitter LOCK and UNLOCK buttons for 15 seconds. The
locks will again cycle once.
3.Repeat step #2 for each additional keyless entry transmitter.
4. Turn the ignition on to exit the keyless entry transmitter programming mode. Programming is now complete.
There is another programming method but it requires the use of a scan tool.
But all Alero's (including the GX) have Power Locks and Power Trunk... so I am wonding if I pick up a transmitter whether I can program it without any other modifications? Anyone have an idea?
Sil
Program only 1 vehicle remote control door lock receiver at a time. If more than 1 receiver is being programmed at the same time, it is possible that the same transmitter could be programmed to more than 1 remote control door lock receiver.
Perform the following steps in order to program the transmitter:
Remove the ignition key from the ignition lock cylinder.
Remove the BCM PRGRM fuse from the fuse panel. Refer to Fuse Block diagram.
Close all of the doors.
Close the liftgate.
Turn the ignition lock cylinder to ACC.
Turn the ignition lock cylinder to OFF, and then back to ACC within 1 second.
Open and close any vehicle door. A chime will be heard when the system enters the BCM programming/diagnostic mode.
Important
After 7 seconds, a chime may be heard confirming successful synchronization. It is necessary to wait approximately 14 seconds for a second chime that will confirm successful programming.
Press and hold the transmitter LOCK and UNLOCK buttons simultaneously for 14 seconds.
Repeat the previous step on each additional transmitter to be programmed.
Install the BCM PRGRM fuse back into the fuse panel. Refer to Fuse Block diagram.
Important:Be careful and be sure which fuse you pull.
Are you the person that posted in the Alero topic in Sedans? I was looking for a Silver Alero GX with 4cyl/5sp in California but had no luck. Actually, I found no 5sp at all! I wasn't that picky about the color either, would have taken any lighter color.
Yes, I was on the Alero forum. 4dr GX 5spd is hard to find. In the Boston to Philly area there are about six. Two at one dealer in Boston area (a Blue and Silver). One in NW CT (Silver), one in Albany, NY (Silver), one in North Philly (Silver).
My mother has a blue Alero and I don't care for Silver. There was a Black one in Norht Philly, but it was sold from under me and there was a Ruby one in SE Ct that I scooped up!
If not for the Ruby I'd have settled for the Blue or Silver....
Sil
Sil
Close all the vehicle doors.
Press and hold unlock on the door lock switch.
steps 4 through 6 must be completed within 25 seconds of pressing the door unlock switch.
While holding the door lock switch in the unlock position, insert and remove the ignition key twice. Do not rotate the ignition lock cylinder.
Insert the ignition key a third time leaving the key in the ignition lock cylinder. The ignition must remain in the LOCK position for the rest of the procedure.
Release the door lock switch. The chime will sound three chimes to signal that transmitter programming/diagnostic mode is active.
Press and hold the lock and unlock buttons at the same time on the keyless entry transmitter for approximately 4 seconds. The chime will sound two times to signal that the transmitter has been programmed successfully.
Repeat step 7 for the rest of the transmitters (for a total of 4 transmitters).
To exit the transmitter programming/diagnostic mode perform either of the following:
Turn the ignition switch to the RUN position.
Remove the ignition key from the ignition switch.
When I get home tonight I will check to see if your procedure works. My fear is that my car (which I a stripped Alero that has power lock & truck but no keyless entry) may be wired to run the procedure you describe, but does not have the receiver on board.
Your thoughts are appreciated!
The mounting holes for the receiver are in about the center of the package shelf, no hardware is used, it more or less snaps in. Your GX shouldn't have it unless it was put on as an option. I'm sure it can be added, and it's a possibility a kit is available with all parts.
company. Does anyone know how to reset the door panel keyless entry code
without having the current code? I would like to be able to use this feature.
Once the remote control door lock receiver enters the programming/diagnostic mode, the programming of the first transmitter erases all previous transmitter programming information, requiring the programming of all transmitters.
· Remove the ignition key from the ignition lock cylinder.
· Remove the BCM PRGRM fuse from the fuse panel. Refer to Fuse Block diagram.
· Close all of the doors.
· Close the liftgate.
· Turn the ignition lock cylinder to ACC.
· Turn the ignition lock cylinder to OFF, and then back to ACC within 1 second. Open and close any vehicle door. A chime will be heard when the system enters the BCM programming/diagnostic mode.
Important
· Press and hold the transmitter LOCK and UNLOCK buttons simultaneously for 14 seconds.
· Repeat the previous step on each additional transmitter to be programmed.
· Install the BCM PRGRM fuse back into the fuse panel. Refer to Fuse Block diagram.
Important: Be careful and be sure which fuse you pull.
thanks brandon
