Chevrolet Suburban Battery Drain
I have had my 1999 Chevy Suburban in to the dealer 4 times for phantom battery drain. We'll wake up in the morning and intermittently the battery will be dead. No lights left on, no doors left open. the dealer replaced the 4X4 panel once and the battery twice to no avail. They seem stumped. Any ideas?
In theory, with a battery drain, you will have a meter reading or the test light will glow. A meter might be better because if the drain is very small it may not light a light. Anyway, once the meter or light is registering, you pull one fuse at a time until the light goes out. This gives you the circuit that the drain is in.
Then it gets tougher. Obvious culprits are dome lights, courtesy lights, etc. So once you know the circuit you may have to disable every component, one by one, in that circuit until the light goes out or the meter stops reading.
Sooner or later, victory is certain, but you have to be patient and methodical. Sounds like the dealer was neither. I can't imagine why they replaced the battery. It could have been load-tested.
A simple battery drain and they are having trouble with it?
The young pups in shops are more concerned with what the computer tells them, then anything else.
Don't get me wrong, there are many really good young mechanics coming into the field, but they are usually trained by a mechanic who is good.
Sorry for the rant.
