The 4 major issues with the early RDV's were the following.
1 BCM-electrical
2 Intake gaskets
3 AC condensors
4 Wheel bearings
The things we miss most about our 2002 CXL is the ride and the roominess.It couldnt be beat for that!
(1)Disconnect the vacuum hose from positive crankcase ventilation valve
(2).
Remove the positive crankcase ventilation valve.
Within many historical posts, I noticed a few folks had to replace their factory AC Condensor. Especially on thier 2002-2003 RDVs.
A few moments ago, I came across:
http://www.innerauto.com/Featured_Items2/rendezvous/C0255/
If the factory Condensor in my 2003 FWD RDV blows, should I replace with this one, or with the GM factory replacement part? Just wondering which product is better?
thanks...
It didn't bother her, but every time I drive her car, I notice that "rumble" sound. She has a FWD CXL with the third seat always folded down. I think it is just the nature of the beast. Such a big open area in the rear, with road noise coming in through the side panels.
I read other forums, including an Aztek one, and some people there complain about the "rumble" noise also. It must be a certain pitch which irritates some, but not others. If you really feel ambitious, try swapping the tires between the two "sister" cars, and see if that makes a difference in either. I would sure try that, wouldn't take that long to do.
I have an 03 and it made the same noise, and got worse the longer I drove it, especially at highway speeds. Turns out there was a factory recall on the front wheel bearings and hubs. I would call your nearest dealer and ask if your car, and it should be, is covered for the recall. They replaced both left and right for me and I no longer have the super loud humming noise - and it was free!
Thanks again
Open the rear hatch, and inside you will find two phillips head screws. Remove both, and the lense will slide back towards you, coming off the side of the rear quarter panel. There are two plastic "pins" attached to the quarter panel which you will see once you take the lense off. When reinstalling, line the clips inside the lense up with the "pins" and slide it forward until everything seats. Reinstall the two screws and you are done. Less than 1 minute to get the lense on or off.
The bulb is a 3057. Her bulb looked good, but I put a new one in and everything worked. I then put the old one back in, and it worked also! I checked all the connections by the socket, and everything looked good. I put the new bulb back in and buttoned everything back up. If this one quits working, I will get it to the dealer, since the extended warranty should cover anything other than the bulb.
Now my question. I thought these vehciles gave an indication on the dash or DIC when a bulb was not working. Her's never gave such a message.
Just remember, wash your hands before biting.
i got 03 rvd and at 124km it all fell apart 1 week after purchase. gaskets, bearings, and 1 pipe that delivers coolant, windshield cracked, hood starting to rust...
but i still like the car, just wish it were a bit lighter, feels too much like a minivan at times i think.
I love the ride, the spaciousness, the features (I have the CXL), and mine looks almost as good as it did the day I bought it.
Just figured I'd chime in. I've posted here about problems before, but overall, I'm still really happy with my Rondy.
As far as you say that yours feels heavy, similar to a minivan there is a reason. Even though the body of the Rendezvous is shorter it is still between 300 and 600 pounds heavier depending on accessories. I believe this is due in part to the four wheel independent suspension and the rear air ride assist. I feel my Rendezvous handles much better than all late model minivans. Although my brother purchased an '02 all wheel drive and his is considerably heavier.
I guess this post has some rambling in it but maybe some justification for your observation.
I have a love hate relationship with my 02 with only 65,000 miles on it.I purchased this beauty with only 32000 miles hoping for a quality vehicle. As with other owners I have replaced both front bearings and some sensor for fuel usage. Tires replaced. I love(d) my car.
In Jan of 07 I hit a deer broadside into the front grill. The entire exterior of the front end was replaced as well as the radiator. I drove my car for 5 days after the accident without incident. When I got my car back from the body shop my heater did not work when idling/at below 2000 rpms. I returned to the body shop. They said that they replaced the thermostat(1) and that it should be fine. I drove for 3 days with good heat before it happened again. I took it back to the body shop who told me that it was likely my water pump and not related to the accident. So, I took it to my mechanic who did not believe this and replaced the thermostat(2) that ran hotter. I ran fine for about4-5 days. First I slowly lost the heat at low speeds then over heated again. My mechanic then replaced the water pump. Heat was fine for about 1 week. I over heated again, lost heat. Thermostat replaced for the 3rd time, he flushed the heater core and the engine(I'm not sure what that means)and tested the head gasket pressure. Nothing. I had good heat for 3 weeks. Now heat is gone again,am starting to overheat again. Sheesh...Neither me or my husband are mechanics. We have agood mechanic who is baffled by this.I think he is leaning toward the heater core next. I'm not feeling good about this either. :sick: I just want to get back on the road.
Let me know if that fixes the problem.
Sounds like something might be plugging up the flow at certain times, causing the overheating and not allowing the hot coolant to circulate for the heater.
You might also want to check all the radiator hoses, make sure none of them are getting pinched, shutting off the flow of coolant. I would also check them for "soft" spots which would allow the hose to collapse and block the coolant. Any of these could come and go, not happening all the time.
Doubt that it is your heater core if you are not loosing fluid or smelling coolant inside the car, or have a wet spot on the carpet by the passenger foot area.
You could also have an air bubble in the cooling system, which would cause the same things. The system would need to be "burped" to get the excess air out.
I think it is something with the new radiator being installed after the accident, or a part of the cooling system as mentioned. I would also check the belt to make sure it is not worn or damaged, allowing slippage.
442455, The body shop guaranteed that all replacement parts were genuine ,new GM parts. They did a beautiful job. I do agree with your assessment, however. I checked all of the hoses and belts to the best of my ability. It felt rather empowering. I'm certain it's not the heater core,as you said if there are no wet spots its not the core. Mechanic said that it was burped.
Thank you, thank you gblanchette and 442455. I'll let you know when the "expert" checks it out.
Keep a close eye on that coolant level and make sure it doesn't go down. Good luck, and please do keep us informed.
Thanks for the redirect to this thread. I appreciate your keeping me/us posted on what happens, maybe we can help each other get to the cause. I am no mechanic but after doing more searching (google, etc.) I am pretty sure that in my case I have a leak that is pulling air into the cooling system. I don't seem to be losing coolant anywhere. In my search I found somewhat similar symptoms and consequent suggestions that it may be a cracked head or block or the new head gasket is ill fitting and leaking because the head was not made flat and true enough before the gasket was applied. Since I have had everything else replaced it seems more likely (to me, anyway) that that is the problem. I'm not sure if I can post a link to a competitor site on this page but I found a useful thread at cartalk dot com/ and then this tail board/showflat.php?Cat=0&Number=383462&page=0&fpart=all&vc=1
I take the car back in tomorrow and like you, I'm going to print out some stuff and give it to my mechanic.
It's not a problem if it adds to the discussion here but we do frown on flat out promotion of other sites.
SUVs and Smart Shopper
Thanks again for your time and expertise. I'll keep you posted.
As for the o2 sensor causing the "ice" to show in the dash readout, I don't understand that at all. The sensor "reads" the exhaust gas to give a reading to the computer for drivability. Has nothing that I am aware of for the temp display.
There is another sensor mounted in the front of the vehicle which sends the air temp to the display. If you had front end repairs from the deer accident, this sensor could have been damaged, or not re-connected during the repairs.
I have the service C/D installed on a computer other than the one I am using now, but I believe "ice" is an indication of a malfuction in the sensor (when it isn't actually cold enough outside for "ice" to show}
I still love my car, but I'm concerned that these problems are going to continue. I've owned Hondas and Nissans in the past and had no problems with either of them whatsoever until they got older and things started wearing out. Having things like this happening on a car that's just a year old really concerns me. Time will tell I guess. I hope I didn't make a mistake buying a Buick. There are plenty of people standing in line to tell me "I told you so."
